hayaman
LSP_Members-
380 -
Everything posted by hayaman
Excellent work,the correct prop is Curtiss assymetrical have in mind-cheers
- 133 replies
- 368fg/395fs
- hasegawa
(and 3 more)
Tagged with:
Trumpeter Republic P-47N Thunderbolt Cockpit After market?
hayaman replied to Vandy 1 VX 4's topic in LSP Discussion
I double this,their customer support is best of the best,even when i destroyed a small part and asked to buy it they send it free as a fellow modeler would have done-cheers- 40 replies
- Trumpeter
- P-47N Thunderbolt
(and 1 more)
Tagged with:
Thanks,i see you have done a lot of research,me too,hours and hours!,thanks again,cheers- 40 replies
- Trumpeter
- P-47N Thunderbolt
(and 1 more)
Tagged with:
Hi,i m building Razorback and i m planing to cut off details from MDC corrugated floor and attached them on the kit s,do you think the MDC set can be combined with the Razorback s back plate and then attach on the kit s fuselage?-cheers- 40 replies
- Trumpeter
- P-47N Thunderbolt
(and 1 more)
Tagged with:
The MDC set is (along with Eagle s FW 190 sets) the best cockpit set for WW2 plane,if you re patient you can take MDC s corrugated floor(also offered in the set)and cut off dets such as hydr pumps,stick,and other floor mostly details,personally i don t like the 2D effect of p/etched but in some cases(instr.panels,placards) they look superb-the Barracuda SPOKE wheels(without the flat cover) are ok for N you just have to look for the right tyre pattern if any particular for the N or the particular plane you build-cockpit has many differences and at least 1 unique as the seat had arm rests-cheers- 40 replies
- Trumpeter
- P-47N Thunderbolt
(and 1 more)
Tagged with:
Hallo mate,what s up?which green did you use for wells and 'pit?-by the way i mlooking for a prt from Trump s Razorback,the cockpit s back wall(with the headrest,is there anything you can do?(or any idea what i can do?)-cheers
New 1/24 P-47D RazorBack - 3208 - see you in 2015!
hayaman replied to raymondchung's topic in Vendors Board
I saw the bubbletop version,it s the Trump enlarged with some better detail though in places,still though with that AWFULL seam on the spine,no such problem with Razorback though,in my opinion with a resin cockpit it will be awsome -
...on enlargement i can see the w.shield is correct and i can t see the spinner clearly,if it s the Curtiss(and the prop too) it s ok-looks like the Trump in terms of surface detail,ok with me -
From what i can tell that prop is suitable only for the latest Razorback variants (-22,23) and if (i can t see clearly) the windshield is frameless that s a mistake,it was also...razor edged with metal at the edge -
Thanks mate,from pics of the now restored Guinea found 1,the colour is dark indeed,i ll try the mix
Great!-just fix the problem there was with the Vintage P-47(too short legs),from what i can see it s ok though -
Hallo-since lots of people has built it i wonder if any1 has found the exact interior colour-mind you it is NOT the usual int. green,it was called Northrop Interior Green and it was darker and duller than the normal int.green-any help apreciated,cheers
A sorry,no intention at all,it s just that i found out doing so 'late' and i was boring to re write!-cheers
Hmm,shouting?what do you mean,i don t understand...it s here because i asked for an adress at the 1st place not for parts-cheers
I don t understand why any company hasn t deside to make it since everytime some1 states 'INVADER' there s an uprising going on=i d like any Korean version or a firefighter!,a counter would be ok also-crossing fingers...
Hallo-thanks for trying but waat i need is the corrugated floor from the MDC set in particular-i can buy the whole set for 40EU but i m trying to find the floor alone and avoid paying the whole set for it-the set includes 2 floors for Has kit and since only 1 version of it needs the corrugated floor the majority of the modelers who built it would have it as a late 1(non corugated)so they ll have the other spare-thanks anyway
HALLO AND HAPPY NEW YEAR-IF YOU HAVEN T BUILD IT FOR SOME REASON OK OR ELSE I M AFRAID IT WON T BE ANYTHING AVAILABLE,ANYWAY,I NEED LEFT UPPER WING PART AND IT S LONG COVER(THE 1 THAT GOES OVER THE BULLETS) FOR EXAMPLE,BUT I LL SEND YOU THE PARTS BY NUMBER-THANKS
Hallo-any1 knows any source for Trumpeter spare parts-sprues?i need some from(any)P-47-thanks and H.N.Year
'Don t know if that is applicable to your conversion set but if it is the Tamiya VIII is the best-cheers
HK Mossie, first sight...... WIBBLE!!!!
hayaman replied to notanotherrainydaykit's topic in LSP Discussion
makes 2 of us! -
No! -
Hallo-i m looking to buy the CORUGATED floor as given in the P-47 s set,i guess the majority of the builds concern the latest types(non corugated floor)so the other should have stayed unused-PM me HAYAMAN210@HOTMAIL.COM-thanks
Hi,thanks for reply-indeed they only fit the big hole but trying to bend them either side at the mark there is on 1 of the sides doesn t give the sape it shows(and i ve seen in real belts-the small hole buckle should be at 90 degrees and vertical to the seat when belts are flat on it,i really can t see how...
Can they be made with a paint marker you think?-great build by the way
Hallo-Given the chance i want some help-i m starting my 1st atempt to use these belts in my P47 and i m stuck with a problem,'can t figure out how the buckles No 7 and 8 of the shoulder straps are benting,i see them in other belt sets without bending and the way HGW says to bent (the instructions are a scetch not photo) is impossible,maybe hmm,it s just me,nevertheless i d apreciate some help-thanks,cheers
