623 -
Everything posted by dashotgun
Silhouette Portrait 2 Settings for Custom Masks
dashotgun replied to Thunnus's topic in Decals & Masks
supposedly the cb09 is more precise then the silhouette blades they come in 30 45 and 60 degree blades -
my auto blade dies due to my inexperience and they are very difficult to acquire right now so I bought a cb09 no regrets it is not an auto blade but works great and the blades are replaceable . I just posted some designs on Kevin futters website btw https://www.scalemodelpaintmasks.com/ -
yes to both it will be more bright and metallic over a black base. I have actually sprayed over no base but you have to do light coats and test to see if it will attack the plastic. I have also used a lacquer base as well if again you start with light coats. MM lacquer black is good. The main thing is it will show any imperfection in you prep and sanding the base coat needs to be polished to a shine before putting the alclad on. BTW the new aki xtreme metal is quite good as an alternative and is a bit more forgiving IMHO. I still use both
perfect for us non figure painters no face!
hey that is normal for some
Another HK B-25 coming in March.... so they say...
dashotgun replied to Gazzas's topic in LSP Discussion
so does the model have the stressed skin effect? -
Is tonal mapping the same as a mottled layer
dashotgun replied to dashotgun's topic in Painting & Finishing
i have oil paints and turpentine amazon carries liquin magic. amenable to trying it on a test bed. So you are saying dried oil paint is compatible with enamel. Lacquer will cover anything I think -
another thought is why did you use oil paint? I use mostly enamels and lacquers and i am not sure that oil paint with its slow drying time etc is going to be a friendly under enamel or lacquer. btw your bench is as crowded as mine -
i wish iain mckenzie would weigh in he is amember here but posted on facebook and mentioned the term said he learned it here. I like the look Quang I agree that subtlety is warranted and sort of what your doing is also mottling but using color as well. Since as real object fade and wear the colors in the paint change as well with a colored subject like a ww2 era p51 with a color like olive green( or raf dark green) the properties of the paint and how it ages comes into play as well. I think yellow underlay although that may combine into green blue I am trying to achieve a yellowish under tone hmm -
https://www.autoblog.com/2021/02/07/scale-model-cars-planes-tanks-pandemic-antidote/
Came across the term and was uncertain to its meaning
i wish they made a kit for the mig 29 a
thanks the eduards look so good though, I received the sturmbock from ups today the landing gear legs look nice but are a bit flexible. I am going to order the Sow legs just as $ as the eduards but I like supporting one of our own . I am not sure all of my models need legs but replacing the fw190d was a bit of a pain so will go ahead with these or sac
having had a bad experience with the stock gear on the hasegawa 190d requiring a transplant. I used the sac gear and they were okay but the white metal leaves a lot to be desired. The eduard gear is pricy at 20 bucks plus shipping 1/2 the cost of the model. Lately i have trying to avoid a lot of the ams however I do like to photograph the models and requires some handling . So are metal gears really needed it is not a heavy model and if so are the brass ones worth it?
it is a day or so ago
Funny thing is i am building the original release now and decided to do Frenesi. I sourced the cutting edge decals but am going to make my own masks any way the irony is funny Btw the reports on the difficulty of the build are overblown.
Life under Lockdown.....What are we all missing the the most?
dashotgun replied to monthebiff's topic in General Discussion
i miss seeing my grandkids... the youngest is just under a year and is changing so much it is sad you can never get the time back -
Yolo
Still bought jt i will work something out. :)
just ordered from sprue bros the revell sturmbock yahoo!!!! in point of fact they got a whole restock many of the german revell models are back in stock
I have been looking for the sturmbock NA everywhere except europe with ridiculous prices and shipping, like 50- 60 dollars and 45 - 50 shipping. I got it for 40 with 9 shipping wahoo hopefully the drought is over. OTOH I have no place to display these any more
I just scanit via my printer scanner then do a trace however you get a lot of noise and poor separation between the colors -
just beautiful
