fozzy
LSP_Members
  • Content Count
    1,407
  • Joined
  • Last visited
  • Days Won
    5
Everything posted by fozzy
  1. Thanks for your comments guys!...helps me keep on track!
  2. Hi guys Well it's been nearly a month now since my last post what with family staying and this and that etc etc( you know the drill...getting in the way of modelling!)...but finally I'm now back at dealing with this B17G! ...and it was time to tackle the complicated ball turret hanging system!.......After looking at loads of confusing photos of the task at hand I decided that the only way to replicate it was to try and break it down into small stages.....wasn't going to be easy ...but then that's the challenge I guess! So I started with the frame work and th
  3. Sorry about the first two photos guys!...I accidentally deleted them off postimage hence breaking the link!......I will down load them again!
  4. Thanks a lot guys! Yes Kev....weird!!.....those two images are of a real Fortress....I will look into it!
  5. Afternoon chaps! Well after considering all the possible ways of how to build the structure which holds the ball turret to the fuselage just beyond the radio room I came up with some sort of plan! I had some vac formed molds of the ball turret that were not good enough when I was constructing it........way back it seems!......which luckily I kept. I thought that as it's the correct shape may be I could cut pieces of it to fit on top of the ball turret and then add the bits and pieces on top of that?.....so I went about that idea. I thought the best plan would be to
  6. Cheers Brian ......but not finished by a long shot yet mate!!
  7. Hi guys Today I would like to show you the completion of the radio room it self. This section of the build will still be on going as I have to get the ball turret installed and a shed loads of other details on the exterior....which brings me to a BIG problem! As normal with scratch building ...sometimes mistakes are made!...well I will own up to my mistake and tell you that the position of the ball turrets aperture is slightly out!.....( it needs to be a tad more to the rear)... I might be able to get away with it but it means a lot of re adjusting which means dest
  8. EQUIPMENT ON THE REAR PORT BULKHEAD Hi Guys There is a lull in the good weather so I have found the time to do another posting here rather than concreting! This will be the penultimate posting of the Radio room before I tackle the complicated mechanism above the Ball Turret!....something that's going to be a tough one no doubt! ....but first lets get to today's posting! Not too much stuff had to be scratched...there is a spare oxygen bottle....Liaison Transmitter ....Liaison Antenna Tuning Unit and a few bits and bobs on the side wall
  9. FORWARD STARBOARD AREA OF THE RADIO ROOM Hi guys Another week gone by and another area of the radio room complete!....and another week nearer to starting the rear section of this build!... So a few things had to be scratched and so I started with the Command Receivers...here they are before painting and wiring up!......... Being approx 3 cm long it was a bit fiddly...I had to drill tiny holes to accept the pins I used for the cable connectors and switches etc ....here it is painted....... Above the Receivers
  10. Cheers Kev!....what I really need is one of those miniature camera/videos..so that I can get into all the nooks and crannies!
  11. THE EQUIPMENT BENEATH THE RADIO OPS DESK Hi to all! Here is the next episode to this never ending saga! Before I start I want to say that I do realize that this scratch build is not 100% accurate.The interior colours I have chosen are a mish mash taken from hundreds of photos I have collected.The other problem is that it seems that The Flying Fortress's interior used different equipment and placed them in different areas of the aircraft....for example the Tokyo shut off valves. I have placed them on my model beneath the Radio ops desk ...which some of the G
  12. RADIO EQUIPMENT ABOVE THE RADIO OPS DESK INSTALLED Hi guys We continue!............... I spent all this week since the last post installing all the radio equipment I scratched......As a reminder this included ..the radio ops desk that had the Liaison Receiver ,spare turbo amplifier ,headphones ,transmitter master switch ,transmitting key and desk lamp. I also installed the Command dynamoter and modulator ,the fire extinguisher ,portable oxygen bottle , IFF crash switch and the oxygen regulator and panel...I don't think I left anything out! Here a
  13. Cheers Tom! No I haven't forgotten about that window as it has been giving me a headache since I started on this section!...There are many different variants of the radio room hatches on the B17G. The photos of this B17G I am building seems not have that window forward of the hatch and then other photos show that it does!....so rather confusing to say the least! Luckily most of the roof section of the radio room I am constructing is open to show the internal detail, so therefore I don't need to worry too much about it...as long as I show the actual hatch
  14. BITS AND BOBS ABOVE THE RADIO OPS DESK Hi chaps Another week gone by and more equipment scratched There is so much equipment in the radio room that I decided to break it down into areas.....so today's post will be concerning the gear above the radio ops desk including what would have been on the desk! So to start with I knocked up the ops table...... ....and on this table we first need the Liaison Receiver. ....a 4 sided plastic square with scrap plastic and wire for switches etc! A bit of paint a
  15. FUSE PANEL ,RADIO ROOM HATCH AND CONTROL CABLES! Hi guys Hows it all going in the model world? Here we have the next installment of the radio room build for this B17G...as the the title states I managed to get 3 things completed since the last post....so starting with the fuse box here are some photos............ Quite straight forward really...a thickish piece of plastic was cut and manipulated into the fuse box!! It was then painted and cables added to it ....and here it is installed in it's rightful
  16. Well hi there one and all! After a long long break which included Christmas/New Year and a trip to San Diego to see family I have finally returned to my office and the B17G.......I do hope the start of this year has been kind to you all so far! So what have I done?...well I have done all the basic construction for the top half of the radio room. It took some time as the sky light above the radio room proved to be a bit of a pain to get it together...I just hope that it looks ok! The insides to the Balsa fuselage was covered with the plastic from yogurt pots
  17. Brilliant video showing the potential power of the ball turret and of course the cramped space the gunner had to squeeze into!....thanks for sharing the video themongoose
