Bstarr3 Posted March 20, 2018 Share Posted March 20, 2018 Having just finished my Mossie, I'm on to a quicker build. I'm doing the new Mustang wheels up with a pilot figure - old school! I may even hang it from the ceiling! After my long term project, I'm doing this with no aftermarket, no scratch building. The only thing not out of the box is the Tamiya pilot figure, generously donated by David66. Anyway, here's some shots of the cockpit underway. I know the plywood is supposed to be overpainted in black, but I'm just leaving it as is since the pilot is going to take up most of the space in there anyway. The IP decal is actually really nice right OOB. Snugs down into the detail beautifully. There are a nice set of placard decals as well. Out2gtcha, CANicoll, Big Texan and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 20, 2018 Share Posted March 20, 2018 Looking good! I plan on doing this exact same thing with my CM F7F kit, and turning into a What-if Reno Unlimited. Not enough wheels up builds! Looking forward to more progress..................do you have a scheme in mind yet? Link to comment Share on other sites More sharing options...
1to1scale Posted March 20, 2018 Share Posted March 20, 2018 Here is a tip that will save yourself some grief. 1. File down all all the slots that the cockpit halves go into, the biggest issue with the whole assembly is that once painted and assembled, its about .020 too wide, which throws off the canopy and windscreen. Also, test fit all the canopy clear parts, dont be surprised if you need to shim the windscreen up and out, and the canopy out. 2. Don't paint, just glue all the internal pieces into the wings, without paint, you should get a really good fit. 3. Check for sink marks on the landing gear doors, trailing edges of the upper wings, and the flaps. 4. Make sure to spend some time fitting the tail halves to the fuselage, you will have to do some sanding and filling. You will also have to fill the entire seam along the fuselage halves. As long as you know the issues beforehand and are not surprised by them it should go very quickly. I still plan on building a couple more, as this is a very good looking finished model, but the one I back-ordered in December has still not shipped. Big Texan and Out2gtcha 2 Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 20, 2018 Author Share Posted March 20, 2018 Looking good! I plan on doing this exact same thing with my CM F7F kit, and turning into a What-if Reno Unlimited. Not enough wheels up builds! Looking forward to more progress..................do you have a scheme in mind yet? In keeping with my straight OOB theme, I'm going to do good ol Lou IV. I can't decide if I feel like tweaking people by doing it in OD/blue instead of OD/medium green Out2gtcha and CANicoll 2 Link to comment Share on other sites More sharing options...
RLWP Posted March 20, 2018 Share Posted March 20, 2018 Here is a tip that will save yourself some grief. 1. File down all all the slots that the cockpit halves go into, the biggest issue with the whole assembly is that once painted and assembled, its about .020 too wide, Only, as I keep banging on, mine wasn't! Richard Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 20, 2018 Author Share Posted March 20, 2018 Only, as I keep banging on, mine wasn't! Richard Looks like dry fitting is the order of the day! RLWP 1 Link to comment Share on other sites More sharing options...
quang Posted March 20, 2018 Share Posted March 20, 2018 Here is a tip that will save yourself some grief. 1. File down all all the slots that the cockpit halves go into, the biggest issue with the whole assembly is that once painted and assembled, its about .020 too wide, which throws off the canopy and windscreen. Also, test fit all the canopy clear parts, dont be surprised if you need to shim the windscreen up and out, and the canopy out. Speak for yourself. Like I said on the other thread, mine went on without any problem. Can't understand why some people insist on dissing the Revell kit. Out2gtcha, Troy Molitor, coogrfan and 2 others 5 Link to comment Share on other sites More sharing options...
Out2gtcha Posted March 20, 2018 Share Posted March 20, 2018 Speak for yourself. Like I said on the other thread, mine went on without any problem. Can't understand why some people insist on dissing the Revell kit. I dont think he was dissing the kit at all. AAMOF, he clearly states he likes the finished model, and plans on building more. It sounds just more like he is stating what a lot of folks have found, that sometimes the cockpit if built up with paint, and/or not sanded properly can potentially interfere with fuselage fit. I think the kit fits just fine, but care will have to be taken on the internals to keep that on track. Its obviously not perfect, but as your build, and other builds show, it can be made to fit well, and by the few Ive seen built, turns out to be a very nice looking model. Ive got custom 357 FG paint masks ready to go for my copy. quang 1 Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 20, 2018 Author Share Posted March 20, 2018 It definitely looks like some, but not all, people have had fit issues. I will carefully dry fit to make sure whether any modifications are necessary or not. I have noticed, as was mentioned in another thread, that the clear parts have some unevenness that affects their transparency. I'm not too upset about it for a $25 kit. Out2gtcha 1 Link to comment Share on other sites More sharing options...
CANicoll Posted March 20, 2018 Share Posted March 20, 2018 In keeping with my straight OOB theme, I'm going to do good ol Lou IV. I can't decide if I feel like tweaking people by doing it in OD/blue instead of OD/medium green I'll be doing Lou IV in the blue/OD. Dana sent me his Hi-Res scan (higher res than what he posted on the threads) and that is a really helpful photo reference. Looking forward to seeing your build! Chris Link to comment Share on other sites More sharing options...
RLWP Posted March 20, 2018 Share Posted March 20, 2018 I will carefully dry fit to make sure whether any modifications are necessary or not. Do! You'll find there are several places where nothing seems to fit, then parts click into place Richard Link to comment Share on other sites More sharing options...
MikeMaben Posted March 21, 2018 Share Posted March 21, 2018 Looks like dry fitting is the order of the day! When is it not ? Jeff 1 Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 21, 2018 Author Share Posted March 21, 2018 When is it not ? Touché MikeMaben 1 Link to comment Share on other sites More sharing options...
Gazzas Posted March 21, 2018 Share Posted March 21, 2018 Nice detail work! Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 21, 2018 Author Share Posted March 21, 2018 Nice detail work! Thanks, Gaz! I've decided no super-detailing here. I'm not even going to wire up the battery and radio. This is a strictly OOB build. MikeMaben 1 Link to comment Share on other sites More sharing options...
