1/32 Trumpeter Me 262A-1a "Yellow 3"
  • Please log in to reply
92 replies to this topic
#16 Ohm-men
Ohm-men
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 50 posts
Posted 24 January 2018 - 10:14 AM
Looking forward to this! Seams you're taking the 262 whole the way to town!
Those Barracuda wheels look delicious, such detail....
A few guys at my club are building the 2 seater version of the 262 and I think it's a great kit, especially considering all the updates you will be using.
  • Thunnus likes this
#17 VintageEagle
VintageEagle
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 87 posts
Posted 24 January 2018 - 10:38 AM
Great choice of subject. Looking forward to your build! The Trumpeter Jumo 004 intake diameter looks visually too small, but I haven’t measured it and compared with the original. I may be wrong. The rivetting is indeed a bit exagerated, but may be toned down by a layer of primer. Note tht the tail of this aircraft was made of wood (it was one of the few experimental tails attached to some aircraft).
Edited by VintageEagle, 24 January 2018 - 10:40 AM.
Interested in the Me 262 and photos of captured German WWII aircraft
Vintage Eagle Publishing
www.vintageeagle.com
#18 G-Man
G-Man
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 107 posts
  • Gender:Male
Posted 24 January 2018 - 12:51 PM
I just got this kit as a b-day gift, so I'll be watching your build. Will you be using putty on all the seams and rivets like the real thing?
ON THE BENCH: Trumpeter 1/32 Ju 87B-2
ON DECK: Hasegawa 1/32 Fw 190D-9
#19 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 21,534 posts
  • Gender:Male
Posted 24 January 2018 - 01:18 PM
Wow, terrific looking!  With your paint and weathering skills, this will be a stunner in the end.  More please!!
#20 Wackyracer
Wackyracer
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 183 posts
Posted 24 January 2018 - 01:30 PM
Here are the Montex Masks that I've picked up for this build.  I really like using masks instead of decals whenever I can and at a minimum, I'll be using these masks for the numerals, crosses and swastikas.  They also have the yellow/black skull badge as a mask but it looks a bit fiddly to use.  I can use the Trumpeter decals for badge as a back-up.
In lieu of the PE belts that Trumpeter supplies, I've purchased a s et of HGW fabric belts.  I have a hard time getting PE belts to look natural and fabric belts, whether they are from HGW or RB, are my preferred choice, especially for open canopy builds.  And no, I didn't make a purchasing mistake... I saw that the 262B set was about the same price as the 262A... a great cost-cutting move to pick up two harness sets for the price of one, no?
img=https://s6.postimg.o...1/IMG_2127.jpg]
I got the same Montex masks for a different plane with the yellow/black skull badge. I didn't realise it was in the kit which I already owned!
HGW belt sets; same idea/thoughts as well. Mosquito sets come with 2 RAF belts but the same price as a single spit set.
Looking forward to this one.
  • Out2gtcha, Wouter and Thunnus like this
#21 Thunnus
Thunnus
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 521 posts
  • Gender:Male
Posted 24 January 2018 - 05:12 PM
A delightful and challenging build awaits you John.  Thanks for taking the effort to share your trials and victories :D
Looking forward to the odyssey  :piliot:
Dan
Thanks Dan!  This one is going to a long one, I think.  I have an oversees trip in February that will take me off the bench for at least a few weeks.
Time to get the dremel out by the looks of it John!!
Regards. Andy
Yes.  Once I am comfortable with how the Aires components fit and which kit parts will remain, I'll have to start the hacking process.  Depending on the quality of the plastic, sometimes I find it easier to use a curved x-acto blade to slice off those long ribs on the interior.
You can grind those tabs away - and the kit pit will still fit nicely in the fuselage!
Have a look here: http://forum.largesc...ic=67660&page=2
Cheers
Alan
I just checked out your entire build thread, Alan.  Good to know about those huge mounting lugs... removing those will make it easier to compare the fit of the Aires components to the kit parts.
Thanks Jerry!  Are your friends building the Trumpeter 2 seater or the new Revell?
Thank you for that information!  I know more about the 109G/K and 190D-9 so any insight regarding the 262 is very helpful and appreciated.  I'm not going an absolute stickler for accuracy but I like doing those little things that make one's build different from the rest.
I don't think I'll be removing the rivets.  My plan is to reduce their impact by giving the exterior surfaces a fine sanding and re-scribing all of the panel lines.  That plus the priming/painting process should knock the rivets down.
Thanks Brian!  My brain is still stuck on that first obstacle... figuring out these Aires resin pieces.
Are you going to do Yellow 2?  That's a very interesting scheme.
  • harvey likes this
John
#22 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,382 posts
  • Gender:Male
Posted 24 January 2018 - 08:00 PM
Great project, John. It's funny that you're contemplating whether it's worth using the Aires cockpit to upgrade the Trumpeter one. I used parts of the Trumpeter cockpit to upgrade the Hasegawa kit when I built it!
http://forum.largesc...showtopic=29698
Kev
#23 Victor K2
Victor K2
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 152 posts
Posted 24 January 2018 - 08:04 PM
If the undercarriage legs seem too long, it could be that the aircraft Trumpeter used as a reference ( photo's, drawings or museum aircraft ) were devoid of fuel/equipment/ordinance etc, and were therefore at the full extent of the oleo's. A lot of manufactures should offer fully extended or compressed versions of U/C legs. so as to give we, the modelers a choice of posing our model as either "in flight" coming in to land, or "on the ground" fully loaded.
Oh, one other thing, we do Maths here in the UK, Maths is made up of a sum of numbers with an answer the result. A number on it's own is just a number and not Math as how did you get the answer without doing the Maths :frantic:
All joking aside, I look forward to this build , if only to give me some inspiration to get mine out of the loft/attic.
Bob.
  • alaninaustria and Thunnus like this
#24 Daniel460
Daniel460
    Senior Member
  • LSP_Members
  • 514 posts
  • Gender:Male
Posted 25 January 2018 - 04:38 AM
:popcorn:
 Great start John. Really enjoy your detailed build threads!  :thumbsup:
 Dan
#25 Troy Molitor
Troy Molitor
    Senior Member
  • LSP_Members
  • 1,503 posts
  • Gender:Male
Posted 25 January 2018 - 11:10 AM
I’ll be looking forward to this one John as the rest have also mentioned. Great subject and start so far.
Troy
#26 Wackyracer
Wackyracer
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 183 posts
Posted 25 January 2018 - 01:30 PM
I haven't got a 262 scheme figured yet, but that's right up my alley being all Frankenstein and all that.
The masks are destine for this...
d0jxrrg.jpg?1
  • LSP_Kevin, Martinnfb, harvey and 1 other like this
#27 Thunnus
Thunnus
    Senior Member
  • LSP_Members
  • 521 posts
  • Gender:Male
Posted 25 January 2018 - 06:21 PM
Wacky... that is a wild Ju88 scheme.  I've never seen that one before.  I love a high quality profile!
John
#28 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,087 posts
  • Gender:Male
Posted 25 January 2018 - 09:10 PM
John,
    As a relative novice when it comes to resin, I appreciate your insights as to how to go about it.
I can definitely see that there is some improvement with the resin parts.
Gaz
​We don't have social skills.  We build models.
#29 speedgraflex
speedgraflex
    Member
  • LSP_Members
  • PipPip
  • 10 posts
  • Gender:Male
Posted 31 January 2018 - 09:11 PM
John,
I am so glad you are documenting your projects with such care. As usual, your attention to the details is top notch. I will definitely have some more to offer you here, having discussed with Thomas 1/32 Jumos in detail from a modeling perspective, but these notes will be shared when you begin work on the engines, I think, to preserve your wonderful flow to the story you are telling. Personally I go back and forth on whether to leave a cover off one engine since the Jumos were so fussy to maintain. Have you considered this option?
All the best,
Bruce
#30 CATCplSlade
CATCplSlade
    Senior Member
  • LSP_Members
  • 1,075 posts
  • Gender:Male
Posted 31 January 2018 - 10:18 PM
Bob.
That's interesting. Here in the U.S. we have something similar called Mathematics. We can not only do sums, but we can also find products, square roots, areas and volumes and all manner of wonderful things. Perhaps we can arrange to send over some samples with our next shipment of Justin Timberlake albums and Supernatural dvd box sets. 😚
Edited by CATCplSlade, 31 January 2018 - 10:20 PM.
  • scvrobeson, Victor K2 and Zank_Frappa like this
Working on: AIR - Revell Spitfire Mk IIa   LAND - Bandai 1/30 Hummel, Zvezda Mercedes L4500A, Dragon Kubelwagen Ambulance
