1to1scale Posted January 19, 2018 Share Posted January 19, 2018 (edited) So, i got bored, was home from work sick, and as they say, idle hands... I decided to whip a quick build together...Hobbycraft P-51A/MK.I RAF 309 Polish Sqd, 1943. I decided to turn my P-51A into a MK.I and with no purchased AM, I will add a few minor scratch build items to the cockpit and use a few leftover pieces from other builds, but other than that, this one is really just meant for a paint job. I'm doing a Sea Gray / Dark Green camo. I will also be adding a Malcom hood I pulled out of my MK.Ia kit. I am also considering doing a night fighter version that was 75% Dk Green and 25% Dk Sea Gray on top, and all black on the bottom, Im still researching this one. Here are a few pics, I am leaning toward doing the first one, “B†scheme. Edited January 27, 2018 by 1to1scale CANicoll, LSP_Kevin, Gazzas and 3 others 6 Link to comment Share on other sites More sharing options...
CANicoll Posted January 19, 2018 Share Posted January 19, 2018 LOVE the early Mustangs with the Malcom Hood from the Polish squadron. Looking forward to your build! Chris Link to comment Share on other sites More sharing options...
Thunda Posted January 19, 2018 Share Posted January 19, 2018 Im in the middle of one of these- been doing some scratch building of the tray behind the pilots head with the camera on it. Nice overall sillouette but you can tell its an upscaled 1/48- internal fit quite poor and short on detail although I used the Eduard P51B set for the Trumpeter. Look forward to following your build. By the way- Ive been 3D printing a corrected spinner for this kit if you are interested. There are two versions- see this thread: http://forum.largescaleplanes.com/index.php?showtopic=72188 Harold 1 Link to comment Share on other sites More sharing options...
Martinnfb Posted January 19, 2018 Share Posted January 19, 2018 Excellent choice, I will follow with interest. Cheers M. Link to comment Share on other sites More sharing options...
1to1scale Posted January 19, 2018 Author Share Posted January 19, 2018 I have to admit, the cockpit fit was poor, as you see in the pictures, I had to use some shims and do some creative placement of some styrene strips. I also moved the upper tray behind the pilot back to bulkhead behind the rear windows, although, from pictures I have seen, they seemed to vary quite a bit. I still have to sand the wheel wells as the plastic is thick and interferes with the bottom of the cockpit floor a bit. I am using some leftover PE from other builds, but I am determined not to buy anything but a mask set for painting. There are definitely some minor fit issues all over, but nothing a sanding stick cant resolve. I spent about three hours total getting it to this stage, pretty much, all the gaps are near perfect and will not require putty, most of the fit issues were from rough mating surfaces, and misaligned mating pins. The wings only requires some very minor sanding for clearance, the front cowl was perfect, a little sanding on the right fuselage to cowl joint gave me a very tight fit. Actually, it was too tight, so I had to add a slight bevel to return the panel line. Most of the three hours was fabricating and sanding. I'm ready to paint the interior, then I will glue it all up and get it primed up. I wish Hobbycraft was still around as this is generally a nice kit. It really could use some more cockpit detail, but this will be a quick build and I will keep it simple. sandokan 1 Link to comment Share on other sites More sharing options...
R Palimaka Posted January 19, 2018 Share Posted January 19, 2018 Great project, wish I had one of these! Just a minor note, I think you'll find that Malcolm hoods on RAF Allison-powered Mustangs were extremely rare. I'm certain that none of 309's had them. You did say however that this was a painting exercise, so carry on. Sorry for being that guy... Richard Snowbird3a 1 Link to comment Share on other sites More sharing options...
1to1scale Posted January 19, 2018 Author Share Posted January 19, 2018 (edited) I am struggling with putting the Malcolm hood on. I have one picture of a Malcom hood on a MK1a 168 Sqd 1944, but its not a polish unit. I know they were swapped onto some aircraft, I figured...what the hell. I have also seen some Allison mustangs as late as mid 1944, so a few stuck around, its entirely feasible that some units had them, but I think it looks cool, so I really want one, the hard part is documenting a plane with it. Edited January 19, 2018 by 1to1scale MikeMaben 1 Link to comment Share on other sites More sharing options...
1to1scale Posted January 19, 2018 Author Share Posted January 19, 2018 (edited) I found this rather useful article if anyone is looking for early MK1 camo information. RAF versions http://www.ipmsstockholm.se/home/camouflage-and-markings-of-north-american-p-51-mustang-part-2/ US versions http://www.ipmsstockholm.se/home/camouflage-and-markings-of-north-american-p-51-mustang-part-1/ Edited January 22, 2018 by 1to1scale Thunda 1 Link to comment Share on other sites More sharing options...
Adam Maas Posted January 20, 2018 Share Posted January 20, 2018 (edited) I am struggling with putting the Malcolm hood on. I have one picture of a Malcom hood on a MK1a 168 Sqd 1944, but its not a polish unit. I know they were swapped onto some aircraft, I figured...what the hell. I have also seen some Allison mustangs as late as mid 1944, so a few stuck around, its entirely feasible that some units had them, but I think it looks cool, so I really want one, the hard part is documenting a plane with it. The last Mustang in RAF service was actually an Allison Mustang, retired in 1947, the Allison Mustangs served right until the end of the war and were the only Mustangs the RAF could keep (as the Mk1 and 1a were not lend-lease). Very few got the hood though, as it was less beneficial for the missions they flew (which was mostly low-level recon) than it was for the MkIII's flying fighter sweeps. Edited January 20, 2018 by Adam Maas Link to comment Share on other sites More sharing options...
dennismcc Posted January 20, 2018 Share Posted January 20, 2018 Great idea, there's nothing like a quick OOB build with no worries about the exact details to refresh the modelling mojo. Cheers Dennis Link to comment Share on other sites More sharing options...
1to1scale Posted January 20, 2018 Author Share Posted January 20, 2018 (edited) Quick update, I got the interior, landing gear, and wheel wells airbrushed, now just have to hand paint some details before I close up the fuselage. Damn...I forgot to sand the seam mark off the control stick. Grrrrr... Edited January 20, 2018 by 1to1scale sandokan 1 Link to comment Share on other sites More sharing options...
1to1scale Posted January 21, 2018 Author Share Posted January 21, 2018 After struggling with ordering a set of PE for this, I relented and dug out a set of P-40N PE from my stash, which I just used the placards and a few bits for the cockpit boxes, the rest is paint. I still have to weather it a bit, but for a $10 cockpit, I'm happy. Gazzas, LSP_Kevin, Shawn M and 1 other 4 Link to comment Share on other sites More sharing options...
1to1scale Posted January 22, 2018 Author Share Posted January 22, 2018 Weathering with dark brown wash, and aluminum, gray, dark green, and light green powders. I used the set of Eduard P-40 seatbelts, they may not be correct, but it's all I had on hand. Gazzas, LSP_Kevin, MikeMaben and 3 others 6 Link to comment Share on other sites More sharing options...
Gerhard Posted January 22, 2018 Share Posted January 22, 2018 Looking good. Link to comment Share on other sites More sharing options...
1to1scale Posted January 22, 2018 Author Share Posted January 22, 2018 The last Mustang in RAF service was actually an Allison Mustang, retired in 1947, the Allison Mustangs served right until the end of the war and were the only Mustangs the RAF could keep (as the Mk1 and 1a were not lend-lease). Very few got the hood though, as it was less beneficial for the missions they flew (which was mostly low-level recon) than it was for the MkIII's flying fighter sweeps. As I was researching this version I learned a lot of interesting things about why the RAF had so many MK.1 and MK.1a Mustangs, and why they kept them so long. These were not Lend/Lease, these were bought direct from NA, so they were bought and paid for, so that explains why they were flying these until the end of the war. Thunda 1 Link to comment Share on other sites More sharing options...
