F-14B UPGRADE 1/32 Tomcat
  • Please log in to reply
153 replies to this topic
#46 Fancherello
Fancherello
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 701 posts
  • Gender:Male
Posted 24 November 2017 - 05:22 PM
Thank you !
#47 fab
fab
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 135 posts
Posted 26 November 2017 - 08:21 PM
C'est à cette heure que tu rentres?
Pas mecontent de te voir de retour!
Amities
Fab
#48 Fancherello
Fancherello
    Senior Member
  • LSP_Members
  • 701 posts
  • Gender:Male
Posted 01 December 2017 - 07:14 PM
a small update to share a good experience with a product new to me.
Tinting glass/canopies is something I ( we ? ) don't practice that often and honestly I never feel comfortable when reaching this step. Moreover in the case of Tomcats I often find the tinting effect a bit overdone. Then I found just per chance the Alclad clear Armour Glass tint. ( On a webshop where I was looking for something totally different ! ) and decided to give a try.
I found it a very good product. The tint is much lighter than expected and builds up slowly enough to stop before it's too late ! I sprayed through my airbrush, medium pressure a few passes of a mist coming a bit more wet in the end. THe result is cristal clear, equal shade all over the part, perfect tension. Straightforward and spot on the result I was looking for.
What a relief because this is a step where you can't really mess up or you end up ordering new clear parts !
24174614_517783608603525_884136398317060
24232014_517783635270189_835743578117624
Edited by Fancherello, 01 December 2017 - 08:46 PM.
  • stusbke, Starfighter, LSP_Kevin and 9 others like this
#49 A-10LOADER
A-10LOADER
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 454 posts
  • Gender:Male
Posted 03 December 2017 - 02:21 AM
Welcome to Team Alclad, I love their stuff. Nice work.
Steve
OPERATION "DELIBERATE GUARD", "SOUTHERN WATCH", "ENDURING FREEDOM" AND, "IRAQI FREEDOM" VETERAN.
#50 Fancherello
Fancherello
    Senior Member
  • LSP_Members
  • 701 posts
  • Gender:Male
Posted 03 December 2017 - 12:11 PM
Thank you ! I do love their metal paints range, but i didn't know they had transparent hues in their range. I wasn't confortable about a lacquer on a clear part either, but it's been great !
  • A-10LOADER likes this
#51 Vandy 1 VX 4
Vandy 1 VX 4
    Senior Member
  • LSP_Members
  • 3,419 posts
  • Gender:Male
Posted 03 December 2017 - 04:35 PM
Alclad also has some Prismatic colors. The UV one. I've been wanting to use for years
Candy is Dandy but Liquor is Quicker :beer4:
#52 Jose Pedro
Jose Pedro
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 83 posts
  • Gender:Male
Posted 03 December 2017 - 04:43 PM
Very interesting solution!
#53 jenshb
jenshb
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 257 posts
  • Gender:Male
Posted 07 December 2017 - 10:35 AM
Alclad's armoured glass is a great product with no adverse effects on the clear parts, and even if you get some orange peel, you can micromesh and polish it to perfect clarity.  Beware though that - in my experience - Alclad's other transparent colours; red, green, blue, yellow, smoke are far more aggressive on clear parts and will ruin the clarity of these parts.
Jens
#54 Fancherello
Fancherello
    Senior Member
  • LSP_Members
  • 701 posts
  • Gender:Male
Posted 07 December 2017 - 11:14 PM
Thank you Jens for the information !
Fanch
#55 Fancherello
Fancherello
    Senior Member
  • LSP_Members
  • 701 posts
  • Gender:Male
Posted 07 December 2017 - 11:59 PM
hello
here's an update. After reading Daco's book, the build is turning into a 3D thema and I chose to try and take part of the big scale. Pictures show many lines of filler showing the fight against water all around the airframe. Some line appear fresh an dstraight, some are pretty rough and uneven. I depicted this with different ways to lay down some Mr Surfacer, which hopefully will help to give a bit of life to such a big surface.
I got rid of some unwanted rivets, typical Trumpeter surprise.
I added a bit of detail around the taillhook and reshaped and hollowed the hook itself.
The canopy is cristal clear and superb but has horrible and thick raised details ( fuse lines above bang seats ), so sanding and polishing were necessary.
I have an eduard etch set but the details that have to go on the slats wells dont show some very viible rails so I'll do this part on my own and started with masks and layers of surfacer.
I started to detail the belly pallets and thought their head would be OK...I detailed hinges, holes and rivets...and once I dryfitted them on the kit with a missille....they looked terribly flat. So I kiked my b..tt and went into reshaping their head covers: I opened the with a razor saw, added an insert cut from Daco's drawings. I raised the bulge lines that appear on the outer vertical face by addind a thick strip, sanded and carve it. Then I laid a structure made with thin rods and suffed it with modelling clay . I sanded the clay down until the rods showed off and used thin filler and surfacer to get an even finish. I finished them with scribing and a few hinged doors ( R and L layouts are different ). At the moment a last coat of Surfacer is drying to get a step between the rail and the first part of the cover: I didnt treat both part of the head together to get the impression of to separate parts in the end, both having smoother lines than the rail itself. Resin bomb adapter are Aires/Aerobonus items.
bye
Fanch
Edited by Fancherello, 08 December 2017 - 12:04 AM.
  • Starfighter, blackbetty, LSP_Kevin and 5 others like this
#56 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,382 posts
  • Gender:Male
Posted 08 December 2017 - 12:05 AM
Expert work as always, Fanch.
Kev
#57 Fancherello
Fancherello
    Senior Member
  • LSP_Members
  • 701 posts
  • Gender:Male
Posted 08 December 2017 - 12:54 AM
Thank you Kevin !
#58 A-10LOADER
A-10LOADER
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 454 posts
  • Gender:Male
Posted 08 December 2017 - 01:26 AM
Beautiful !!
Steve
#59 Starfighter
Starfighter
    Senior Member
  • LSP_Members
  • 1,197 posts
  • Gender:Male
Posted 08 December 2017 - 07:32 AM
There's nothing not to love about this - great progress, Fanch!
#60 Jose Pedro
Jose Pedro
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 83 posts
  • Gender:Male
Posted 08 December 2017 - 01:36 PM
Hi!
Thanks for the update!
Your work is very well done and i love the attention to detail!
Cheers!
  • MARU5137 likes this
