1to1scale Posted September 14, 2017 Share Posted September 14, 2017 Thanks to Tony (tjtx) I swapped my Tamiya Spitfire for this wonderful Snipe kit with a little bit of AM included. I am not yet sure which version I am building, but will need to make a choice soon. Last night I cut open the bags and pulled all the parts that needed wood-graining. I sprayed them all with a very thin coat of Tamiya Desert Yellow, tonight i may try my hand at wood grain and oils. Hopefully I wont muck it up too bad, I have watched enough youtube to get some ideas on how to get it done. sandokan, LSP_Kevin and Harrison90 3 Link to comment Share on other sites More sharing options...
Martinnfb Posted September 15, 2017 Share Posted September 15, 2017 Nice choice , I will follow with interest. Link to comment Share on other sites More sharing options...
ZachP319 Posted September 15, 2017 Share Posted September 15, 2017 I'm on board for this ride. Only problem I have with the snipe is weather to do the early or late. I like both for different reasons. On a side note I find it odd that WNW did not include Barker's Snipe as one of the decal options. I know Pheon makes a sheet with his mount but really thought WNW would have provided. Oh well..... Zach Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 15, 2017 Share Posted September 15, 2017 I built the late kit, and as most WnW kits go, its superb! Not sure if the early comes with it or not, but just watch that Aldis long gun sight. It attaches to the upper wing IIRC, but actually goes through the windscreen, which is attached to the fuselage. Link to comment Share on other sites More sharing options...
1to1scale Posted September 15, 2017 Author Share Posted September 15, 2017 (edited) I started last night by prepping the oil paints. As someone suggested, I put a folded paper towel in a small tupperware dish with a lid (dont tell my wife!). I squeezed out a couple globs of Light and Dark Ocher oil paint, and I will let the linseed oil leach out for 24 hours before I start tonight. I also forgot to paint the seat frame (A30) and I took out a chunk of the prop when cutting it off the sprue, I need to fill the gak and paint both pieces. Also, I think I settled on Option E as I like the turned aluminum cowling and I have a good idea as to how I will achieve that effect. Edited September 15, 2017 by 1to1scale Out2gtcha 1 Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 15, 2017 Share Posted September 15, 2017 I started last night by prepping the oil paints. As someone suggested, I put a folded paper towel in a small tupperware dish with a lid (dont tell my wife!). Try thinning the oils with Japan Drier too. It alone, will take the oil drying time to a matter of hours, VS days or even weeks. Link to comment Share on other sites More sharing options...
karimb Posted September 15, 2017 Share Posted September 15, 2017 Try thinning the oils with Japan Drier too. It alone, will take the oil drying time to a matter of hours, VS days or even weeks. Or use Uschi van der rosten's Blitz Dry. Does the same. Whatever you can get your hands on! Well here we go again with another wingnut build! Excitement all around when i see them pop up and i am looking forward to your progress. Tony got bit by the bug as alot of us have so now the "pandemic" has moved to you. Great choice on the kit! I've got the late version that will be probably finished in "Nelly" so I'm looking forward to taking some notes! Karim Out2gtcha 1 Link to comment Share on other sites More sharing options...
1to1scale Posted September 16, 2017 Author Share Posted September 16, 2017 Well, I gave it a good try, I think I did ok, I was going for a dark finish, but I'm not sure if the wood grain looks realistic or not, I would appreciate any criticism. I am also not sure wether I should do a clear, yellow, or orange gloss over it. Shaka HI, Whitey, sandokan and 1 other 4 Link to comment Share on other sites More sharing options...
ZachP319 Posted September 16, 2017 Share Posted September 16, 2017 Looking really good. Can I recommend a coat of Tamiya clear orange. I find it adds a nice richness to dark wood grain finishes. And the glossy finish works for varnished wood. Me while not a worry for this build I only recently found that when going for a dark wood grain that yellow is a good base coat with burnt sienna oil paint for the wood grain. I am using this on my Dh9a and was pretty with the result. Zach Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 17, 2017 Share Posted September 17, 2017 I think it looks very convincing. Especially after the details are painted and picked out. You can mix it up, but as mentioned a fine mist of a 50/50 mix of Tamiya clear red/clear yellow brings a nice varnished richness to the look. Just go really light on the coats until you achieve the look you want. Link to comment Share on other sites More sharing options...
Martinnfb Posted September 17, 2017 Share Posted September 17, 2017 part no.11 looks ultra real Link to comment Share on other sites More sharing options...
1to1scale Posted September 17, 2017 Author Share Posted September 17, 2017 Every time I look at these parts I get excited to keep going on it. I'm going to try and clear them tonight. Link to comment Share on other sites More sharing options...
1to1scale Posted September 17, 2017 Author Share Posted September 17, 2017 I did a test on the underside of the floorboards, yellow and orange clear brushed on. I think Brian is right, orange is a better "varnish", of course...airbrushing a thinned mixture should leave a little more subtle effect. Gazzas, sandokan and Whitey 3 Link to comment Share on other sites More sharing options...
LSP_Ron Posted September 17, 2017 Share Posted September 17, 2017 Excellent wood work there. Very nicely done Link to comment Share on other sites More sharing options...
1to1scale Posted September 17, 2017 Author Share Posted September 17, 2017 It looks fantastic so far. I'm excited to see it in person at some point. Maybe sometime in the future, we can set up LSP DFW area lunch for the local members. Link to comment Share on other sites More sharing options...
