Hs-129 B3
  • Please log in to reply
77 replies to this topic
#1 Dukie99
Dukie99
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 259 posts
  • Gender:Male
Posted 09 September 2017 - 10:30 AM
Next and last of my builds needing a rescue from the SOD is GMF Hs-129 B3 resin kit. This is a build where my enthusiasm collided with my lack of skills as this is a very challenging kit, with bare bone instructions, so reference material is essential. I also had one badly casted wing around the wing root. I was able to improve its shape but it is not perfect and I tired on sanding and reshaping and on the perspective of having to do a lot of rescribing. I will do my best to rescue this one but it will not be as easy as the A-10 or the Little bird. Since there is more than 3 months left in this GB, I probably have enough time to finish it. This is where she stands:
Instructions:
Reference materials
2017090908121688-26EE785B-B959-44EB-9A2E
Box shot
2017090908121688-C09A2DA8-1B71-41F8-BF61
Cheers,
David
  • LSP_Kevin, Martinnfb, harvey and 6 others like this
#2 BradG
BradG
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,919 posts
  • Gender:Male
Posted 09 September 2017 - 02:03 PM
This kit definitely needs saving! It looks like you've done most of the major work, just perhaps the engine nacelles will be a bit of a challenge, but I reckon you will be surprised at how your skills have advanced and how easy the work on this might seem. I remember a few kits that I've test fitted and put back in the stash because it looked like insurmountable issues with my current skills, only to come back a few years later to the same kit and the issue wasn't a problem to deal with.
Can't wait to see this one finished.
  • harvey likes this
#3 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,825 posts
  • Gender:Male
Posted 09 September 2017 - 10:04 PM
Cool! I have this kit too, and look forward to seeing what you do with it.
Kev
#4 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,554 posts
  • Gender:Male
Posted 10 September 2017 - 01:16 AM
I'd like to see it, too.
:popcorn: :popcorn:
​We don't have social skills.  We build models.
#5 Thomas Lund
Thomas Lund
    Senior Member
  • LSP_Members
  • 1,482 posts
  • Gender:Male
Posted 12 September 2017 - 05:18 AM
Looks great and such an interesting aircraft - looking forward to following this.
I can see that you should have bought shares in the putty company before starting :-)
#6 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 22,096 posts
  • Gender:Male
Posted 12 September 2017 - 01:17 PM
I've got the same kit in my stash, and that Shatton barrel is a work of art in itself.
Keep going!
#7 imatt88
imatt88
    Senior Member
  • LSP_Members
  • 1,158 posts
  • Gender:Male
Posted 14 September 2017 - 12:22 PM
Duke, any progress?
I have the same kit, and it's on my shelf of Doom until I can muster the courage to finish it
Only THE greatest rock band in the world
#8 DeanKB
DeanKB
    Senior Member
  • LSP_Members
  • 4,423 posts
  • Gender:Not Telling
Posted 14 September 2017 - 04:13 PM
Mine didn't even make the shelf of doom.
I sold it very soon after buying it - at a loss.
An absolute piggy of a kit. No two surfaces lined up, fuselage was warped, the detail very soft indeed, the instructions very scant indeed.
My advice would be to sell now before ZM's kit comes out. At least, I think it's ZM?
  • DougN and Out2gtcha like this
Inactive Account.
#9 DougN
DougN
    Senior Member
  • LSP_Members
  • 2,241 posts
  • Gender:Male
Posted 14 September 2017 - 05:59 PM
Same experience here, probably the worst kit I've seen in 1/32.  Also add in oval tires, oval engines, mismatched surface details, etc - however the OP's kit does look a lot better than the one I was sent.
Good job getting your kit almost done David, looking forward to seeing it completed!
Edited by DougN, 14 September 2017 - 06:01 PM.
  • Out2gtcha likes this
#10 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 22,096 posts
  • Gender:Male
Posted 14 September 2017 - 06:35 PM
My B3 isnt that bad, but Im holding out for the ZM kit. Im also not selling my  GMF kit either.............unless someone wants to buy a B3 kit without the B3 parts, cause Im planning on grafting the GMF B3 canon, and breach parts onto the ZM kit.
#11 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,825 posts
  • Gender:Male
Posted 14 September 2017 - 09:18 PM
The one I have is a JRutman original, and while I haven't closely examined every part, it looks pretty good to me!
Kev
  • Rick Griewski and LSP_Typhoonattack like this
#12 Dukie99
Dukie99
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 259 posts
  • Gender:Male
Posted 16 September 2017 - 07:25 PM
Hi Guys,
Thanks for following this. I see that a lot of you bought this kit, it is indeed an exciting airframe, a fully automated 75mm cannon on a small twin engine. This one is clearly resisting. Most of the time is spent on this kit last week has consisted of puttying, sanding, priming to check for flaws and repeat and I have therefore little to show for it.
The good news is that I am getting very close to being done with the puttying and sanding. After these pictures I applied another coat of primer and I have three small areas that requires some more work and then I can start rescribing the areas where I lost the details.
The next step will then be to glue the tail and the elevators and the gun gondola. The fit of the gondola is just so so and one side is wrapped/ poorly casted and will need to be corrected. I also needed to find a way to attach the gun in the gondola once the model is finished. I expoxied a piece of styrene fitted in the gondola. The gun fits in a hole I made in the piece of styrene. The fit is pretty tight so you can take the gun on and off and once the gondola is glued at the right place on the fuselage it ensures that the gun mouth is at the right distance from the nose of the aircraft.
Thank you for following this build, hopefully more progress soon.
Cheers,
David
  • DougN, Out2gtcha, BradG and 2 others like this
#13 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,554 posts
  • Gender:Male
Posted 16 September 2017 - 10:19 PM
Keep it up, it's great progress.  I don't have the kit, but love the shape of the plane and it's armament.
#14 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 22,096 posts
  • Gender:Male
Posted 16 September 2017 - 11:57 PM
Looks great! That Shatton Bork canon IS the reason I bought the B3 kit. Its a little jewel. Keep going!
  • Zero77 likes this
#15 BradG
BradG
    Senior Member
  • LSP_Members
  • 2,919 posts
  • Gender:Male
Posted 17 September 2017 - 01:30 AM
I find there's something oddly satisfying about sanding a model kit to death.
  • Troy Molitor and LSP_Typhoonattack like this
