Starfighter Posted September 20, 2017 Share Posted September 20, 2017 Great job, Jim! Link to comment Share on other sites More sharing options...
brahman104 Posted September 20, 2017 Share Posted September 20, 2017 Interesting process there Jim, looking forward to seeing what happens next Craig Link to comment Share on other sites More sharing options...
Dan Paxton Posted September 21, 2017 Share Posted September 21, 2017 I love scratch builds....watching and learning sir! looking great so far. Cheers Dan Link to comment Share on other sites More sharing options...
Jim Barry Posted September 26, 2017 Author Share Posted September 26, 2017 Some 3D prints came back last week. First the revised wheel (Version 2). I like it a lot, but have already added more rim and will probably do the inside of the wheel with the brake and caliper in 3D so version 3 is in progress. The next pieces are the gear. Here in the youtube link below I am playing with it as it does "operate". I've decided against what I feel is just too much to actually build it all in a working configuration. I think the straw that broke the camel's back was getting it to stay extended and or retracted. Something somewhat unreal would probably have to nested in the bay to lock position and well, I just can't stomach it. https://youtu.be/pYu4BGnJyCs KUROK, sandokan, Derek B and 7 others 10 Link to comment Share on other sites More sharing options...
Dan Paxton Posted September 26, 2017 Share Posted September 26, 2017 Jim Barry 1 Link to comment Share on other sites More sharing options...
sandokan Posted September 27, 2017 Share Posted September 27, 2017 Gulp!!!!! Jim Barry 1 Link to comment Share on other sites More sharing options...
Jim Barry Posted October 7, 2017 Author Share Posted October 7, 2017 Not a lot going on lately. Kind of my off season. But time freed up today and having dusted off my 3D skills lately I got to work on the tail wheel. Here's a youtube vid of it Other 3D work done in the past week were doing the brakes and the propeller's interface with the driveshaft. Kind of ups my interest in doing the cockpit in 3D. Derek B 1 Link to comment Share on other sites More sharing options...
Jim Barry Posted October 8, 2017 Author Share Posted October 8, 2017 This morning I set out to finish the cowling master for vacuforming and just felt that I was working too hard to get it right and there was still so much more to do. Frustrated enough, I decided to try it in 3D. I ended up quite happy with results. Here I put all the parts together in one model to sort of test everything. We are living in the future for sure digitally dry-fitting our models. Too much! Starfighter, MikeMaben, red baron and 13 others 16 Link to comment Share on other sites More sharing options...
Jim Barry Posted October 9, 2017 Author Share Posted October 9, 2017 Back at it big time today. Finally a rainy day to just be inside. Started the cockpit and exceeded my expectations -- much more detail to go which should go well. I've been struggling how I'll encase the cockpit and provide a surface for the exterior paneling and thought I was headed to some crude build up, but then I learned to manipulate panels in 3D without much trouble and so made these here. Zank_Frappa, Uncarina, TorbenD and 7 others 10 Link to comment Share on other sites More sharing options...
Jim Barry Posted October 10, 2017 Author Share Posted October 10, 2017 (edited) I tried to build some interior framing in 3D and basically could not figure it out. I decided I would just do it manually after the parts printed but then it dawned on me (after a good break) I could make a copy of the panel and offset it just enough to make an interior wall, and then with some cubes as cutting tools I could then cut it up into a frame/lattice thing. As you can see in the video below(stepping though "redo", I did not do it this fast!) it went really well, but the real cheating part was there at the end when I just select "mirror and the work goes to the other side. Parametric modelling is a very good thing! Video Edited October 10, 2017 by Jim Barry Derek B, Rainer Hoffmann, HerculesPA_2 and 8 others 11 Link to comment Share on other sites More sharing options...
Jim Barry Posted October 11, 2017 Author Share Posted October 11, 2017 Added some more details to the pit tonight . Throttle pod with throttle, radio button, mixture lever and pitch controls set on a rail. Then on the port side "box" I put the tail wheel lock control lever, the dive recovery flap control, the knob for the aileron tab, knob for the rudder trim, the fresh air control (shaped just like what we see on today's airliners notably), the hydraulic pressure gauge just below that, and finally I cut the map case hole. I uploaded all this to my Shapeways work folders and it all passed their checks as long as I used the Frosted Ultra Detail (or Frosted Extreme). Price is good and though have more stuff to go, I think I'm in the clear here with thicknesses etc. This is definitely a lesson in "one step at a time". I recall looking at my Kinetic 1/24 Razorback P-47 kit I purchased as a possible engine source and thinking as I pulled out sprue after sprue after sprue, that there was "NO WAY" I could make all these parts and that I was crazy. I suppose it's actually happening.....one little part at a time. Thanks for stopping by. sandokan, Paul in Napier, HerculesPA_2 and 5 others 8 Link to comment Share on other sites More sharing options...
Jim Barry Posted October 12, 2017 Author Share Posted October 12, 2017 And though small, I made an extra effort to detail the stick which took well over an hour tonight. It's all about those triggers and red buttons, right? For those interested, the top button is bombs , the side button is rockets and the front trigger is for cannons (or early versions like mine were 4 Browning 50 cal mgs). Paul in Napier, Uncarina, Harold and 7 others 10 Link to comment Share on other sites More sharing options...
Uncarina Posted October 12, 2017 Share Posted October 12, 2017 Jim, This is amazing work! I'm learning a great deal, and love seeing the Bearcat take shape. Cheers, Tom Link to comment Share on other sites More sharing options...
Jim Barry Posted October 20, 2017 Author Share Posted October 20, 2017 Tom, Glad to hear your input and appreciation. Tonight is more project news and life news. The Bearcat has taken some back seat to work I've had to do on my studio hutte, like finally building a proper ceiling and not having insulation dangling down on me! Also I've had some bike races on weekends that have taken me away. And finally we got a puppy this week which is very time consuming too. Here is recent work in the pit adding the rubber boot for the stick. 11 little discs stacked just right on the stick's pattern. And here is little Ruby. 8 week old Golden Retriever. We lost our family dog last March at age 12 and our family was heartbroken. Ruby is really cheering us up. We love our dogs. Derek B, Scotsman, Doctorgaz and 8 others 11 Link to comment Share on other sites More sharing options...
Out2gtcha Posted October 20, 2017 Share Posted October 20, 2017 Great work!!!! This is really tremendous and the future of modeling IMHO williamj 1 Link to comment Share on other sites More sharing options...
