1to1scale Posted August 11, 2017 Share Posted August 11, 2017 I started working on a new quick build project tonight, while I'm waiting for a whole day I can paint the P-40, I am putting together my 109. This will be an out of the box project with only one aftermarket upgrade, I used a set resin barrels I picked up cheap at the last show. The kit parts were just too horrible to leave in. I will be painting on all the markings except the stencils. I assembled a bunch of sub assemblies in preperation for painting and dry fit and sanded the fuselage and cowl panels. I'm pretty happy how it all fit so far. Next step is to paint and assemble the cockpit so I can close up the fuselage. LSP_Kevin, Bomber_County, Intruder503 and 3 others 6 Link to comment Share on other sites More sharing options...
Daniel460 Posted August 11, 2017 Share Posted August 11, 2017 Great start! Just picked one of these up, will be keeping an eye on your build! Dan LSP_K2 1 Link to comment Share on other sites More sharing options...
Gazzas Posted August 11, 2017 Share Posted August 11, 2017 :popcorn: Link to comment Share on other sites More sharing options...
1to1scale Posted August 11, 2017 Author Share Posted August 11, 2017 Great start! Just picked one of these up, will be keeping an eye on your build! Dan You will like it. The fit is really very good so far. I did have to do a bit of sanding with a coarse sanding stick on the framework under the cowl panels, while the fit is not terrible, a little sanding really help line everything up well. It seems to be an easy kit so far, it has some weird panel joins in odd places. I suppose they are like that so that filling and sanding is easier, you would not have to re-scribe any panel lines. This kit has no rivet detail to speak of, so it would be an excellent kit to try rivet tools the first time, which I may do. Daniel460 and Mark M 2 Link to comment Share on other sites More sharing options...
1to1scale Posted August 13, 2017 Author Share Posted August 13, 2017 While I was priming the P-40, I also did a base coat of dark gray on the cockpit, hopefully I can get this done in the next couple of days and close up the fuselage. I did use a lighter gray than I should have, but I will weather it with a black wash, so it will darken up a bit. MikeMaben, tomv87 and MikeC 3 Link to comment Share on other sites More sharing options...
1to1scale Posted September 14, 2017 Author Share Posted September 14, 2017 I have to admit that I forgot to take more pictures while I was working on this. Here is the finished cockpit, basically 100% OOB except for the belts. I finished the cockpit and closed up the fuselage a week ago. The only AM that I used on the cockpit was I shaved the belts on the back wall up to the buckles in the middle and added $1 belts from there down, along with some PE buckles at the bottom. Right after I took these pictures I closed up the fuselage, and added all the wings, flaps, ailerons, and every tail piece. Unfortunately no pictures, as it completely escaped my mind. Last night I primed the whole model in Stynilrez While Primer, its also the base for the Montex markings. If I get a chance I will try to spray more this weekend. 109, MikeC, Seversky and 6 others 9 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 14, 2017 Share Posted September 14, 2017 That cockpit is superb! Kev Link to comment Share on other sites More sharing options...
Mark M Posted September 14, 2017 Share Posted September 14, 2017 me like!! Link to comment Share on other sites More sharing options...
1to1scale Posted September 16, 2017 Author Share Posted September 16, 2017 Update pictures, put the masks on tonight. Gazzas, tomv87, MikeC and 2 others 5 Link to comment Share on other sites More sharing options...
Gerhard Posted September 16, 2017 Share Posted September 16, 2017 I like, looks like a decent kit. What is the kit number please? LSP_K2 1 Link to comment Share on other sites More sharing options...
1to1scale Posted September 16, 2017 Author Share Posted September 16, 2017 I like, looks like a decent kit. What is the kit number please? It's the Revell Germany BF-109G6. Link to comment Share on other sites More sharing options...
1to1scale Posted September 16, 2017 Author Share Posted September 16, 2017 This is going to end up being a very late war repainted scheme mostly brown/green with tan mottle and the original 76 undersides. Gazzas and LSP_K2 2 Link to comment Share on other sites More sharing options...
Gazzas Posted September 16, 2017 Share Posted September 16, 2017 Looks sweet! I'm curious about adding the markings before camouflage. Is this for location later on? Thanks, Gaz Link to comment Share on other sites More sharing options...
1to1scale Posted September 16, 2017 Author Share Posted September 16, 2017 Those are vinyl masks, the white is the base, then the color is sprayed over the top. Link to comment Share on other sites More sharing options...
1to1scale Posted September 18, 2017 Author Share Posted September 18, 2017 (edited) Put down a coat of RLM76 tonight, more colors to follow, 5 more to be exact. You can see most of them hanging out in the background. Edited September 18, 2017 by 1to1scale JMason5067, tomv87, Kendzior and 4 others 7 Link to comment Share on other sites More sharing options...
