F-23A in 1/48
F-23A YF-23 hobbyboss 1/48
  • Please log in to reply
76 replies to this topic
#16 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 853 posts
  • Gender:Male
Posted 05 December 2017 - 06:25 AM
The upper half of the fuselage went through quite a bit of a change. The engine nacelles are angled according to the central axis; the nozzle area is entirely extended, while the nozzles only are shrinked forwards; the centerline humpback behind the nose section (above the weapons bays) is split for a proper shaper; the wing roots are also prepped for a better fit with the almost twice thinned wings. The curved tails where on both sides of the nozzles are entirely reshaped. And that`s just about it with the rough cutting and gluing.
This is how it looked before:
and after the edits:
  • Uncarina, Shawn M and MARU5137 like this
#17 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 5,740 posts
  • Gender:Male
Posted 05 December 2017 - 02:34 PM
wow, you are fearless thats for sure.
Any trademark articulation planned for this one?
  • MARU5137 and F`s are my favs like this
I dont suffer from AMS, I revell in it..get it...Revell
#18 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 05 December 2017 - 04:50 PM
Hehe, 10x Shawn! Yep - Just the landing gears wil move up and down for 2 modes again - in flight and parked. And i also plan to make the ginormous rudders moveable, i mean i wish to manage to make them moveable, cause the space around the anchor points is so little that i doubt that the rotation will be stable. But i`ll try it for sure. ;) Even a slight change in the angle of the rudders shifts the overall appearance.
  • Shawn M and MARU5137 like this
#19 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 5,740 posts
  • Gender:Male
Posted 05 December 2017 - 05:09 PM
very cool
  • allthumbs and F`s are my favs like this
#20 Chek
Chek
    Senior Member
  • LSP_Members
  • 1,140 posts
  • Gender:Male
Posted 05 December 2017 - 09:13 PM
Very intriguing re-design work, Milan. Is there any reason for the converging exhausts (apart from looks)?
And what happens at the air dam you've created by bringing them together? Or is the centre body going to be brought up level with the tops of the exhaust tunnels? So many questions - I must learn some patience....
Edited by Chek, 05 December 2017 - 09:15 PM.
  • F`s are my favs likes this
#21 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 06 December 2017 - 05:05 PM
The questions are never enough. :))) Well, for this conversion i choos to stick to the unclassified technical drawings published on yf.23.net, for example. According to this scheme, there is an angle of 1.5 degrees according to the centerline, per engine. I could only speculate what the real reasons are, but undoubtly they are related to the IR signature reduction. It`s better to concentrate the exhaust paths in a smaller area(path) behind the plane, rather than dispersing the 2 exhaust paths in opposite directions. The temperature is already reduced by the IR absorbing tiles and the other tools for IR reduction.
And secondly, the aerodynamics. The entire nacelles should not be perfectly paralleled to each other like on the prototype version. So the ends of the nacelles (which are the nozzles) are the natural continuations of the nacelles, and are respectively slightly angled to each other.
At least these are my thoughts. I`m not an expert in this kind of area, but i think i know the basics. :P
Edited by F`s are my favs, 06 December 2017 - 05:07 PM.
  • Chek and MARU5137 like this
#22 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 5,740 posts
  • Gender:Male
Posted 06 December 2017 - 06:52 PM
the angle of the nozzles probably helps in engine out situations as well
#23 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 06 December 2017 - 08:38 PM
With the rudders extended, and also the fairings are trimmed on both sides of the nozzles (where are located the anchor points of the rudders).
  • Martinnfb, Shawn M, Peterpools and 1 other like this
#24 MARU5137
MARU5137
    Senior Member
  • LSP_Members
  • 19,493 posts
  • Gender:Not Telling
Posted 06 December 2017 - 08:48 PM
Milan,
SUPER work.
Looks very good.
:clap2:
Res Non Verba .
La calma è la virtù dei forti !
Potius Mori quam foedari.
#25 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 5,740 posts
  • Gender:Male
Posted 07 December 2017 - 02:00 PM
wow, the only time my kits look like that is if I need to cut 'em for the bin
brave man, I admire your skills
#26 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 07 December 2017 - 04:40 PM
My first time doing something like that... and honestly i`m kinda affraid of what will happen too :))) But i want to make F-23A! :)
  • Shawn M likes this
#27 eoyguy
eoyguy
    Senior Member
  • LSP_Members
  • 747 posts
  • Gender:Male
Posted 07 December 2017 - 04:44 PM
Damn. I think I would have just slapped on some decals for an active duty plane and called it good.
You talkin' to me? Well I'm the only one here.
Just because we can't obtain perfection doesn't mean that we shouldn't strive for improvement.
#28 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 07 December 2017 - 04:59 PM
Just take a look at the underside (sry for the low-quality, it`s nighttime)
These are actually the 2 halves testfitted...
@ eoyguy: If all goes well, the final vision will be of a well worn Raptor - the exact same camo and colors. I have some great collection of unused decals, so i`m gonna use them too.
  • Shawn M and Gazzas like this
#29 jenshb
jenshb
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 257 posts
  • Gender:Male
Posted 07 December 2017 - 07:15 PM
I was just going to convert the Hobby Boss YF-23 into a YF-23, but this is plastic butchery on a grand scale.  Following with interest.
Jens
#30 F`s are my favs
F`s are my favs
    Senior Member
  • LSP_Members
  • 853 posts
  • Gender:Male
Posted 07 December 2017 - 07:29 PM
Jens, hi and thanks! Btw what means to convert the same thing into the same thing?! :))) U mean the edits of the numerours curves on the top side of the intakes? Cause i know that they are wrong on the YF-23 kit itself. Otherwise, the oob kit is pretty much a YF-23 version....
Also tagged with one or more of these keywords: F-23A, YF-23, hobbyboss, 1/48
