How to make propellers out of paper...
  • Please log in to reply
40 replies to this topic
#1 apauling
apauling
    Member
  • LSP_Members
  • PipPip
  • 18 posts
  • Gender:Male
Posted 07 May 2017 - 08:18 PM
A Paper Propeller
Back in 2009 when Wingnutwings released their first kits I was inspired to build their LVG C.VI kit. At the time I puzzled how to re-create the multi-colored laminated wood propeller. Keeping the lamination lines straight when viewed from the side makes painting them very difficult. Eventually I decided to laminate different colored sheets of wood together and carve my own prop. This worked at recreating the lamination pattern but I was never really satisfied with this method. When viewed up close the grain pattern of the wood looks out of scale and creating the very thin pieces of wood needed involves a lot of work with the planer. (a tool that a lot of modelers probably don’t have). Eight years later I have decided to try again for my build of the Wingnutwings Roland D.VI.
Reasoning that a sheet of paper is like a very thin piece of veneer I decided to make my laminations out of colored paper.1paper.jpg
I got some brown and tan colored paper at the craft store and cut it into 1” by 4” strips. The paper I used took three strips to build up the thickness of one of the seven layers. 21 strips stacked up makes the full thickness of the prop in 1/32nd scale.
Next I ran a bead of super glue down the center of each strip and quickly stacked them up on the pad of a wood clamp. I tightened the clamp until the layers were nicely squished together and let it cure overnight. (there is a small fire hazard with super glue and organic matter you might want to leave the clamp outside while the glue cures). 2laminated.jpg
I traced the kit propeller onto the top of the paper stack and drilled a hole for the propeller shaft. 3traced.jpg
Next I cut along the outline with a scroll saw.http:4cutout.jpg
Next I carved the taper into the blank. The stack of paper will carve a lot like wood so cut from the hub toward the tip. Think about the pressure of the tool pushing the layers together as you cut.5tapered.jpg
After you have the taper established, carve the twist into the blades. If the paper starts to shred, switch blades or use a little thin super glue to solidify the area you are working on. The paper can be filed and sanded like wood but pay attention to the grain so that you don’t pull the laminations apart or tear out chunks of paper between the glue lines.6twisted.jpg
I sealed the prop with Tamiya clear tinted with a little clear orange.7_Finis.jpg
top: a basswood prop I made back in 2009                                             bottom: a new paper propeller
  • 109, thierry laurent, Rick Griewski and 33 others like this
#2 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 24,492 posts
  • Gender:Male
Posted 07 May 2017 - 08:35 PM
Awesome looking prop
Peter
  • Martinnfb, harvey and CANicoll like this
#3 dora9
dora9
    Senior Member
  • LSP_Members
  • 545 posts
  • Gender:Male
Posted 07 May 2017 - 08:48 PM
Nicely done! Love the way you did it!
  • Martinnfb and harvey like this
Andre Dorion
#4 Jack
Jack
    Senior Member
  • LSP_Members
  • 6,414 posts
  • Gender:Male
Posted 07 May 2017 - 09:03 PM
....I ......LIKE IT!!!
Almost the same way the real thing got made.....
everyone in the circuit switch off your radios....now switch 'em back on again......
#5 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 9,866 posts
  • Gender:Male
Posted 07 May 2017 - 09:16 PM
Absolutely phenomenal work! Thank you for sharing.
Cheers
M.
  • Jack, harvey, Girlscanplay2 and 1 other like this
In progress:   D-13 ; Ta-152V7 ; Mig-29 ; EMIL ; P-39 Аэрокобра ; Avia S-199 ; K-14 what if
Done:            F-8 F-8 Wurger Party ; D-9 ; D-15; Ta-152E ; P-40E
#6 Jolly Roger
Jolly Roger
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 236 posts
  • Gender:Male
Posted 07 May 2017 - 09:48 PM
That is amazing, I also tried the wood method on a 1/48 D.VIII and it came out okay, but this method looks much more like the real deal.  I will try this one on my next WWI model.
  • harvey likes this
Roger <(^^,)>
#7 Rob Owens
Rob Owens
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 247 posts
  • Gender:Male
Posted 07 May 2017 - 10:06 PM
Wow! Scale laminations!! I'll wager it'll look even more impressive when mounted on the model...
  • harvey and MARU5137 like this
#8 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,790 posts
  • Gender:Male
Posted 07 May 2017 - 10:43 PM
I saw this on Facebook, and wondered how I could share it here. Thanks for posting it, Paul. It really is amazing stuff.
Kev
  • williamj, Big Texan and harvey like this
#9 AVbob
AVbob
    Member
  • LSP_Members
  • PipPip
  • 28 posts
  • Gender:Male
Posted 07 May 2017 - 11:05 PM
My first post since joining LSP..........
Super cool way to fab a laminated propeller. It's the best looking prop I've seen in any scale.  I'm heading to the craft store tomorrow morning for paper.
Bob
  • Martinnfb, harvey, MARU5137 and 2 others like this
#10 Girlscanplay2
Girlscanplay2
    Senior Member
  • LSP_Members
  • 1,536 posts
  • Gender:Female
Posted 08 May 2017 - 12:50 AM
Beautiful!!! :thumbsup:  :punk:
Teresa  :)
#11 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 22,052 posts
  • Gender:Male
Posted 08 May 2017 - 01:36 AM
Wow, I think I really need to try this! It looks wonderful
  • Martinnfb, CANicoll and Joel_W like this
#12 Paul Budzik
Paul Budzik
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 332 posts
  • Gender:Male
Posted 08 May 2017 - 02:54 AM
Wonderful idea!  I love to see modelers use materials other than plastic and paper is a great material. :goodjob:
Paul
  • Martinnfb, MARU5137 and Joel_W like this
#13 Gazzas
Gazzas
    Senior Member
  • LSP_Members
  • 2,532 posts
  • Gender:Male
Posted 08 May 2017 - 05:44 AM
Great job!  Thank you for sharing.
​We don't have social skills.  We build models.
#14 sandokan
sandokan
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 276 posts
  • Gender:Male
Posted 08 May 2017 - 09:43 AM
Wow! Fantastic! :m0152:
#15 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • 8,263 posts
  • Gender:Male
Posted 08 May 2017 - 09:57 AM
Smart work.  Nice problem-solving.  Thinking outside of the box to solve a problem is rewarding.  Good show.
Sincerely,
Mark
