karimb Posted February 20, 2017 Share Posted February 20, 2017 (edited) Hey gang! As promised here is the wingnut wings AMC DH.2 that i photographed back when i took the photoshoot session of the DFW CV... No this build was really interesting. The size of the DH.2 is relatively really small compared to the other 1/32nd wwi aircraft i have built before. The cockpit nacelle is exactly the size of a pack of cigarettes from nose to prop! a quick model factoid: WnW AMC DH.2 HGW superset Vector resin gnome monosoupape engine Aviattic linen (very limited use in the cockpit) Bob's buckles and eyelets throughout Silhouette plotter for all the masks Tamiya paints W&N oil paints AK interactive for the weathering Florymodels clay washes UVDR blitzdry for the oil paints Gaspatch two ended turnbuckles various sundries Windsock datafile #48 DH2 rigging guide on Bob's website The kit in itself is a jewel. Every part clicks in place and stays there even when dry fitting! I never stop to be amazed by how wonderful wingnut wings's kits are. while going through the windsock datafile i have found a couple of pictures that show the linen side of the dh2 with the linen removed exposing the fuselage structure and the interior... i decided then and there to embark on this adventure. The fuselage skeleton doesnt need alot of modification to get the correct framing that you see in the reference photos, one area that needs modification is the aft end of the framing where you need to remove material in order to have the correct two 'triangles' that wingnut wings have molded as one piece for engineering and construction purposes. I also had to scratch an "imaginary" pulley in order to route the rudder wires out of the bare fuselage framing on the left side just to get them to align correctly same as the right side. I have used on the inside right side of the fuselage Aviattic linen although it doesnt really show as this area is quite cramped. The wicker seat has been completely painted with various oil colours. a first for me. I also added wiring that were visible on the windsock datafile references. I wanted a really beat up little dh2 so i went to town on the kit with the weathering. the chipping was done with Ak's worn effects and heavy chipping. Multiple oil filters were used on the fuselage and wings. I used my silhouette plotter to cut 1 and 1.5mm strips in oramask810 vinyl in order to mask the ribs of the wings and i have used the windsock datafile as a template for the positioning of the vinyl on the wings. that took quite a long while but still enjoyable! The engine from vector resin is nice too (a step up from the kit one) but lack much more detail than the Taurus one (which i am leaving for my second dh2 build). i received the engine with some of the rocker arms damaged so i had to scratchbuild those too. The Vector kit comes with very vague instructions but its not very hard to figure out the build sequence, i built the kit engine in parallel to get a sense of where everything went... I was planning on using the gaspatch armament but decided against it at the end and left it for another build. I also modified the gear and added two small L shaped retaining wires made from brass that i saw in a couple of reference photos and i think it adds a nice little touch.I first rigged the wings then the box tail separately then brought those together, then did the control rigging. I had to wiggle between the wnw rigging diagram (that got me crosseyed at the end), Bob's buckles's rigging guide and reference photos. The rigging was tedious but nothing someone can't achieve with patience and perseverance. I finished the rigging over a couple of days, walking away from the kit every time i felt i was getting tired and fed up... let me tell you, it keeps calling you back and there is a great amount of satisfaction every time you see more and more rigging take shape! One thing i have done was to modify the photoetch '5' buckle connection for the rudder. I scratchbuilt a similar shape from sheet styrene and then drilled 5 holes big enough to fit 5 small cut pieces of albion brass tubing. i slid 5 two ended gaspatch turnbuckles on top of those rods and then crumpled them flat with a flat nosed plier and cut off the excess. This way you end up with a 3 dimensional unit where the actual turnbuckles rotate and move so you can keep all the control rigging taught without getting one to slack out. same for the other side. looks much better. I hope i explained it right, you can see it in some of the photos and hopefully that will clarify the process. All the markings have been painted on except for the numbers which were the kit's markings. They were extremely thin and conformed beautifully! I might have forgotten to tell about some little details here and there so please do ask if you have any questions regarding any aspect of the build.... A thoroughly enjoyable build! As always gang, thanks for looking in, Stay safe and happy modeling! Karim PS: i forgot to mention the breather tube on the auxiliary fuel tank on the top of the wing is brass tubing bent to shape! Edited February 20, 2017 by karimb Uncarina, Dany Boy, Whitey and 25 others 28 Link to comment Share on other sites More sharing options...
karimb Posted February 20, 2017 Author Share Posted February 20, 2017 Part II Thanks again for checking in! BloorwestSiR, F`s are my favs, red baron and 33 others 36 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted February 20, 2017 Share Posted February 20, 2017 How do you keep churning out these fantastic models, Karim? This one's just as amazing as your last one, and brilliantly executed too. May I publish it on the website? Kev mpk 1 Link to comment Share on other sites More sharing options...
Guest Posted February 20, 2017 Share Posted February 20, 2017 My god man, beautiful !! Love the title and the model.........Harv Link to comment Share on other sites More sharing options...
HL-10 Posted February 20, 2017 Share Posted February 20, 2017 That is an impressive looking model! Great modelling. mpk 1 Link to comment Share on other sites More sharing options...
dodgem37 Posted February 20, 2017 Share Posted February 20, 2017 Damn, you're good. Great show! Sincerely, Mark mpk 1 Link to comment Share on other sites More sharing options...
Dukie99 Posted February 20, 2017 Share Posted February 20, 2017 Amazing build. I love the weathering, brilliant. Once you have rigged this one rigging any other WWI airframe must feel like a walk in the park. I have several wingnut wings in my stash but not this one, I thought it would drive me insane... Cheers, David mpk 1 Link to comment Share on other sites More sharing options...
Bill_S Posted February 20, 2017 Share Posted February 20, 2017 Simply stunning, Karim! How about a little tutorial on how you did those wings? mpk 1 Link to comment Share on other sites More sharing options...
phoenix 54 Posted February 20, 2017 Share Posted February 20, 2017 Karim, superb build....................now, can someone please pass me the knitting needles and some wool? Paul mpk 1 Link to comment Share on other sites More sharing options...
Hubert Boillot Posted February 20, 2017 Share Posted February 20, 2017 Another extremely well done kit! You really put your spare time in Doha to good use, Karim ! Hubert mpk 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted February 20, 2017 Share Posted February 20, 2017 Incredible, your builds and photography gets better and better! mpk 1 Link to comment Share on other sites More sharing options...
williamj Posted February 20, 2017 Share Posted February 20, 2017 Top Shelf Karim. Just beautiful. mpk 1 Link to comment Share on other sites More sharing options...
Joe66 Posted February 20, 2017 Share Posted February 20, 2017 Really outstanding ! Funny but to me, most WWI British schemes are boring and drab, but with your beautiful painting techniques, you have really brought it to life ! -Joe mpk, Vandy 1 VX 4 and williamj 3 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted February 21, 2017 Share Posted February 21, 2017 An absolutely stunning model there Karim! I really like the look of the wood finish you did in the cockpit. Carl mpk 1 Link to comment Share on other sites More sharing options...
Jan_G Posted February 21, 2017 Share Posted February 21, 2017 Well Karim, that is a superb build with perfect finish! I like your painting and weathering techniques and with all these nice photos it is really nice build reference for us thanks for sharing! jan mpk 1 Link to comment Share on other sites More sharing options...
