WNW Fokker DVII F / Relinked photos and updated ones!
50 replies to this topic
#1 karimb
karimb
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,048 posts
  • Gender:Male
Posted 05 December 2016 - 11:12 PM
Hey everyone,
in the ongoing process of relinking the photos of my past threads, i have updated this one with some of the old and a complete new set of photos i have taken not long ago using the DSLR and the lightbox!
Below the original thread.
Karim
Hey guys!
For some reason when i had finished writing the 'post new topic' it all disappeared so here we go again!
I present to you wingnut wings's Fokker DVII/F finished in Gotthard Sachsenberg's beautiful yellowbird scheme...
This is only my second great war build after the Albatros and im just loving every moment of it, so much so, that the wingnut wings stash has grown to 18 kits since september. I just find the aircraft, era, colorful schemes, and men that flew them so interesting...
The research involved and the reading are also a big point of interest to me. I'll give you a quick resume on the gentleman first:
Gotthard Sachsenberg initially started out as a sea cadet in 1913, and when the war broke out he got transferred and assigned as an observer on two seater with MFA2. He then underwent pilot training and started flying Eindeckers with the same division. When MFA2 got changed to Marine feld jasta 1 (MFJ1) Sachsenberg became commander of the unit. He scored his first aerial victory in May 1917, and went on to score another 30 victories until the armistice. He survived both world war one and world war two and died in 1961 ( summary drawn up from my sources which are hopefully correct )
Well, now that we have introduced the pilot let's introduce the kit.
Being only my second wingnut wings kit after the Albatros, i found this kit to be a bit trickier to build. Tolerances are much smaller for things to fit correctly in place and the internal flight control rigging is quite challenging. Another aspect of the build that was quite challenging was that this scheme required alot of decaling, and i used multiple producers of decals for different areas and that meant that i each type reacted differently to different setting solutions in order to conform well. To be honest, there isn't any real catches on this kit that an average modeler cannot overcome, you just need patience...
I completely plumbed the engine following reference pictures i had at hand. I added all the wiring in the cockpit for the instruments and the gun synchros. I made the spark plugs by sliding 0.3 wiring into 0.5 OD albion tubing and cut them to length and put them where the spark plugs should be. I also tried something new for the ignition wiring. I noticed in all the photos that the end of the ignition wiring had a sort of terminal that looks flat and sits on top of the spark plug. To do this i braided two 0.1 wires to give it the braided look and then inserted that into a short cut of brass tubing. I then used flat smooth long nose pliers to flatten the end of the terminal and drilled a 0.3 whole into the flat part of the brass, et voila! looks just like the references, and it sits well in place on the spark plug. for the ignition harness tube i used brass tubing that i cross drilled and painted in a salmon color. The magnetos also got their share of wiring which was bundled and inserted into the tube. I added the front plumbing and also a couple of pipes. The connectors i used are actually electrical wire sheathing. I also added to the engine frame some sort of canister that connects to the engine and then has a tube that goes back towards the firewall (I couldnt manage even with all the digging to find out what it was so if anybody knows please let me know!). The engine case got the salt chipping treatment on top of gray that had been polished with UVDR chrome pigments (a first for me and i must say i am very happy with the UVDR metallic pigments!). Trying to get the yellow paint not to look uniform was also a challenge that was overcome with preshading, postshading and mottling different yellows during the painting process (instructions call out for flat yellow but i didnt really like how it looked so i made my own mix by adding a couple of drops of orange to the mix). For the 4 color lozenges i use Aviattic products and i must say they are wonderful. I use their product line every chance i get... I also selectively used HGW's superset for the build and Gaspatch's resin LMG 08/15 Spandaus. Those are little gems, and to be honest i still havent figured out if they are cast or 3d printed but they are so darn clean and sharp i would recommend you try them out...
Well that pretty much what i can remember, i am sorry if i have forgotten any little details, please do ask me if you have any specific questions!
A quick factoid of the build:
HGW Superset for the Fokker DVII
Gaspatch Spandaus
Gaspacth turnbuckles 1/32
Bob's buckles ( eyelets and tubing). Thanks Bob!
Aviattic 4 color lozenges for the wings. Thanks Richard!
Wingnut wings Fokker DVII/F kit
AK chipping fluid
Tamiya acrylics for the painting
AK clearcoat for the decaling, ultra matt coat for the interior
Sating coat is a mix of tamiya flat clear and clear thinned with mr levelling thinner
Metallics by Mr metal color and metallic pigments by Uschi VanDerRosten
Oils are a mix of WN and Abteilung for the filters, the woodwork and the prop
AK pinwashes and weathering effects for the engine
Florymodels clay wash
Microsol, Microset and Walther's Solvaset were used
Ez Line and modelkasten rigging line
AK pigments
References were Squadron/signal publications Fokker DVII in action, the wnw manual (a source in itself) and the internet
If i am not mistaken this should be the majority of the products used. Again, since my memory isn't what it used to be when i was 20 years old, please do ask me if you have any specific questions regarding any of the products or parts of the build...
I hope you guys like her!
She's sitting in my display cabinet, right in the middle, and i have just started putting together my references for a DFW CV build that should start tomorrow
As always comments and critiques are always welcome
Gang, until next time,
Stay safe and happy modeling!
your buddy,
Karim!
NB: This thread is going to be picture heavy. you have been warned!
Below two photos of the cockpit during work in progress!
https://photos.smugm...ender 45-XL.jpg
https://photos.smugm...ender 46-XL.jpg
Edited by karimb, 30 August 2017 - 01:58 PM.
  • harvey, Uncarina, Peterpools and 2 others like this
OUT OF THE HANGAR:  WnW Camel F.1 (RFI) WnW AEG G.IV White.VII (RFI/WIPWnW Fokker E.II (RFI)  Academy F/A18-D (RFI)  WnW Albatros B.II (RFI) WnW Fokker DVII (RFI) WnW AMC DH.2 (RFI) Tamiya F4U-1 Arkansas Traveler (RFI) WnW Roland D.VIb (RFI)
WIP: Gaboon Viper
#2 harvey
harvey
    Senior Member
  • LSP_Members
  • 18,581 posts
  • Gender:Male
Posted 05 December 2016 - 11:28 PM
Geezzz buddy I thought you were GOING to start this!! Love it. The color is fantastic.....Harv
  • Martinnfb and Peterpools like this
There's a fine line between cuddling and holding someone down so they can't get away
working on:  Tamiya F4U-2 Night Fighter
Trump P-38M BACK ON BENCH FINISHED!!!
#3 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 8,976 posts
  • Gender:Male
Posted 05 December 2016 - 11:32 PM
Absolutely fantastic Karim, I like the dirt and grime. Just lovely. Thanks for sharing.
Cheers
Martin
  • harvey and Peterpools like this
In progress:   D-13 ; Ta-152V7 ; Mig-29 ; EMIL ; P-39 Аэрокобра ; Avia S-199 ; K-14 what if
Done:            F-8 F-8 Wurger Party ; D-9 ; D-15; Ta-152E ; P-40E
#4 karimb
karimb
    Senior Member
  • LSP_Members
  • 2,048 posts
  • Gender:Male
Posted 05 December 2016 - 11:33 PM
Harv my friend... thanks for such kind comments!
I have noticed when it comes to this scheme it's either you love it or completely the other end of the spectrum. i am glad you share my opinion that the yellow is quite catchy!
WIP: Gaboon Viper
#5 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 25,451 posts
  • Gender:Male
Posted 05 December 2016 - 11:34 PM
Looks great. I have two of the WNW D.VII's to get at one of these days, and I hope mine turn out as nice as this.
  • Martinnfb, harvey and Peterpools like this
Kevin
I was going to procrastinate tonight, but decided to wait.
In Progress:
#6 karimb
karimb
    Senior Member
  • LSP_Members
  • 2,048 posts
  • Gender:Male
Posted 05 December 2016 - 11:35 PM
Cheers
Martin
Marting buddy!
Thanks for leaving a word. i am glad you like it...quite a challenging build but very rewarding!
  • Martinnfb and harvey like this
WIP: Gaboon Viper
#7 Jolly Roger
Jolly Roger
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 212 posts
  • Gender:Male
Posted 05 December 2016 - 11:36 PM
Jaw dropping work...
How did you paint that exhaust, very realistic.
I think this is the finest WNW Fokker D.VII I have ever seen.
Roger <(^^,)>
#8 r0t0rdr1ver
r0t0rdr1ver
    Senior Member
  • LSP_Members
  • 819 posts
  • Gender:Male
Posted 06 December 2016 - 12:17 AM
Outstanding work Karim!
#9 D Bellis
D Bellis
    Senior Member
  • LSP_Members
  • 3,869 posts
  • Gender:Male
Posted 06 December 2016 - 03:44 AM
Absolutely gorgeous!
D
You can lead a person to information, but you can't make them think.
"Emotion is the enemy of reason." - Immanuel Kant
#10 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,829 posts
Posted 06 December 2016 - 06:24 AM
Your builds get better and better. I can't believe it! And good photographs, too (which makes it possible for us to appreciate it even more)!
Edited by Shaka HI, 06 December 2016 - 06:24 AM.
#11 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 06 December 2016 - 06:37 AM
An utterly fantastic build, Karim! You're fast becoming one of my favourite modellers, and this build continues your superb output. May I publish it on the website?
Kev
#12 Zero77
Zero77
    Senior Member
  • LSP_Members
  • 5,741 posts
  • Gender:Male
Posted 06 December 2016 - 01:53 PM
Oh my God !!!! That's crazy !
I cant see anything that is not damn good. But those exhaust pipes are totally amazing !!!!
I think it's your most impressive model so far.
And you work so fast ! It seems to me that you finished the Albatros only a few days ago !
Following the big Photobucket rip-off attempt, all my pictures on the forum cannot display anymore. I try to reupload the RFI pictures, but i'm not sure i'd have enough time and energy to reupload the pictures of the WIP threads. If you're interested in a specific subject and want me to reupload some pictures, just let me know. :)
Finished : F-16C Barak, F-4J VMF333, Czech Mig-19PM, Bell X-1, Russian Su-25 in Chechnya, Ta152H-1, Czech Avia S.199, Heinkel He162, Swiss AF Bf109G-6, Regia Aeronautica Bf109G-6, P-47D "Slick Chick", RFC Sopwith Pup, A5M2 Claude, Schneider Cup 1926 Macchi M.39, German F-104G JaboG34, Curtiss P-6E, Curtiss P-36A USAAC, Piper SuperCub floatplane (PA-18-150), Russian built Nieuport 11, Albatros D.Va Seefrontstaffel 1, Bf109G-12 (two-seater trainer), Texas ANG F-86D,  Post-war Hawker Tempest Mk.V
#13 MostlyRacers
MostlyRacers
    Senior Member
  • LSP_Members
  • 5,035 posts
  • Gender:Male
Posted 06 December 2016 - 06:00 PM
:wow:
Absolutely gorgeous Karim ! Everything in this build is top notch. And the scheme is so eye catching
:bow: :bow: :bow:
Hubert
#14 Wolf Buddee
Wolf Buddee
    Senior Member
  • LSP_Members
  • 2,253 posts
  • Gender:Male
Posted 06 December 2016 - 08:48 PM
Beautifully built and weathered Karim. I absolutely love these WnWs kits and your Fokker DVII is superbly done!
While I understand that this is a Fokker built aircraft I always thought the DVII F was BMW powered?
Cheers,
Wolf
#15 BiggTim
BiggTim
    Senior Member
  • LSP_Members
  • 2,477 posts
  • Gender:Male
Posted 06 December 2016 - 09:42 PM
Karimb,
In a forum where the best modelers in the world are well represented, you are, without a doubt, second to none. The quality of this, and every one of your builds, is simply mind-blowing and truly inspiring!!
Tim
In progress: 1/32 Trumpy P-38L (very slowly), 1/32 Trumpy Me-109E-4, and some others.....
On deck: Can't choose between 190D-13 "Yellow 10", Hase P-47D, or Tamiya Corsair....
Completed in 2015: Hasegawa F6F-3 Hellcat, Hase Me-163 Jagerfaust , 1/16 Fokker DVII Scratchbuilt Wooden Skeleton
Reply to this topic
