Zero77 Posted October 29, 2016 Share Posted October 29, 2016 (edited) Hi, I finally finished my Kittyhawk F-86D, painted with Texas ANG markings. The build is OOB, with the only addition being the fabric seatbelts from Eduard/HGW. I started it in August during my hollydays, but i only cut, cleaned and glued small asemblies at this time as i was not home. I started painting and assembling it only in late august. It was not so long as i build another small model since then, so it took me about 2 months in all, but i did not worked on it every days. It was first primed in grey, sanded smooth and coated with Alclad gloss black. Then i polished it a lot with micromesh 12000 grit and applied a mix of AK chrome and polished aluminium. Compared with the Alclad hi shine finishes, the AK are a bit less reflective, but still quite good, though they are way stronger to adhesive tape and various manipulations. I used the stencils and emblems from the box, but most of the markings (ANG markings, stars-n-bars and also the walking area border) were painted with masks as i found the large decals from the box quite tricky to use and the national insigna blue was too light. Anyway, it's always better to paint on a NMF model as you avoid any carrier film, difficult to blend in when you cannot use any varnish coat (it would kill the sheen and the reflection). There has been a lot of masking for the dayglo orange surfaces, the suface traitement on some aluminium parts, exhaust area, and markings, but i'm quite happy with this original and colorful scheme. The weathering was quite light as on this kind of polished finish, there is not a lot to do. A just hi lighted the panels with a UMP wash (no enamel wash as the AK metal paints are enamels so i did not want to experiment something that could ruin everything !), as without it it looks a bit toyish (i mean when you can see the bottom of the panel lines painted on...). On the dayglo areas, i did not used "dark dirt" was as it would be too dark and would be unrealistic, so i used "rust" color instead. The build itself was not the easiest i did, but it was quite pleasent. Nothing was really difficult to solve, though it sometimes asked for a bit of thinking and a lot of trimming. Of course, some putty was involved, too. I have two other of the kind in the stash (F-86K, which i plan to build as a french and a german aircraft) and i think it will be easier next time now that i trained myself on this one. I hope you like it. As usual, i took indoor pictures (but with daylight) on a blue background (i prefer that that the usual white background wich is too agessive for the other colors, though my blue is too vivid. I should find a kind of neutral grey background...) and then full outdoor pictures. Here is the link to the WIP thread : http://forum.largescaleplanes.com/index.php?showtopic=64229 Edited October 29, 2016 by Zero77 joe, Hubert Boillot, Shaka HI and 12 others 15 Link to comment Share on other sites More sharing options...
Zero77 Posted October 29, 2016 Author Share Posted October 29, 2016 DrDave, reconspit, Marcel111 and 12 others 15 Link to comment Share on other sites More sharing options...
Zero77 Posted October 29, 2016 Author Share Posted October 29, 2016 red baron, F`s are my favs, David66 and 10 others 13 Link to comment Share on other sites More sharing options...
Zero77 Posted October 29, 2016 Author Share Posted October 29, 2016 Hubert Boillot, ShelbyGT500, Jan_G and 7 others 10 Link to comment Share on other sites More sharing options...
Zero77 Posted October 29, 2016 Author Share Posted October 29, 2016 (edited) ANd with other LSP jets fellows. They take a lot of space ! And one of my reference pictures : Edited October 29, 2016 by Zero77 Aerobat, reconspit, DrDave and 7 others 10 Link to comment Share on other sites More sharing options...
Aerobat Posted October 29, 2016 Share Posted October 29, 2016 A really outstanding job - c'est beau. Zero77 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted October 29, 2016 Share Posted October 29, 2016 Excellent NMF finish! Just wow! Zero77 1 Link to comment Share on other sites More sharing options...
Jack Posted October 29, 2016 Share Posted October 29, 2016 Nicolas, tres bien, great DOG!!!! Zero77 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted October 29, 2016 Share Posted October 29, 2016 Brilliant model, Nicolas! You just keep turning them out. May I publish it on the website? Kev Zero77 1 Link to comment Share on other sites More sharing options...
joe Posted October 29, 2016 Share Posted October 29, 2016 That turned out fantastic. Lovely finished on my that dog... Zero77 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted October 29, 2016 Share Posted October 29, 2016 Very, very nice. I like this a lot. Zero77 1 Link to comment Share on other sites More sharing options...
Zero77 Posted October 29, 2016 Author Share Posted October 29, 2016 Thanks a lot ! Or course you can publish it Kev ! Link to comment Share on other sites More sharing options...
David Hansen Posted October 29, 2016 Share Posted October 29, 2016 A Brilliant job. Literally and figuratively. Easily the best example i've seen built up yet, and a worthy inspiration to others who want to take this on. -d- Zero77 1 Link to comment Share on other sites More sharing options...
Zero77 Posted October 30, 2016 Author Share Posted October 30, 2016 A Brilliant job. Literally and figuratively. Easily the best example i've seen built up yet, and a worthy inspiration to others who want to take this on. -d- Thanks a lot, i'm very touched by your compliment ! Link to comment Share on other sites More sharing options...
Joe66 Posted October 30, 2016 Share Posted October 30, 2016 Wellllll now yall......ain't that jest the puurtiest little thang ! Sharp build. Looks Great !! Joe Zero77 1 Link to comment Share on other sites More sharing options...
