HPH Fw-189 A-1
HPH Fw 189
  • Please log in to reply
98 replies to this topic
#1 Jan_G
Jan_G
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 564 posts
  • Gender:Male
Posted 04 July 2016 - 07:50 PM
Hi guys,
time to start my summer project #2...
I realized,  that 3 HPH kits I have, represents 33% of my current stash :) so its time to start to build it :frantic:
so it will be my first HPH model and first all resin model, so looking forward to this OOB build, with just some small extras if needed.
I did not see lot of Uhu`s builds on the web so will try to cover it with lot of pictures and hope that I will do justice to it.
971a2444-11a5-4fce-887f-744171095d87_zps
67d55a10-2490-45f3-8b73-aaa8b80c6755_zps
I love this style of model content, you really do not have to buy anything :)
And yes, one of the reasons I have started Uhu is that I need some material for Sandy seatbelts because dont want to use PE ones anymore :)
and will try wet transfers for the first time so Im happy   :hmmm:
Ok, main parts needs some carefull cleaning...
793ae907-603c-46b3-90ac-ccdd53f16216_zps
used lot of water, Tamiya fine knife and Radu`s fine saws 8 for this job...
and it went quickly and well...
thanks for looking
jan
  • Iain (32SIG), LSP_Paul, Martinnfb and 8 others like this
#2 Iain (32SIG)
Iain (32SIG)
    Senior Member
  • LSP Moderator
  • 7,335 posts
  • Gender:Male
Posted 04 July 2016 - 07:53 PM
Looking forward to seeing this come together Jan - great project!
Iain
Iain Ogilvie - http://www.aeronut.co.uk
#3 LSP_Paul
LSP_Paul
    Senior Member
  • LSP Moderator
  • 5,546 posts
  • Gender:Male
Posted 04 July 2016 - 07:54 PM
Best of luck with this one too Jan!
Paul
#4 Jan_G
Jan_G
    Senior Member
  • LSP_Members
  • 564 posts
  • Gender:Male
Posted 04 July 2016 - 08:00 PM
Thanks Paul, thanks Iain :)
Currently I am so into modelling that yesterday I went for 5 days business trip to Bucharest and I put in my suitcase even some resin parts, sand paper and tamiya knife so I can clean them up in the evenings...hopefully before evening parties :)
  • Iain (32SIG), LSP_Paul, Kahunaminor and 1 other like this
#5 Wouter
Wouter
    Senior Member
  • LSP_Members
  • 520 posts
  • Gender:Male
Posted 04 July 2016 - 08:13 PM
Will follow with great interest, I have this kit in my stash. Let's see what you can do with it!
On the bench, on the shelf, Finished. Just take a look here:https://www.scalemat...te.php?id=17982
#6 Jan_G
Jan_G
    Senior Member
  • LSP_Members
  • 564 posts
  • Gender:Male
Posted 04 July 2016 - 08:59 PM
it appears that main challenge is to put wings together with cross-beam in perfect alignment
Even if you will clean carefully main parts, there are no exact pin marks and cross beam consist of 3 parts  :hmmm:
so I was just following instructions....
glued beams to wing parts and middle section...
and prepared some stuff to keep all parts aligned.
I used to play with allignment and dry fitting for 2 hours till I glued it  together (descriptive geometry was my favourite discipline during my studies :) )
493f34c2-c20e-4bce-947d-6995074ad357_zps
and after 1 hour of epoxy drying I just realize that something wrong with left wing angle...
ebcbf2b2-647e-492d-8b8a-5aca041e22cb_zps
this small deviation caused that left wing tip was 5mm above the level of right wing tip.
So I cut the beam from wing and scrub the glue and refix it in better position  :deadhorse:
and the result, wings glued together and alligned, yeees
this stage can be show stopper so take your time.
thanks for looking
jan
  • Iain (32SIG), D.B. Andrus, Martinnfb and 4 others like this
#7 Jan_G
Jan_G
    Senior Member
  • LSP_Members
  • 564 posts
  • Gender:Male
Posted 04 July 2016 - 09:12 PM
I would like to kindly ask you guys for some advice regarding epoxy glue
I bought this tamiya stuff at my LHS (that fellow didnt have anything else in stock currently)
its 5 min epoxy and its quite easy to work with it.
but didnt find any evidence regarding usability with resin, how it will survive sanding and so on
So pls do you have any experience with this?
It looks that original HPH epoxy is out of stock currently, so do you think that even such two components epoxy stuff from brands like Uhu or Pattex will work well with resin?
thanks a lot for recommendations.
jan
  • Martinnfb and Zero77 like this
#8 D.B. Andrus
D.B. Andrus
    Senior Member
  • LSP_Members
  • 2,133 posts
  • Gender:Male
Posted 04 July 2016 - 09:29 PM
:popcorn:
Cheers,
D.B.
  • Martinnfb likes this
Synthetic Ordnance Works
Alba, Texas
(formerly Synthetic Authentics)
#9 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,828 posts
  • Gender:Male
Posted 04 July 2016 - 09:30 PM
So glad to see you start this one, Jan. It's a great project, for sure! I'll be following along avidly.
With regard to the Tamiya epoxy cement, it should be fine for use on resin. Most epoxy glues are good more most jobs, and will give you more strength, with less brittleness, than CA.
Kev
#10 Wouter
Wouter
    Senior Member
  • LSP_Members
  • 520 posts
  • Gender:Male
jan
Hi Jan,
can't comment on the Tamiya stuff, but I have tried some 5 min epoxy from Pattex on my Hph Me410 and it failed miserably. From that point on I reverted to superglue and Hph's own epoxy. Lovely stuff, but it takes 24 hours to dry so you have to plan ahead. The good thing is that you have plenty time to adjust the parts if needed.
Anyway, you can order their epoxy glue directly from their website.
Cheers, Wouter
#11 Jan_G
Jan_G
    Senior Member
  • LSP_Members
  • 564 posts
  • Gender:Male
Posted 04 July 2016 - 09:49 PM
thanks guys for recommendations, really appreciate it
Will try to send email to HPH, because their website show stock 0 for their epoxy currently, or will try to find it on other eshops
and meantime will use this Tamiya glue
jan
#12 Clunkmeister
Clunkmeister
    Senior Member
  • LSP_Members
  • 11,799 posts
  • Gender:Male
Posted 04 July 2016 - 11:56 PM
Awesome start, Jan. The trimming and initial ling me t are always the most tedious, critical and time consuming parts of these builds.
Most of us tend to rush through this most critical step. Me included...
Was mich nicht umbringt macht mich stärker
In progress:  T-28C, T-28D from a C, MuG-23MF, Felixstowe F2a early, PBJ-1H, PZL P-11C
Completed: RCAF F-51D Mustang, ZM A-1H Skyraider, Tamiya A6M2, Felixstowe F2a early, Junkers J.l, Gotha G.lV, Pfalz D.Xll, Albatros D.V, Bf-109F4, Ta-152H-1
#13 Jan_G
Jan_G
    Senior Member
  • LSP_Members
  • 564 posts
  • Gender:Male
Posted 22 July 2016 - 08:03 AM
quite slow progress with this one
cleaning parts, sanding and dry fitting of major parts...but honestly I really enjoy this kind of builds :)
first layer of surfacer applied and Gunze RLM02 used for wheel wells
and I was playing with Radu's rivet tool a little bit - its great. I was doing rivets for first time and realised that it was not such a challenge than I expected.
lessons learned: If you poured a soap water in the sink - always use strainer  :rolleyes: - waste disposer ate 3 parts in past week  :shrug: but I have written to HPH already If I can get them extra
was waiting for HPH Epoxy, but now  I have it so will glue main parts together as a next step...
thanks for looking
jan
  • 109, Iain (32SIG), Kagemusha and 2 others like this
#14 alaninaustria
alaninaustria
    Senior Member
  • LSP_Members
  • 6,862 posts
  • Gender:Male
Posted 22 July 2016 - 09:08 AM
Wow! Gorgeous bird!!
#15 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 26,194 posts
  • Gender:Male
Posted 23 July 2016 - 08:14 PM
Interesting machine, and looks like a pretty nice kit.
Kevin
I was going to procrastinate tonight, but decided to wait.
In Progress:
Also tagged with one or more of these keywords: HPH, Fw, 189
