red Dog Posted September 17, 2015 Share Posted September 17, 2015 (edited) Hello gents, it was a while i couldn't work on LSP because of a few smaller scale projects i had to finish. But here i am again with something i looked forward to for a long while a HK B-25J model. The B-25 will be the Maid in shade currently part of the commemorative airforce in Arizona. The build will create a few challenges. - Obviously the interior has been adapted to air rides rather than combat. Although the guns are still installed there are lots of seats all over the forward and aft cabin. I'm not sure i'll be able to make the internals as the modern restored aircraft, especially considering that most of all this will be invisible once assembled. - the natural metal finish will be interesting as well and of course there is no decal for this one - well not that i know of. So i had to design my own. the larger decals (national insignas and tail numbers will be painted these are not final yet, just a work in progress when I need a break from the bench. - the biggest issue for me will be the need to convert the engine exhaust from the full clayton of the model to the modified clayton that restored B-25 usually have. Some of the top cowling individual exhausts are collected into one larger side exhaust pipe and the carburator intake on top of the wing is much larger and rectangular in shape. I don't think i have already seen such a modification on 1/32 B-25 model. The model will use a bit of aftermarket products such as the usual eduard PE sheets, AMS props, Brassin wheels, brass gears and turned barrels for the .50s. Not forgetting the much needed nose weight Let's go for another B-25 WIP Edited July 24, 2016 by red Dog Iain and Zero77 2 Link to comment Share on other sites More sharing options...
Jan_K Posted September 17, 2015 Share Posted September 17, 2015 Wonderful, I'll follow this thread. Link to comment Share on other sites More sharing options...
Out2gtcha Posted September 17, 2015 Share Posted September 17, 2015 Lovely! Link to comment Share on other sites More sharing options...
Jack Posted September 17, 2015 Share Posted September 17, 2015 Hi Red dog, very interesting build, certainly on the "inside-job", and it could be possible to show it using the clear fuselage version of the HK Mitchell, which is a special issue of this kit. Jack. Link to comment Share on other sites More sharing options...
brahman104 Posted September 18, 2015 Share Posted September 18, 2015 Count me in. I do love a B-25 build. I'll get to mine one day Craig Link to comment Share on other sites More sharing options...
red Dog Posted September 26, 2015 Author Share Posted September 26, 2015 (edited) Lovely!Brian, I Hope you won't mind me using your splendid WIP of the "Lady Lil" ? http://forum.largescaleplanes.com/index.php?showtopic=43199&page=1 To be honest I used yours as inspiration - I'll be happy if mine turns half as good as yours. Standard internal work started with some PE fun with the eduard sheets for the B-25J: bomb bay: Cockpit: Access doors: I broke a few teeth on that one. I think (but I may have screwed it) that Eduard instruction sheets (32-756) have some mix ups about the access doors and the inner walls to the access doors. There is a narrow and wide door and if you follow the instructions the inner wall details PE fret won't fit the kit's parts. As they are too wide or too narrow to fit the entrance. All it takes is switching a few parts around to fix it. Here's how I did in the end: 1. Eduard instruction says: front door inner wall is 59-58 but should be 60-56 and inversely for the rear door on instructions 2. Eduard instruction says: front door is 69-67-66-23-22-74-53 but should be 69-67-66-23-22-73-46 3. Your instruction says: rear door is 70-68-62-23-22-73-46 but should be 69-67-66-23-22-74-53 Again, that is how it was for me. I'm still scratching my head about this one wondering if I screwed up Seats: The Pe seats are gorgeous. Unfortunately I can't use them as I need the standard seats and certainly not the smaller seat. So I would need to buy an extra seat PE set to get a second pilot seat or live with the kit's seats which are perfect for the restored civilian version but quite less gorgeous than the PE's. That said I could use the kit's seats in the fuselage as Maid in Shades has a lot of extra seats for the rides they sell. I'm still wondering what to do about that one. I could use one PE seat and 4-5 extra kit's seats. Edited February 29, 2016 by red Dog airscale and Iain 2 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 26, 2015 Share Posted September 26, 2015 That's some nice work! Kev Link to comment Share on other sites More sharing options...
brahman104 Posted September 26, 2015 Share Posted September 26, 2015 Man that PE looks like a lot of effort.... looks awesome though! Craig Link to comment Share on other sites More sharing options...
Azgaron Posted September 26, 2015 Share Posted September 26, 2015 Nice work so far! HÃ¥kan Link to comment Share on other sites More sharing options...
red Dog Posted September 26, 2015 Author Share Posted September 26, 2015 (edited) Thanks guys, all pretty basic stuff for now. The crew of Maid in shade certainly earned the right to get comfortable flying the B-25 so I added some cushion in milliput on the kit's seats The hydraulic pump was redone with soldering wire - although I screwed up the end of it. the rest is basic painting, and eduard PE's. weathering is Wip. Right side wall populated with eduard PE. I added some wires for the boxes. I also added some basic detailling in the top turet compartment behind the cockpit. The gear manual pump and some tanks. There is no wall detail at all in the top turret compartment, I'm not going to remake the whole structure but I added some very basics ones so it looks at least like the rear compartement. That area will be heavily populated anyway with large boxes. Maid in Shade don't have the turret column installed so I may leave that out of the compartment. Edited February 29, 2016 by red Dog stusbke and airscale 2 Link to comment Share on other sites More sharing options...
red Dog Posted September 27, 2015 Author Share Posted September 27, 2015 (edited) Populating the top turret compartment: The other side Some work on the rear with eduard stuff: Edited February 29, 2016 by red Dog Lars Befring 1 Link to comment Share on other sites More sharing options...
shark64 Posted September 27, 2015 Share Posted September 27, 2015 sweet. great looking cockpit. Oliver Link to comment Share on other sites More sharing options...
Youngtiger1 Posted September 28, 2015 Share Posted September 28, 2015 Great start RD. I need to grab me a set of those ProMod PE seat set. Link to comment Share on other sites More sharing options...
red Dog Posted October 25, 2015 Author Share Posted October 25, 2015 (edited) It's slow but i made some progress The bomb bay was painted in aluminium with details in interior green. More plumbing will be added as I close the bomb bay. I decided to stick the two top bombs in there just to pupolate a bit the bay. Obviously these would be dummies I sourced some textured plastic sheet to simulate the soundproof padding some civilian B-25 have on the inner fuselage walls. That's a great opportunity also to hide the lack of details in some part of the fuselage. The emergency exit door is not detailled inside the fuselage so I used the PE meant for the fuselage side bomb bay exit which is totally invisible after the fuselage is closed. It will be barely more visible on the fuselage side but it greatly populates that area. I'll also detail the counterweight mechanism for the waist guns. Some more paint and more goodies added. The other side received the same treatment The front cabin was also painted and detailled a bit more. Black boxes, fire extinguishers, wires, first aid kits... An hydraulic tank was added on the bomb bay front wall in the top turret compartment. I'll add some floor in the rear compartment. If it is not done and the rear access door is left open, the internal side wall of the door are just sticking out of nowhere. The plasticard floor will address that issue. Edited February 29, 2016 by red Dog TorbenD, geedubelyer, Ripaman and 2 others 5 Link to comment Share on other sites More sharing options...
brahman104 Posted October 25, 2015 Share Posted October 25, 2015 Wow mate! That is top notch I especially like your CB panel and the painting and finishing of the bomb bay bulkhead. Where did you find that "sound proofing" pattern plastic, I certainly could use that in my chinook models! Cheers Craig Link to comment Share on other sites More sharing options...
