A sentimental favourite de Havilland - the Mk35 Vampire
Vampire
  • Please log in to reply
8 replies to this topic
#1 Uncle Les
Uncle Les
    LSP Member
  • LSP_Members
  • PipPipPip
  • 32 posts
  • Gender:Male
Posted 08 November 2014 - 10:55 AM
Many moons ago a younger Uncle Les wore a blue uniform and performed feats of technical interest on Bous, Macchis and more importantly, on this aircraft:
This is the view from the instrument section window above the flight line.  I decided I wanted to build a model of this very aircraft ( as I tend to do with others I've taken a screwdriver to..) and to this end I made a 1/72 resin conversion set, 1/48 resin fuselage replacement and more recently, a 1/32 one-off.  Here's a bit of the story of the 1/32 example in a brief photographic essay:
I decided I wanted to build an RNZAF Venom alongside the Mk35 using a Matchbox Sea Venom as a base - I also obtained a Tigger models Vampire but this proved to be rather expensive and disappointing - it ended up being an expensive canopy and mismatched parts that needed a LOT of work.  Eventually I knocked up the sections I needed with plasticard and resin using scaled up plans from various sources.
My take on the Goblin was using the Matchbox Ghost, casting up new cans and making a few mods here and there...
vampmk35007_zps1562a3d6.jpgThese pics will show which bits of the kit I used and which bits were cast up - I made up one boom to suit and cast up multiples to cater for this and the Venom.
I then whipped up a nose shape and vac-formed some nosey bits to cater for both the underside and the bonnet.
Edited by Uncle Les, 08 November 2014 - 02:20 PM.
  • Whitey likes this
#2 Uncle Les
Uncle Les
    LSP Member
  • LSP_Members
  • PipPipPip
  • 32 posts
  • Gender:Male
Posted 08 November 2014 - 10:57 AM
The vacform nose is seen here before the ribs were added
A little more detailing work
  • harvey and Whitey like this
#3 Uncle Les
Uncle Les
    LSP Member
  • LSP_Members
  • PipPipPip
  • 32 posts
  • Gender:Male
I spent a lot of time "under the hood" so I have a least a little knowledge of the plumbing !
#4 Uncle Les
Uncle Les
    LSP Member
  • LSP_Members
  • PipPipPip
  • 32 posts
  • Gender:Male
Posted 08 November 2014 - 10:59 AM
Moving forward - I tend to build fairly fast and didn't photograph some of the intervening steps so here we are magically with some markings applied
 The wing tip lights were made by inking a small vacform "bulb" was was encased in clear epoxy and then sanded to shape.
Bang seats using some Mk3s I had laying around (thanks Eric Sujecki collection..)
 and we're pretty much there
Edited by Uncle Les, 08 November 2014 - 11:00 AM.
#5 Uncle Les
Uncle Les
    LSP Member
  • LSP_Members
  • PipPipPip
  • 32 posts
  • Gender:Male
Posted 08 November 2014 - 11:00 AM
and finally here's my take
on an aircraft I enjoyed immensely as mere queer trader.
Edited by Uncle Les, 08 November 2014 - 02:17 PM.
  • mywifehatesmodels, harvey, SinuheH and 1 other like this
#6 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,804 posts
  • Gender:Male
Posted 08 November 2014 - 11:26 AM
Awesome stuff Les! Good to see how this one came to fruition. Good inspiration too for when I finally tackle Tigger's Tunnan.
Kev
#7 SinuheH
SinuheH
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 1,614 posts
  • Gender:Male
Posted 08 November 2014 - 04:13 PM
Amazing stuff - thanks for sharing the origin and journey!
:goodjob:
Completed: Tamiya P-51D (SAAF),  F-5E (Swiss) , Bf109G-6 (Swiss) (LSP article lost?), Hasegawa Ki 61 TonyTamiya A6M5c Zero (USN), Hasegawa Ki-84 (Chinese Nationalist Forces)
Hasegawa Bf109F-4Trop (SAAF)
On the bench: Foreign or Captured GB: IAF F-16A Netz
Stalled: Tamiya F-4J (USN)
Silhouette Mask Cutter user
#8 Whitey
Whitey
    Senior Member
  • LSP_Members
  • 652 posts
  • Gender:Male
Posted 08 November 2014 - 07:40 PM
Incredible Les. Well played.
#9 Hardcore
Hardcore
    Senior Member
  • LSP_Members
  • 1,611 posts
  • Gender:Male
Posted 08 November 2014 - 07:53 PM
Amazing you get such even, smooth, surface at the end.
Also tagged with one or more of these keywords: Vampire
