Airfix 1/24 Typhoon - airscale Instrument Panel
  • Please log in to reply
21 replies to this topic
#1 airscale
airscale
    Senior Member
  • LSP Sponsors
  • PipPipPipPipPipPip
  • 1,813 posts
  • Gender:Male
Posted 10 August 2014 - 07:07 PM
evening all :)
I have spent the last few days sending many of our airscale Typhoon upgrade sets out across the world for the new Typhoon and it occurred to me with many builders soon to start using them it might be worth adding an mini WIP on how I would get the best out of the kit parts and the decal set.
Happy to pull it if not wanted of course, so will see how it goes...
I will only complete the Panel rather than the whole cockpit (so won't be adding all the many placards we include), as I assembled the test shot parts I had to make pictures for our instructions. Also I won't be tempted to detail any more than what is included in the box, so let's see what you get in the kit.
The panel is beautifully reproduced and is joined by a clear insert, which while it is clear is not meant to be used in that way which is a bit curious...  I can only think it is to allow for the spare bulbs which are moulded as three small protrusions above the top left of the middle six instruments..
..first thing is the dial faces have bevelled edges so first thing was to take a flat file and flatten them all down - the side panels are at an angle and the flat must be flat to the surface of these...
..in addition a few of them are too small for the holes in the one I had so these will need replacing with punched discs and therefore filing even further back...
..this is after a few minutes work - don't worry about losing clarity on the clear part as we have decals to go over them - the faces should be at a uniform depth and as flat as possible...
..I used a Waldron punch to punch out a few discs to tidy up the apertures that needed it - mine was a test shot so maybe different to the production version, but this is easy to do if needed...
..one thing that I noticed after assembly was the clear part makes the middle six instrument panel (the 'Blind Flying Panel') very, very thick when viewed from any angle, so I carefully routed out the top of the clear part with a dremel...
..I don't have instructions or all the parts so not sure how the panel mounts, but you should be able to see the tops of the instrument bodies through the gap at the top of the Blind Flying Panel, so I added some scrap tube to represent them...
you may want to disregard this if it complicates assembly, but I am a cockpit geek and it would bother me (ahem)
..not easy to photograph, but you can see the thinner panel and maybe the backs of the top three instruments..
..also means I can add a convenient handle to work on the part..
..I always prime before painting, so a shot of Mr Surfacer to see what's what. I would still prefer to fill the gaps in some of the dial faces, but will see how we go...
..hope this is useful as I am doing it anyway to make sure no tweaks are needed in the new set. Mods feel free to move to vendors area or wherever if needed.
..back later after painting...
TTFN
Peter
  • dora9 and Girlscanplay2 like this
airscale donates a % of sales to the Royal Air Force Association to remember 'the few' RAFA
#2 Jolly Roger
Jolly Roger
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 212 posts
  • Gender:Male
Posted 10 August 2014 - 07:39 PM
Very much looking forward to seeing more of this, as I received an email the other day saying my instruments were on the way to me.
Roger <(^^,)>
#3 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,225 posts
  • Gender:Male
Posted 10 August 2014 - 07:49 PM
Peter
Great;y appreciate the mini tutorial and looking forward to the next part. I'm slowly purchasing all the other upgrades presently available.
Keep 'em coming
Peter
Trumpeter SBD-1
#4 Gloucester Nige
Gloucester Nige
    LSP Member
  • LSP_Members
  • PipPipPip
  • 48 posts
  • Gender:Male
Posted 10 August 2014 - 09:25 PM
Thanks for taking the time to do this Peter, I hope to receive my set tomorrow,(Monday).
It's a shame you don't do canopies :innocent:
Regards
Nige
#5 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,225 posts
  • Gender:Male
Posted 10 August 2014 - 09:47 PM
Ditto!
Trumpeter SBD-1
#6 Simmo.b
Simmo.b
    Senior Member
  • LSP_Members
  • 709 posts
  • Gender:Male
Posted 10 August 2014 - 11:02 PM
My sets in the mail too, will be following for sure, thanks for posting!!
#7 airscale
airscale
    Senior Member
  • LSP Sponsors
  • 1,813 posts
  • Gender:Male
Posted 10 August 2014 - 11:46 PM
thanks chaps
well, that all went pretty smoothly - an evening's work. Everything fits so thats the first hurdle overcome!
I just blasted through to get it complete this evening and really the only tips I can give are take your time and trim what little carrier film there is if the dial sits in a recess.. oh and an optivisor is very useful!
..so, after priming I shot a coat of semi gloss black (all paints are Tamiya), followed by Nato Black...
..then picked out the details with a semi gloss black wash - basically thinners with the paint added carefully applied with a fine brush...
..then it was cut out a dial and start application according to the instructions - I just use a small blob of cold water..
..after working through the dials & placards it was done! If I was doing it for real, I wouldn't do too much differently - maybe add some panel details and certainly take more time painting the coloured dial surrounds...
..as it is, my photography is not so great so here are a few pics of the panel with different backgrounds to try & give some idea of how it looks...
..I still need to chip and weather it, and look at how best to 'glaze' the dials as I can't use my normal punch & glaze with acetate as the moulded dials don't all fit my waldron punch set - I expect glazing with future or gloss varnish will do it... will see next time..
I hope that was useful, and can't wait to see the builds of this astounding kit that are sure to come in the next few months..
TTFN
Peter
  • Girlscanplay2 likes this
#8 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,225 posts
  • Gender:Male
Posted 10 August 2014 - 11:49 PM
Peter
Much appreciated.
Peter
Trumpeter SBD-1
#9 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 11 August 2014 - 06:30 AM
Beautifull !
Cheers!________________________________________________________________________________________________________
In the work :   Dornier Do 335   /   A-1H/J Skyraider   /   Mirage F1 (Scratchbuild)  /  Mirage IIIC
Completed builds :   Hawker Tempest (kitbash)   /   Nakajima B5N Kate (Scratchbuild)   /   Spitfire Mk I
Master pattern work:   DB-603 Engine    /   F4U-1 Corsair engine bay
#10 airscale
airscale
    Senior Member
  • LSP Sponsors
  • 1,813 posts
  • Gender:Male
Posted 11 August 2014 - 01:58 PM
..to finish up..
drops of future on the dials, a bit of matt varnish on the placards, some weathering (at least my best efforts at it..) and hopefully some better photography in natural light...
..just need to get the rest of the kit now.... but I must resist - I have a 1/32 DH Hornet & Ju188 to build first :ninja:
TTFN
Peter
  • TaffyMan likes this
#11 Eli Raphael
Eli Raphael
    Senior Member
  • LSP Sponsors
  • 2,240 posts
  • Gender:Male
Posted 11 August 2014 - 02:37 PM
Thanks for posting, Peter.
Eli Raphael
www.zotzdecals.net
"Love of beauty is taste. The creation of beauty is art."
#12 TaffyMan
TaffyMan
    Senior Member
  • LSP_Members
  • 733 posts
  • Gender:Male
Posted 11 August 2014 - 09:07 PM
Cheers for this mate nice tutorial - just need to earn some penny's so I can get the kit and bits :frantic:
Happy Days - Taff :D
#13 Anders_Isaksson
Anders_Isaksson
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 123 posts
  • Gender:Male
Posted 11 August 2014 - 09:39 PM
Looks like a great set for the Airfix Typhoon, thanks for the walkthrough! :)
#14 Iain (32SIG)
Iain (32SIG)
    Senior Member
  • LSP Moderator
  • 7,156 posts
  • Gender:Male
Posted 11 August 2014 - 09:41 PM
Stunning stuff Peter - as always!  :thumbsup:
Iain
Iain Ogilvie - http://www.aeronut.co.uk
#15 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 24,225 posts
  • Gender:Male
Posted 11 August 2014 - 10:41 PM
Peter
Much appreciate the tutorial.
Peter
Trumpeter SBD-1
