HK Models 1/32 Meteor Mk 4
HK Models Meteor
  • Please log in to reply
226 replies to this topic
#1 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,036 posts
  • Gender:Male
Posted 22 December 2013 - 01:39 AM
As promised folks, here's the opening salvo to my HK Models test shot build. This kit arrived without a box or instructions, and with test decals that I'm told do not meet production standards in terms of colour fidelity. I have some rudimentary assembly instructions in PDF format, but no painting and marking guide. So, here's a teaser shot of a pile of sprues:
For more photos and sprue shots, check out the preview I did from a couple of weeks ago, and also the associated forum discussion.
The reason I'm starting this thread now, rather than when I've got some actual progress to show, is that I have no idea what colours to paint the cockpit. And of course, that's where I'd like to start! As best as I can determine it appears to require a combination of black and interior green, but I'd love to hear from anybody with some definitive info.
Kev
#2 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 23,669 posts
  • Gender:Male
Posted 22 December 2013 - 01:43 AM
Kev
Eagerly looking  forward to following the build as the kit is on my must buy list
Peter
  • Mal_Belford likes this
On the bench: Trumpeter A6A Intruder VA-165 Boomers
USS Constellation 1971-72
#3 Michael Satin
Michael Satin
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 72 posts
  • Gender:Male
Posted 22 December 2013 - 01:57 AM
As I said on FB, both the Classic Airframes 1/48 kit and the Modellers Datafile on the Meatbox indicate black for the F.Mk.IV.  I don't see any indication of interior green.
Looking forward to the build!
Michael
#4 Michael Satin
Michael Satin
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 72 posts
  • Gender:Male
Posted 22 December 2013 - 01:59 AM
BTW, would you like a scan of the CA instruction?  They might help on the build.  Let me know!
Michael
#5 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,036 posts
  • Gender:Male
Posted 22 December 2013 - 02:02 AM
Michael
Thanks Michael, that would be most useful! Can you email it to me?
Kev
#6 Smokey
Smokey
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 434 posts
  • Gender:Male
Posted 22 December 2013 - 02:07 AM
Kevin,  Will be following your build.  I got one of these on the wish list.  Dan
#7 Michael Satin
Michael Satin
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 72 posts
  • Gender:Male
Posted 22 December 2013 - 02:19 AM
On their way!  Let me know if the resolution is OK.
Michael
#8 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,036 posts
  • Gender:Male
Posted 22 December 2013 - 02:27 AM
Michael
Thanks Michael - all good!
Kev
#9 Michael Satin
Michael Satin
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 72 posts
  • Gender:Male
Posted 22 December 2013 - 02:29 AM
Excellent!  Looking forward to seeing you work your magic!
Michael
#10 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,036 posts
  • Gender:Male
Posted 22 December 2013 - 02:36 AM
Thanks Michael. This will be pretty close to OOB, just so we can all see how it goes together. Though I wouldn't mind a set of aftermarket seat belts. Any suggestions?
Kev
#11 Michael Satin
Michael Satin
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 72 posts
  • Gender:Male
Posted 22 December 2013 - 03:37 AM
Looks like a pretty standard Sutton harness, though I may be wrong on this one.
Michael
#12 ghatherly
ghatherly
    Senior Member
  • LSP Sponsors
  • 1,510 posts
  • Gender:Male
Posted 22 December 2013 - 04:39 AM
Looks like a neat kit.  I plan on watching.
Merry Christmas, Gary
Many Thanks, Gary
email:   garyhatherly@gtresinproducts.com.      Web Site:   www.gtresinproducts.com
"In the beginning was the Word, and the Word was with God, and the Word was God, He was with God in the beginning. Through Him all things were made; without Him nothing was made that has been made. In Him was life, and that life was the light of men. The light shines in the darkness, but the darkness has not understood it.” John 1:1-4
dd34971d-1dff-4d25-b610-dddb8f8ab69c_zps
#13 oletcherfred
oletcherfred
    Senior Member
  • Deceased Members
  • 576 posts
  • Gender:Male
Posted 22 December 2013 - 05:24 AM
If you need Sutton Harness hardware and correct instructions, check out:
Thanks in advance fo looking !
Happy Modeling!
Fred Hultberg
, resident etching Wizard @ Fotocut�
oletcherfred at yahoo dot com
#14 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,036 posts
  • Gender:Male
Posted 22 December 2013 - 06:16 AM
Hi Fred,
Is there meant to be a link in your post somewhere?
Kev
#15 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,036 posts
  • Gender:Male
Posted 22 December 2013 - 06:40 AM
OK, I've started snipping plastic off the sprues. My sample shipped with extensive bubble wrap, but in a relatively flimsy plain cardboard box, so the trailing edge of one of the wing roots suffered some crush damage:
This shouldn't pose too much of an issue, and I'd imagine the final retail package won't suffer from this possibility.
One thing I noticed immediately is that the sprue attachment points are on the mating faces of the parts, rather than their outer visible surfaces:
This is a double-edged sword. On the positive side of the ledger, it means that clean up - when done carefully! - should not mar the visible surfaces of the kit. On the negative, injudicious use of the sanding stick will produce a local depression in the plastic that could result in gaps come assembly time. On the whole though, I think I prefer this approach than the other, which risks damage to surface detail.
Here's the fuselage taped together after cleaning up the sprue attachment points:
The fit is pretty good, though not completely crisp along the mating edges, and there's a notable 'unfinished' look to the plastic either side of the seam line:
This will be taken care of during the clean up of the fuselage seams, but it did strike me as a little odd. Here's the wing assembly similarly cleaned up and taped together:
And then the two assemblies brought together:
Fit is pretty good, though the trailing edge of the wing roots will need careful assembly and clamping to ensure there are no steps:
I suspect a little bit of filler will be required, but nothing too dramatic. Next up I'll start work on the cockpit.
Kev
  • frogman13 likes this
Also tagged with one or more of these keywords: HK Models Meteor
