Zero77 Posted September 8, 2013 Share Posted September 8, 2013 (edited) Here is a 1/32 revell X-1 I made on may. It was quite fast to build, only 2 sprues. The longer job was to engrave the panels and find a good mix to get an acceptable orange hue. It is almost OOB, i have only made some little scratch in the cockpit and added the 2 little scoops at the rear of the fuse. I also regraved the tires as the ones from the box were wrong. It was quite difficult and the result is not as clean as i want but it is not really visible. The decals are from cutting edge, but it almost was a mistake as the decals supplied in the box were very good (i used them for the stars as i found them better than cutting edge's). Edited September 11, 2013 by Zero77 Whitey 1 Link to comment Share on other sites More sharing options...
Zero77 Posted September 8, 2013 Author Share Posted September 8, 2013 RJS 1 Link to comment Share on other sites More sharing options...
pzcreations Posted September 8, 2013 Share Posted September 8, 2013 shes looks great! wheres the brook stick? Link to comment Share on other sites More sharing options...
Zero77 Posted September 8, 2013 Author Share Posted September 8, 2013 Thank you guys ! shes looks great! wheres the brook stick? I haven't made it... There was no toothpicks at home at this time... Seriously i did not made it because it was only used one time, so i consider it to be very anecdotal ! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 9, 2013 Share Posted September 9, 2013 Very nice mate! For what it's worth, a broomstick is supplied in the boxing of this kit that I have. How did you go with the engine exhaust pipes? On my kit they're very undersized, and do not fit the rear fuselage opening at all. Yours looks great, but you don't mention needing to do anything with them. May I publish it on the website? Kev Link to comment Share on other sites More sharing options...
SinuheH Posted September 9, 2013 Share Posted September 9, 2013 Nice work, takes me way back to The Right Stuff! Link to comment Share on other sites More sharing options...
joe Posted September 9, 2013 Share Posted September 9, 2013 Super stuff mate, that looks really classy. Well done. Link to comment Share on other sites More sharing options...
Thomas Lund Posted September 9, 2013 Share Posted September 9, 2013 Beautiful build - incredible simple aircraft for doing something that groundbreaking - well air-breaking, but ya know :-) Makes me want to do one Link to comment Share on other sites More sharing options...
Zero77 Posted September 9, 2013 Author Share Posted September 9, 2013 (edited) Very nice mate! For what it's worth, a broomstick is supplied in the boxing of this kit that I have. How did you go with the engine exhaust pipes? On my kit they're very undersized, and do not fit the rear fuselage opening at all. Yours looks great, but you don't mention needing to do anything with them. May I publish it on the website? Kev Thank you Kev ! Sure you can publish it on the website ! Yes the engine exhaust is undersized, but there was no problem for me as the engine is connected to the fuse with 2 rods (glued on the left side of the fuse if i remember correctly). So i only glued those 2 rods to their position on the left side of the fuse, and while the glue is bonding you are able to set it in the good position in the center of the aft fuse (i have dry assembled the fuse at this time to center it as good as possible). And although the exhaust is quite undersized, it is centered, and the only visual issue is that you have a slight gap between it and the fairing (but it's not very noticeable). Well it is not exactly as the real stuff, but there no other to do it, except making it all scratch and thin down the fuse thickness like crazy. (i have just noticed that i have forgotten to add the fuel dump pipe.... I will certainly add it as it is not a difficult modification... Drill and add a stretched cotton-bud...) Edited September 9, 2013 by Zero77 Link to comment Share on other sites More sharing options...
Rob Colvin Posted September 9, 2013 Share Posted September 9, 2013 Very nice Link to comment Share on other sites More sharing options...
LSP_Ron Posted September 10, 2013 Share Posted September 10, 2013 Nice work! Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 10, 2013 Share Posted September 10, 2013 Thank you Kev ! Sure you can publish it on the website ! Thank you sir! I just need your full name so I can credit the article properly. Kev Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 11, 2013 Share Posted September 11, 2013 And here is the article! http://www.largescaleplanes.com/articles/article.php?aid=1251 Kev Link to comment Share on other sites More sharing options...
BradG Posted September 13, 2013 Share Posted September 13, 2013 mmm bright, I need my sunnies. Link to comment Share on other sites More sharing options...
