Painting exhaust stains & gun port stoof
  • Please log in to reply
26 replies to this topic
#1 Sparzanza
Sparzanza
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,430 posts
  • Gender:Male
Posted 07 September 2013 - 05:37 PM
How does one do this without an airbrush, and without making it look stupid in the process? I've seen some people using some thinned black paint and just.. drag it out with a brush. This looks like crap to me. There must be some other way for us brush painters. I've found a good picture of exhaust stains on the side of a Hurricane with the help of the awesome BoB movie from 1969. I would like my Hurricane's stains to look similar. I assume the grey part is really old, while the black is fresh. So. How? :)
#2 phantom
phantom
    Senior Member
  • LSP_Members
  • 1,889 posts
  • Gender:Male
Posted 07 September 2013 - 05:40 PM
You can use pastels.
Happy Modeling
Mike
  • Sparzanza likes this
On the bench: F4F-4, F-4D, P-47D,
Completed Builds: ​B-25 Apache Princess
#3 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 9,280 posts
  • Gender:Male
Posted 07 September 2013 - 05:42 PM
Hi. Tamiya makes weathering master set. A powdered pigments  that you can apply with sponge or q-tip. Years ago i use to use just a regular chalk( artistic pastel) . Hope this helps :)
In progress:   D-13 ; Ta-152V7 ; Mig-29 ; EMIL ; P-39 Аэрокобра ; Avia S-199 ; K-14 what if
Done:            F-8 F-8 Wurger Party ; D-9 ; D-15; Ta-152E ; P-40E
#4 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 9,280 posts
  • Gender:Male
Posted 07 September 2013 - 05:46 PM
something like this :)
Edited by Martinnfb, 07 September 2013 - 05:48 PM.
#5 Martinnfb
Martinnfb
    Senior Member
  • LSP_Members
  • 9,280 posts
  • Gender:Male
Posted 07 September 2013 - 05:52 PM
While ago when I did not have an airbrush i use to  simulate the sprayed demarcation lines with the very same technique. It worked on armor as well.
http://www.missing-l...62_mhatala.html
Edited by Martinnfb, 07 September 2013 - 05:53 PM.
#6 DoogsATX
DoogsATX
    Senior Member
  • LSP_Members
  • 1,409 posts
  • Gender:Male
Posted 07 September 2013 - 05:59 PM
Pigments work very well
--Matt
dm-lsmbanner1.jpg?w=400
#7 superfly
superfly
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 95 posts
Posted 07 September 2013 - 06:46 PM
Take an ordinary pencil...scrape the graphite with your blade/knife onto a piece of paper....use an appropiate size brush...load it with graphite filings and dry brush....very easy to control...you can control how dark you want it....seal after.
It also looks good for "dirtying up" the cockpit area without overdoing it....get darker graphite for exhaust stains...more silver graphite for exposed metal look
its also cheap.
#8 Sparzanza
Sparzanza
    Senior Member
  • LSP_Members
  • 2,430 posts
  • Gender:Male
Posted 07 September 2013 - 06:51 PM
Thanks everyone for your replies. I should have mentioned that I needed a poor man's alternative. The Tamiya pigment thingies seems very interesting though, so I will save up for that. Perhaps I can afford it later this month. In the meantime I will try superfly's technique.
Thanks again!
#9 DoogsATX
DoogsATX
    Senior Member
  • LSP_Members
  • 1,409 posts
  • Gender:Male
Posted 07 September 2013 - 07:00 PM
Only problem with pencil graphite (which I love) is that it can look metallic, which you don't necessarily want for exhaust stains. You may want to rundown a set of charcoal pencils (cheap at any art/hobby supply store) and use those.
--Matt
#10 Sparzanza
Sparzanza
    Senior Member
  • LSP_Members
  • 2,430 posts
  • Gender:Male
Posted 07 September 2013 - 07:09 PM
I've used pencils for panel lines on my 1/24 Airfix Stuka. The metallic look will disappear once a coat of matte varnish has been applied. :)
I just tried superfly's technique on a silver 1:72 scale P51. It's a crappy model because it was painted with Humbrol Acrylics included in that giftset, so it's a good experiment platform.  I had problems getting the fragments to even stick to the brush, and even so it took many attempts to get it sort of visible behind the exhausts, sadly. Maybe because it's a silver painted plane. It worked a treat for the gun stains though, but only because I drew actual lines from the openings and across the wing, and then rubbed the lines out until they were barely visible. While it may look alright on such a small scale, I'm not sure how it will work on a 1/24 scale Hurricane. More experimenting to be done!
#11 superfly
superfly
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 95 posts
Posted 07 September 2013 - 07:12 PM
Doogs is absolutely correct charcoal would be better for exhaust stains...I was trying to be......cost effective lol
#12 csavaglio
csavaglio
    Senior Member
  • LSP_Members
  • 1,197 posts
  • Gender:Male
Posted 07 September 2013 - 07:15 PM
Back before pigments became more commercially widespread, I used to use artist's pastel chalks ground up using sandpaper.  You'd only need a few colors to get anything you'd need for exhaust/guns stains.....black, white, brown.....then mix the powders to the shades needed.
Chris
#13 Sparzanza
Sparzanza
    Senior Member
  • LSP_Members
  • 2,430 posts
  • Gender:Male
Posted 07 September 2013 - 07:17 PM
As it happens my brother is an artist. He uses both pencils and charcoal. I'm sure he'll give me some. This is what he can do with charcoal..
http://art1fact.devi...-face-128729844
So maybe he can do something with my Hurri's exhausts as well. ;)
#14 Lee White
Lee White
    Senior Member
  • LSP_Members
  • 3,749 posts
  • Gender:Male
Posted 07 September 2013 - 08:02 PM
The black stains are soot, while the gray areas are lead deposits from the fuel, IIRC. It' not one color being older than the other.
1/35 AH-56A Cheyenne-DONE!
1/32 Yak-38- Done!
 1/32 F-111C for the ABIM Group Build!
#15 Sparzanza
Sparzanza
    Senior Member
  • LSP_Members
  • 2,430 posts
  • Gender:Male
Posted 07 September 2013 - 08:12 PM
Well I guess I do learn something new every day. ;) Thanks for the heads up.
