1/32 Seafire Mk17 Wingfold conversion + the rest
  • Please log in to reply
83 replies to this topic
#1 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 21 August 2012 - 09:44 PM
Well here goes, my 1st Topic the Mk17, the aircraft chosen is SX156 of No 767 NAS, RNAS Yeovilton,1950.
I will be using the PCM kit MkIX + XVI & parts from Radu, GMF & Freightdog.
Posted Image
The wings are from GMF & need to be cut for the fold, then some material removed by using micro chisels so the scratch on the fold can begin by using styrine, brass & etch.
Posted Image
As the title suggests there are other Spits I have done but have never taken pics of my build, the main reason being I started this four years ago to try & complete 21 spits for 2011 the 75th Anniversary as it seemed there was not much going on for this & I would display them.
So whilst you wait for my next bit on the 17 here is the type 300 F.37/34
Posted Image
This was built using the Revell kit + Paragon conv. + Ventura decals.
Bob.
Edited by elric, 22 August 2012 - 12:54 AM.
  • MARU5137 and sandokan like this
#2 Dave J
Dave J
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 1,320 posts
  • Gender:Male
Posted 21 August 2012 - 10:32 PM
Looking forward to this! I was thinking of doing the same sometime..
Could you please give me a brake down of all the parts that you are use/sourced?
Cheers!
Dave Johnson
Wellington, New Zealand
#3 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,082 posts
  • Gender:Male
Posted 21 August 2012 - 10:46 PM
Cool project Bob. I'd love to hear more about your prototype conversion. It's something I've been thinking about doing myself lately, but don't really know where to start. I just can't afford the new Aerotech kit unfortunately.
Kev
#4 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 06:59 PM
Cheers!
Hi Dave,
If you could send me a message with your email I will send you what I have.
Bob.
#5 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 07:27 PM
Kev
Hi Kev,
On the prototype 300 I used the paragon Designs conv. kit + Ventura Decals, the conv. kit I think is now no longer made but now & again they appear. the decals are still available.
Not much to it really, the engine cowling has to be rounded of nearly through the plastic so I filled the inside edges with superglue, then just putting together the new prop, wheels, exhausts,wheel doors,radiator, rudder & canopy, the cockpit is as the MkI without the gunsight, no amour back plate to the seat & remove the undercarriage electrics & replace with the hand pump lever, this can be scratched or bought from Grey Matter Figures [GMF], Fill in the Tailwheel whole & fix the skid.
The only complicated part is re-scibing the wings on the 300 which I have done but am unable to locate the pic from which this was taken at this time + filing of the bubbles on the wings.
the Hendon Pagent Prototype in pale blue/grey when it 1st appeared to the masses with the name Spitfire had normal wings.
Posted Image
Posted Image
Posted Image
Edited by elric, 22 August 2012 - 07:32 PM.
  • MARU5137 likes this
#6 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 07:34 PM
A Pic of the Hendon Pagent model note the flush exhausts, not like the 300 F37./34
Posted Image
Bob.
Edited by elric, 22 August 2012 - 07:49 PM.
#7 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 07:46 PM
Anyway I digress, The MK17,
the wingfold progressing slightly,
Posted Image
Not much going to be left of the PCM fuselage, using the PCM rear fuselage from the Mk XVI conv. & the Griffin nose from GMF.
Posted Image
A little test fit.
Posted Image
Posted Image
Bob.
#8 Shawn M
Shawn M
    Senior Member
  • LSP_Members
  • 5,585 posts
  • Gender:Male
Posted 22 August 2012 - 08:19 PM
wow!
way cool conversion, I love the look of the bi-fold wing.
I dont suffer from AMS, I revell in it..get it...Revell
#9 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 08:46 PM
Thanks Shawn M,
Ok away from the wingfold for a bit,
the griffin nose [GMF] the panel line for the top cowling on the kit is for the spit & on the Seafire goes straight round not at an angle as seen but to the dotted line, this means that the access panels are to be moved back slightly, now where did I put that scibber + the the access panel by the air intake is to be removed filled in with a bit of putty.
Posted Image
most of the parts for this build I am using from left overs in the spare box from the other spits I have built, am using a 5 prop nose but on this aircraft it only had 4 so filler again this time araldite metal, why because I like it & it has a nice grey finish.
Another view of the test fit + pic of underside PCM fuselage or what will be left of it.
Posted Image
Posted Image
Bob.
#10 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,082 posts
  • Gender:Male
Posted 22 August 2012 - 09:44 PM
Hey Bob, thanks for the info on your prototype builds. They look awesome! I see the Ventura decals on eBay occasionally, but I guess I'll need to scratch-build the conversion itself now.
Anyway, your Seafire is looking great, and your work is really impressive.
Kev
#11 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 10:05 PM
Hi all, thought I would show you the aircraft I am attemping to model.
Posted Image
Posted Image
and to finish the evening with my Speed Spit.
Posted Image
For the Speed Spit. I used the Hasegawa MKV kit, part of the Paragon conv. kit for the prototype, put on a new canopy [scratch] nose, props spare box & added scratch rounded wing tips, also on the underside has an enlarged radiator
Bob.
  • Alburymodeler likes this
#12 A.Wolf Grant
A.Wolf Grant
    Senior Member
  • LSP_Members
  • 1,481 posts
  • Gender:Male
Posted 22 August 2012 - 10:21 PM
Wow, this is one to watch. Love the way you show your previous builds as a sign off - very inspiring and more than a little interesting.
Grant.
Grant
Facebook: https://www.facebook...wolfscalemodels: twitter: @Arrowwolfmodels
++ LSP Members receive a 10% Discount on purchases over £50! PM me for the Code ++ Overseas customers have the Sales Tax returned where the delivery address is outside the EU ++Free Shipping with the UK / EU on orders over £100 ++
#13 elric
elric
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 307 posts
  • Gender:Male
Posted 22 August 2012 - 10:37 PM
Thanks Grant,
you might find it a bit much by the time this is finished when I said I had built 21 spits in 1/32 scale, that was for the start of 2011, the bug bit me & by Telford the UK Nats I had completed 28. Now it is 2012 the Mk17 will make it 32 that might be the last because my love is race planes & I have a few piling up in my stash to build.
Bob.
#14 Kagemusha
Kagemusha
    Senior Member
  • LSP Moderator
  • 9,800 posts
  • Gender:Male
Posted 23 August 2012 - 02:08 PM
Hi Bob,
Have you got the right nose for the Seafire, yours looks like a Spitfire XIV nose, whereas for the Seafire XVII you need the shorter Griffon nose as per the Spitfire XII. I sincerely hope this helps - it's a really nice project.
Andy
#15 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 12,289 posts
  • Gender:Male
Posted 23 August 2012 - 05:25 PM
Good stuff Bob - impressive work so far (you obviously enjoy your Spitfires). I shall enjoyn watching this build :popcorn:
Derek
Derek Bradshaw
" Are we not men?...Nay, we are but model makers?..."
