Hobbycraft Sea Fury – Hawker Company demonstrator G-AKRY
  • Please log in to reply
431 replies to this topic
#421 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 5,797 posts
  • Gender:Male
Posted 18 May 2013 - 11:47 PM
Peter
The light bulb finally went off. Scribe the primer and paint but not the bare plastic.
:D
Peter
On the Bench
Hasegawa P-47D Thunderbolt "The Farmingdale Jug"
Tamiya 1/350 HMS King George V
Airborne:
Tamiya Spitfire Mk,IXc  George "Buzz" Beurling, Canadian Leading Ace
Tamiya P-51D Mustang... Big Beautiful Doll
Trumpeter F8F-1 Bearcat
#422 airscale
airscale
    Hooked For Life
  • LSP Sponsors
  • PipPipPipPipPip
  • 270 posts
  • Gender:Male
Posted 20 May 2013 - 06:01 PM
evening ladies..
so, last time I posted I said the fuselage was ready for scribing....  well, I lied....
I had a bit more to do, in fact a day's worth of prep to get a good, polished primer base and all the little dinks and scratches sorted out. I also wanted to try and capture different panel structures around the cowl by trying masked panels with thicker primer...
...first up, after filling the main bits that needed attention and little bits that were uneven with mr surfacer, I masked the panel across the nose to tie in the two vent panels added earlier from brass shim...
...then masked the central panel and gave it another blast of primer...
...then worked the entire surface with micromesh, from grade 1500 to 12000 to get a glassy polished finish..
...this is where the new tail was added and a card fairing made to replace the tailwheel gear doors that were missing on G-AKRY...
...and hopefully here you can see the panel that was masked in with primer - I intend to scribe it's border so it remains to be seen whether after paint the difference in finish can be seen...
...next up is a world of pain in trying to scribe and rivet the fuselage - I guess I will have to find a bit of sponge or something to hold it steady on the bench while I make those 'one chance only' swipes with a scribing tool...
until next time...
Peter
  • MARU5137 likes this
airscale donates a % of sales to the Royal Air Force Association to remember 'the few' RAFA
#423 MostlyRacers
MostlyRacers
    Senior Member
  • LSP_Members
  • 1,173 posts
  • Gender:Male
Posted 21 May 2013 - 10:08 AM
I keep lurking in awe at this project, and have never expressed my appreciation of the outstanding work being done !
Well, now this is a rectified mistake :)
:popcorn: :popcorn:  :popcorn:
Hubert
#424 airscale
airscale
    Hooked For Life
  • LSP Sponsors
  • PipPipPipPipPip
  • 270 posts
  • Gender:Male
Posted 21 May 2013 - 08:14 PM
Thanks Hubert - glad you are enjoying it :)
haven't had much time today, but at last I can finally breathe out....
scribing is the most nerve wracking part of modelling (construction anyway) and setting about a finish you have laboured over with sharp implements is not good for the heart...
first up, I scribed the main vertical panel lines, and then glued a bit of cotton into the prop hub so I could have a reference for the thrustline - this is critical to get the other panels oriented..
..then some dymo tape as a guide...
...and one panel is done... phew...
...got a few more done before packing up for the night and sharing with you good folk..
..until next time...
TTFN
Peter
#425 alaninaustria
alaninaustria
    Senior Member
  • LSP_Members
  • 3,475 posts
  • Gender:Male
Posted 21 May 2013 - 09:56 PM
Great work Peter! I really enjoy scribing... it took me awhile to get it sorted, but I learned to start with patience, measure thrice and scribe once!! I really like the idea of using the thread to set a level from which to measuer other scribes.... I usually measure everything and then use tamiya tape to mark the lines, then draw them using a fine pencil... then when all the lines are drawn on I place the dymo tape where the lines are drawn... but the dymo tape erases some of the lines... but, your method using the thread elliminates this problem. Excellent work mate! It really is true that we learn something everyday don't we!!
Thanks for sharing this tip...
Cheers
Alan
Recreating WWII aviation history in 1/32..... one plane at a time!
Stalled builds...
1/32 scale Big Jug... T-bolt stalled.... gotta get around to finishing this one!
Dreaming of.....
1/32 B-26 Marauder
1/32 Lancaster Bomber
1/32 B-24
1/32 Me 410
1/32 Ho 229
1/32 Do 335
1/32 Yak 3/7
1/32 Saab Drakken
We can dream ..... can't we!?
#426 MARU5137
MARU5137
    Senior Member
  • LSP_Members
  • 4,601 posts
  • Gender:Not Telling
Posted 22 May 2013 - 04:29 AM
Peter,
Very impressive workmanship and inspirational too.
:clap2:
:popcorn:
..... La calma è la virtù dei forti !
Potius Mori quam foedari.
#427 Out2gtcha
Out2gtcha
    Senior Member
  • LSP_Members
  • 6,954 posts
  • Gender:Male
Posted 22 May 2013 - 05:24 AM
GREAT stuff Peter! I agree on the scribing. Im not nearly as good at it as you obviously are but Im learning. I think I just get lazy sometimes.  :lol:
Looking forward to more updates     :popcorn:
#428 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 5,797 posts
  • Gender:Male
Posted 22 May 2013 - 10:49 PM
Peter
Aces on the scribing. If only I was able to do mine half as good, I wouod be one happy camper!
Keep 'em coming
:popcorn: :popcorn:
Peter
On the Bench
Airborne:
#429 TaffyMan
TaffyMan
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 431 posts
  • Gender:Male
Posted 22 May 2013 - 11:17 PM
Nice to see this lady moving on again. The redo of the tail is spot on mate – join what join. Also the re-scribe is brilliant , I’m with the others that I would be ecstatic to get something that looked half as good.
Right pull up the seat and reach for more popcorn :popcorn:
More please - Taff :D
#430 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 15,982 posts
  • Gender:Male
Posted 22 May 2013 - 11:25 PM
That scribing is really terrific Peter! Clean and precise. I'm having no end of trouble with my Hughes racer in this regard (I've given up actually), so right now I'm highly envious!
Kev
#431 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • 3,169 posts
  • Gender:Male
Posted 23 May 2013 - 09:37 AM
Sweet line-work.
Sincerely,
Mark
#432 airscale
airscale
    Hooked For Life
  • LSP Sponsors
  • PipPipPipPipPip
  • 270 posts
  • Gender:Male
Posted 25 May 2013 - 08:39 PM
thank you chaps - how very kind you all are :)
I struggled too with scribing but as in an earlier post, the answer is definately scribe primer, not plastic - so much easier and zero fuss or clean up#
I really like Radu's tools, and today it was out with the rivet wheel. Good reference is a must to know the detail of how the airframe was riveted together - I don't trust plans so rebuild pics are normally most helpful. For the Sea Fury this is Meier Motors or Sanders Auronautics who have excellent galleries of their fine work..
Here is the fuselage centre section, nicely showing the rivet pattern...
..and so a start is made - usual method, using Dymo tape as a guide and micrometer for measurement..
...and then started laying out the rear fuselage - not much more to say, hardly a 'riveting' build is it...
...still loads more to do so this might get a bit dull for a while..
TTFN
Peter
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
