Tamiya Spitfire Mk.VIII
  • Please log in to reply
112 replies to this topic
#16 MARU5137
MARU5137
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 4,577 posts
  • Gender:Not Telling
Posted 21 May 2012 - 09:01 AM
WOW !! Good work... :goodjob:
..... La calma è la virtù dei forti !
Potius Mori quam foedari.
#17 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 22 May 2012 - 03:26 AM
Wow that cockpit is fantastic.
Great paintwork.
Oliver
Thanks Oliver, I do appreciate that!
Frank, really check the fuselage mating surfaces or anything that might be hindering the fuselage halves from coming together cleanly. This is one kit that fits so well, you shouldn't have need for any filler at all on the upper spine. Any extra work here will go a long way to preserving the extremely fine rivet detail by minimizing unnecessary sanding. I found I had to use a little Mr. Surfacer 500 on the lower wing to fuselage join but that was very minimal. The only area I found that gave me any real grief at all was the gun inserts on the wing leading edges. That really surprised me as the entire rest of the kit just wants to fall together.
Keep up the good work Frank!
Cheers,
Wolf
Thank you for the advice Wolf, I will be certain to go back and see where I need to adjust the fit, good to know it is me and not the kit! I tend to make those kinds of boo-boos on each build and it always comes back later to bite my in the $%&!
Thanks mate, I am so happy to hear your are enjoying this one!
-Frank
Remember, not all who wander are lost.
ON THE BENCH
Tamiya P-51D
FINISHED
Hasegawa Ki-84 Hasegawa Bf-109G-14AS Tamiya F-16 Tamiya A6M5 Zero Tamiya F-16CJ Tamiya Spitfire VIII
#18 harvey
harvey
    Senior Member
  • LSP_Members
  • 6,700 posts
  • Gender:Male
Posted 22 May 2012 - 04:40 PM
Very good work Frank. Glad to see you do one of these. Looking killer !..........Harv :popcorn:
There's a fine line between cuddling and holding someone down so they can't get away
working on:
Trump P-38M
#19 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 22 May 2012 - 10:32 PM
Thanks Harv! So far so good, but you really have to be on your toes with this one! One little oversight and it can really ruin your day. Nothing bad to say about the kit, just demands some respect- especially for the engineering that went into it- WOW!
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
#20 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 24 June 2012 - 01:53 AM
Hard to believe it's been over a month since I updated this build! I have been working steadily on this kit, and enjoying it immensely. I have managed to sort out the fuselage seams, build most of the wing, the tail surfaces, and the engine. So far, the only things I have been unimpressed with are the fit of the wing gun inserts, the sloppy PE hinges (causing all of the control surfaces to droop, OK on the elevators but not the ailerons) and the seam across the surface of the elevators, right between the rib tapes. A bit challenging to get smoothed out without damaging the details. I am building mine flaps up, and was a bit concerned with how the parts would fit in the retracted position. I needn't have worried! They fit very snugly indeed. Here are some photos to show I am actually making progress, thanks for looking in!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
#21 Pfuf
Pfuf
    Senior Member
  • LSP_Members
  • 2,399 posts
  • Gender:Male
Posted 24 June 2012 - 06:48 AM
Hi daywalker nice progress I see you got the same little troubles as I did especially the wing gun inserts.
Johan
#22 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 24 June 2012 - 12:51 PM
Thank you Johan! Yes, those inserts are certainly not any fun to sort out! I got the outer two on the left wing sorted out, using layers of CA glue , sanded once cured. One has to be very careful sanding so as not to destroy the details around them. It's hard to show how poorly they fit, but the before and after photos here might help show it:
Before
Posted Image
Posted Image
After
Posted Image
Posted Image
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
#23 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 15,958 posts
  • Gender:Male
Posted 24 June 2012 - 01:01 PM
Great work Frank!
Kev
#24 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 26 June 2012 - 01:48 AM
Thanks! More progress on the Spit...
The wing is complete, with the gun inserts sorted out, the ailerons mounted rigidly (those bloody hinges make them both flop down), and the wingtips mounted. I was very disappointed in the hinged ailerons, they are so loose that both just flop into the downward position. The Tamiya Zero was the same way. So, I added tiny strips between the ailerons and the wing and glued them solid. Problem solved! I also opted to mount the flaps in the retracted position, and those were very easy to do. I was afraid they might not fit well up into the wing, but they certainly do!
Posted Image
Posted Image
Posted Image
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
#25 Wolf Buddee
Wolf Buddee
    Senior Member
  • LSP_Members
  • 699 posts
  • Gender:Male
Posted 29 June 2012 - 05:26 AM
Frank, I had the same experience with the gun inserts. Not the best fit and I spent more time than I wanted to getting them sorted out. As far as the aileron hinges are concerned, I put a small drop of CA on them where they pivot within the aileron. Not enough to make 'em solid but just enough to impede free movement. Worked perfect and I can position them any way I want and they stay put. I used the same technique with the elevator hinges.
Nice work so far!
Cheers,
Wolf
#26 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 29 June 2012 - 12:16 PM
Wolf- Thank you, and brilliant idea on the ailerons! I'll use that method on the next one. Glued up the rudder parts and tail gear bay, and glued the opened bay option into place as opposed to using the magnetic attachment as I do not plan to ever pose it in flight. Camera batteries dead this morning, so I'll get some more pics once they are charged up again.
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
#27 harvey
harvey
    Senior Member
  • LSP_Members
  • 6,700 posts
  • Gender:Male
Posted 29 June 2012 - 02:43 PM
Very good, my friend ! I will have to build mine sometime. Its the HB MKVb. Thanks for the updates, keep 'em coming......Harv :popcorn:
working on:
Trump P-38M
#28 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 30 June 2012 - 03:23 AM
Thanks Harv, glad you like this build! I do not know a lot about the HB kit, but if you ever get the chance to build the Tamiya kit- by all means GO FOR IT!!! :piliot:
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
#29 zaxos345
zaxos345
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 51 posts
  • Gender:Male
Posted 02 July 2012 - 06:17 PM
Very nice work so far my friend, i have also build the IX one and i know exactly what you mean!!!
John
#30 Daywalker
Daywalker
    Senior Member
  • LSP_Members
  • 2,672 posts
  • Gender:Male
Posted 04 July 2012 - 02:08 PM
Thank you John!
Small update today, the wing is sorted out and I couldn't resist taping up the cowl bits to see that gorgeous Spitfire profile! Little things like that really help keep me motivated. :yahoo:
Posted Image
Posted Image
-Frank
ON THE BENCH
Tamiya P-51D
FINISHED
