Rigging method
  • Please log in to reply
4 replies to this topic
#1 radial
radial
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 152 posts
  • Gender:Male
Posted 09 March 2012 - 01:53 PM
For dougn and all those rigging golden age ac.
Have tried the standard rigging methods, sprue, fishing line, etc. with mixed results. I wanted to be able to install rigging at the end of the build to get a cleaner result. In the 30's the ac were rigged with what was called "streamline stainless wire"; essentially flattened stainless cable. To reproduce this in our scale I decided to flatten commonly available .015" round rigid music wire.
To do this 8" lengths of wire are cut and vise grips are attached to each end and simply drawn across a drum sander attachment on a hi speed drill. 3 or 4 passes on each "side" is enough as
These drums are quite aggressive. The wires are smoothed out with 400 sandpaper.
The finished wires are then cut to the lengths required. The fit method is just trial and error. Cut, bend, dry fit and then do it again. I always flatten twice the number of wires needed.
During this fitting process i make a location diagram for all the wires and set it aside till final install. Inevitably, there will adjustments necessary during final assembly. Gluing is done
With thin ca applied with wire. Not an easy method but it does allow for mistakes.
State of the art drum sander
Posted Image
Wiring diagram
Posted Image
Results
Posted Image
#2 LSP_Mike
LSP_Mike
    LSP Staff
  • LSP Moderator
  • 5,290 posts
  • Gender:Male
Posted 09 March 2012 - 08:04 PM
OK, semi crude, yet oddly very effective. How do you tension the wires? I'd thought of rolling wire through two steel wheels spaced just this :shrug: much apart.
in progress:
1/35 Su-85/ winter- attach to base
1/32 DH-9a USMC
1/32 Mig-3:winter paint and weathering: in progress and base
Yacht America need some parts.
NEXT UP: Me-109G2/R6-on hold
I'm so far behind, I think I'm in first place...
Yes, I built models when I was a kid too.... no they're not toys....
#3 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 5,788 posts
  • Gender:Male
Posted 09 March 2012 - 08:12 PM
Results look really good. I would guess that as long as the wire is stiff, it will look taught before and after gluing in place.
Peter
Peter
On the Bench
Tamiya 1/350 HMS King George V
Hasegawa P-47D Thunderbolt "The Farmingdale Jug"
Airborne:
Tamiya Spitfire Mk,IXc  George "Buzz" Beurling, Canadian Leading Ace
Tamiya P-51D Mustang... Big Beautiful Doll
Trumpeter F8F-1 Bearcat
#4 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 7,595 posts
  • Gender:Male
Posted 09 March 2012 - 10:10 PM
Much like myself. :)
Kevin
35 years ago I started off with nothing; and I've still got most of it!
#5 Dekenba
Dekenba
    Senior Member
  • LSP_Members
  • 704 posts
  • Gender:Male
Posted 26 April 2012 - 08:03 PM
I'm about to have a crack at building a WW1 plane - not sure which one yet, but probably the SE.5a from WNW - using Radu's various metal wire's, turnbuckles & terminals.
Should be fun. I'll take some photo's.
Full time pre 1946 model collector. Planning career change to builder.
