SG 500 Jagerfaust - Master pattern completed
  • Please log in to reply
74 replies to this topic
#1 Derek B
Derek B
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 8,863 posts
  • Gender:Male
Posted 25 February 2012 - 02:54 AM
...and the next one please...
Some pics of the start of my next EMD master pattern WIP; a set of SG 500 Jagdfaust weapons for the Hasegawa 1/32 Me 163 Komet.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
(BTW, Radu's RB Productions Contour cutter saw sets are simply awesome!)
Derek
Edited by Derek B, 13 November 2012 - 06:49 PM.
Derek Bradshaw
" Are we not men?...Nay, we are but model makers?..."
High quality products made
for modellers by modellers
#2 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 7,603 posts
  • Gender:Male
Posted 25 February 2012 - 04:06 AM
These are the downward firing hollow charge weapons?
Kevin
35 years ago I started off with nothing; and I've still got most of it!
#3 Loic
Loic
    Senior Member
  • LSP_Members
  • 2,485 posts
  • Gender:Male
Posted 25 February 2012 - 11:13 AM
Very interesting and unusual Derek :speak_cool:
Makes me realise I work with stoneage toolings :hmmm:
Cheers,
Loïc
_______________________________________________________________________________________________________________________
In the work :
Dornier Do 335
Completed builds :
Hawker Tempest
Nakajima B5N Kate
Spitfire Mk I
DB-603 Engine Master Pattern (on sale)
#4 Ads
Ads
    Senior Member
  • LSP_Members
  • 2,295 posts
  • Gender:Male
Posted 25 February 2012 - 11:29 AM
Great stuff Derek!Posted Image
Ads
Posted Image
#5 AndersN
AndersN
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 394 posts
  • Gender:Male
Posted 25 February 2012 - 01:09 PM
Cool! Now I have to get a Hasegawa Komet :)
Will this be complete wings or just inserts?
Cheers
#6 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 25 February 2012 - 02:46 PM
They certainly are Kevin!;)
Derek
Derek Bradshaw
#7 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 25 February 2012 - 02:49 PM
Thanks Loic - I generally use whatever tools I have to hand, which generally means the same few worn out tools!:lol:
Derek
Derek Bradshaw
#8 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 25 February 2012 - 02:51 PM
Ads
Thanks Ads :D
Derek
  • Ads likes this
Derek Bradshaw
#9 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 25 February 2012 - 02:52 PM
Cheers
Thanks Anders - they will be inserts.
Cheers
Derek
  • Ads likes this
Derek Bradshaw
#10 JRutman
JRutman
    Senior Member
  • LSP_Members
  • 3,495 posts
  • Gender:Male
Posted 25 February 2012 - 03:32 PM
Cool idea Derek,
This weapons system would look right at home on "Captain America"
J
#11 Tnarg
Tnarg
    Senior Member
  • LSP_Members
  • 578 posts
Posted 25 February 2012 - 04:24 PM
This is my favorite Komet besides the red one.
Thanks for making this one.
Tnarg
#12 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 25 February 2012 - 07:28 PM
Jerry/Grant...Thank you gents :clap2:
Derek
Derek Bradshaw
#13 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 27 February 2012 - 03:29 PM
A little more progress...
Many modellers tend to find problems getting their two part epoxy Milliput putty to work exactly the way that they want to. There are some simple steps that can be taken to ensure that you are guranteed reliable setting of the putty - no matter how old the pack is! (I had - until recently - regularly used packs that were over ten years old successfully). Here is how I do it:
Posted Image
As can be seen above, most of my packs of Milliput are over three and a half years old - I shall select the oldest standard (grey-green) pack of Milliput for use...
Posted Image
As can be seen, with age, the two sticks (hardener and putt) become affected on their outer surfaces. The green stick has a very fine (almost microscopic) crystalisation effect all over, whereas the hardener stick develops a hard outer skin (looks pretty much like a suasage - the older the stick is, the darker and thicker becomes this 'skin').
Posted Image
The stick of putty (green stick) is generally OK, so apart from removing any hardened areas of surface crystallisation, no further action is required with this particular stick. The trick is to remove all traces of the dark brown skin areas off the other grey coloured stick - leaving any signs of this skin in the putty will cause voids, soft areas or hard inclusions. Here is the start of the removal process of the darker areas from the stick.
Posted Image
You can see that I have cut three slices here as I intens to mix enough for three good sized balls of putty. The 'skinning' process continues. You'll also notice that unusually, there is also a vein of the darker material running centrally through the stick - this also has to go, so the slice is torn open and the darker material is picked out - you are aiming to obtain
a completely uniform grey blob of putty. This does cause a little wastage, but you want a well mixed putty that will set smooth and rock hard without any internal soft spots, so it is worth the small sacrifice.
Posted Image
Two balls of grey putty ready, one more to go...
Posted Image
Here we have all three grey hardener balls and they are now matched with three green putty balls. I roll them into balls as the human eye seems to be very good at comparing sizes in this mode, which means that you will be able to mix two equal quantities of both putty balls together with great accuratecy (Milliput is mixed to a ratio of 1:1).
Posted Image
Here is the first two balls (of grey and green putty) mixed together. It is important to ensure that they are mixed together thoroughly, so much breaking apart and kneading is required until the whole ball is a uniform colour (sort of RLM 02 greenis-grey) - you know when it is ready, it goes very sticky and warm. I have used vaseline liberally on the insides and outside of the Komet wings as a release agent prior to applying the Milliput.
Posted Image
First amount of Milliput applied to the Komet wing, which is taped together and the insert apertures filled with Milliput. The second ball of Milliput is just about to be mixed.
Posted Image
The second ball of Milliput is mixed and is inserted into the wing just prior to it being trapped between the two wing halves.
Posted Image
Both wings have now been filled. Onmce hardened, these will create the SG 500 wing insert master patterns for both wings. Although these should be rock hard in 24 hours, heat can harden them faster, so they have now been propped up on my radiator overnight, so they should be good to go by this evening!
HTH
Derek
Derek Bradshaw
#14 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 7,603 posts
  • Gender:Male
Posted 28 February 2012 - 03:06 PM
Boy can I relate;... a few years ago I used some improperly mixed Milliput, and it oozed yellow crud for months.
Kevin
#15 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 8,863 posts
  • Gender:Male
Posted 28 February 2012 - 05:10 PM
:) (...Occasionally Kev, I still wear the Tee-shirt...)
Derek
Edited by Derek B, 28 February 2012 - 05:11 PM.
Derek Bradshaw
