Good airbrush for LSP's
  • Please log in to reply
21 replies to this topic
#1 LScale
LScale
    Newbie
  • LSP_Members
  • Pip
  • 9 posts
Posted 09 February 2012 - 07:15 AM
Hi
I have been using a Starmax spaygun and I liked using it to spray the larger airframes, but I need a replacement. I'm getting the Aztec broad stroke airbrush, I have no idea how that will go but can anyone recommend an airbrush/spraygun? I find the 0.3 and 0.5 mm gravity fed airbrushes hard to use on a 1/32 F-14 or c-130 or whatever.
#2 DougN
DougN
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 1,695 posts
  • Gender:Male
Posted 09 February 2012 - 08:26 PM
Personally, I love the Paasche H for all but the finest detail work (and for that I love my H&H Infinity) been using mine for 22 years now. The set usually comes with the 1,3 and 5 tips/nozzles, although I typically use the #1 for everything except clearcoats, and then I use the #3. Very easy to use and clean.
Doug
#3 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 7,595 posts
  • Gender:Male
Posted 09 February 2012 - 11:38 PM
Doug
I'll second that. My H series Paasche has served very faithfully for years. Before that was a Badger 350, which also worked very well for an inexpensive tool. Some of the earlier models I built for competitions (where I actually was fortunate enough to place), were painted with that old Badger.
Kevin
35 years ago I started off with nothing; and I've still got most of it!
#4 LScale
LScale
    Newbie
  • LSP_Members
  • Pip
  • 9 posts
Posted 10 February 2012 - 02:48 PM
I have a Paasche H set I bought in about 1987, I think I used it once and forgot about it after I settled on the VL model back then. Having dusted the H off and run some air through it I think it may do the job, cheers!
#5 Shane aka Smokey
Shane aka Smokey
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 144 posts
Posted 27 May 2012 - 09:39 PM
I'm late to the topic, but I have an Iwata hp tr2 (http://www.amcsuppli...roducts_id=2521 that I use for doing large areas, it'scomfortable to use for longer periods, sprays well and has a good sized paint cup.
#6 wingything
wingything
    Newbie
  • LSP_Members
  • Pip
  • 2 posts
  • Gender:Male
Posted 05 July 2012 - 09:45 AM
I use badger 200 for large base coats and my Badger 150 Anthem for camo work. I use the new Iwata NEO for smaller camo detail work. Love them all, easy to clean and repair.
Bob
For good or for ill, air mastery is today the supreme expression of military power and fleets and armies, however vital and important, must accept a subordinate rank.
Prime Minister Winston Churchill
#7 Bill Cross
Bill Cross
    Senior Member
  • LSP_Members
  • 882 posts
  • Gender:Male
Posted 05 July 2012 - 04:09 PM
I love Grex airbrushes, especially their Tritium series. I reviewed one here(paid for it out of my own pocket, it was not a sample sent for review).
Associate Editor at Armorama(http://www.armorama.com)
Current (stuck) projects:
Tasca Firefly diorama
Trumpeter BR-52 Kriegslok with ALL the PE (groan)
Future projects:
Revell of Germany JU-88A
Tamiya Zero
Hasegawa P-47D Bubbletop
#8 D Bellis
D Bellis
    Senior Member
  • LSP_Members
  • 2,116 posts
  • Gender:Male
Posted 18 July 2012 - 09:19 PM
..and my Badger 150 Anthem for camo work.
The Badger 150 and 155 Anthem are completely different animals.
I have both the 150 and 155, but prefer using my 150 for just about everything from R/C models to 1/72 airplanes. That's probably because I have been using the 150 longer (same airbrush since 1987). The 150's IL tip will allow for as small as about a 3/32" spray pattern, while the HD tip will go as big as 1½" or so.
I've tried other airbrushes, and settled on suction-feed, internal mix, dual-action airbrushes as working the best for me. Your milage may vary.
HTH,
D
You can lead a person to information, but you can't make them think.
#9 DrDave
DrDave
    Senior Member
  • LSP_Members
  • 2,664 posts
  • Gender:Male
Posted 18 July 2012 - 11:11 PM
I love my Iwata Tr2
Long live gratuitous use of the exclamation mark!
#10 blackbetty
blackbetty
    Senior Member
  • LSP_Members
  • 3,082 posts
  • Gender:Male
Posted 19 July 2012 - 05:21 AM
badger 150 here too, mine is over 25 years old
back after 20 years
#11 Cunumdrum61
Cunumdrum61
    Senior Member
  • LSP_Members
  • 691 posts
  • Gender:Male
Posted 19 July 2012 - 07:50 AM
For large areas I also use a Badger 150 and sometimes a badger 200. I use the H&S Infinity for other fine work. Still love the old Badgers!
#12 BradG
BradG
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 428 posts
  • Gender:Male
Posted 21 July 2012 - 10:09 AM
Aztek A470 double action all the way for me. I've used badgers and I dislike the weight and the fact they aren't comfortable to use for long periods.
#13 Out2gtcha
Out2gtcha
    Senior Member
  • LSP_Members
  • 6,953 posts
  • Gender:Male
Posted 21 July 2012 - 10:27 AM
Still love my exceptionally durable and comfy Iwata HP-CS --
Posted Image
I bought a really nice quick release for it, that my buddy PeteG and i both use, as it works with his H & S 2 in 1, which I may still invest in someday for fine line stuff.
I have noticed that the H & S 2 in 1 is much more delicate than teh Iwata when it comes to the needle and internal parts. The 2 in 1 is more delicate, but can produce finer lines, but my Iwata is one of, if not THE best all around airbrush Ive owned.
#14 GaryK
GaryK
    LSP Member
  • LSP_Members
  • PipPipPip
  • 42 posts
  • Gender:Male
Posted 23 July 2012 - 09:14 AM
Can someone tell me if the paint bottles are compatible between the Paasche and Badger?
If I find a deal on them I would like to get a bunch of them if I could use them with either brand since I have both.
Thanks
Gary
Texas via California
#15 Brett Barrow
Brett Barrow
    Newbie
  • LSP_Members
  • Pip
  • 4 posts
Posted 07 August 2012 - 05:38 PM
Thanks
Yep, they're the same. The difference is usually the size of the caps, 3/4oz. are 33mm, 1/2oz. are 28mm. Both brands have siphon tops for each size, and they're interchangeable between different brands' similar models (e.g. 150,155,200=VL, 350=H).
