1/32 Tamiya P-51D
#46
Posted 04 March 2012 - 07:51 PM
Kev
Finished: Revell Dora | Hasegawa Emil | Revell Zero Rebuild | 21st Century C.202 | Tamiya A6M5 Zero | Hasegawa Avia S-92 | Hasegawa Fw 190D-11 | Matchbox Sea Venom | XS-Models Hughes H-1
In Progress: Hasegawa Fw 190S Conversion | Matchbox Spitfire 22/24 | Birdcage Corsair the Hard Way!
Shelf of Shame: Revell X-1 | Matchbox Emil
#47
Posted 04 March 2012 - 07:55 PM
working on:
Trump P-38M
#48
Posted 04 March 2012 - 08:09 PM
Thanks!
Ron
I always wait for the paper each morning. I look at the obituary column and if I’m not in it, I go to work.
#49
Posted 05 March 2012 - 01:06 AM
Dan
#50
Posted 05 March 2012 - 01:50 PM
Finished the national insignias.
Select outermost portion of mask first. A technique to aid emplacement is to attach semi-rigid backing paper or cardboard as shown to give some rigidity
when positioning mask.
All masks in place. Sliced wing mask at bottom to get it to lay around countour better. Put masking tape over slice to prevent overspray.
Used same mix of paint - 25 parts white, 1 part yellow and touch of black. Added additional masking for overspray and layed down the white. Keep your
spray angle at 90 degrees with light coats especially where mask covers contours. Also go extra light with white around border to prevent visible white
layer between base color (green) and final color (insignia blue). I went a little too heavy on bottom edge and it shows a little in the end.
I allowed 24hrs for the white layer to dry before proceeding.
Next, burnish a strip of masking tape down to remainder of mask. This will help you lift the mask as one piece (may need a little help with #11 Xacto blade).
Place remainder of mask within existing mask (that we used for white layer).
Now we remove the portion to be blue. This portion of mask was only used as and aid to properly position our star and bars.
Apply insignia blue and carefully remove all masking material. You can get creative with your insignia blue here. I used pure insignia blue on the underside
where no sun fading should occur. On the top surfaces I mixed a touch of white in and oversprayed the entire upper wing insignia while I faded the fuselage
insignia with a slightly lighter shade on top as this portion had more sun exposure. The effect is very subtle.
#51
Posted 05 March 2012 - 02:25 PM
Sincerely,
Mark
Look out aviation! Here come dah Duke and King Kong!
Currently, on LSP: Star of Africa, Hans-Joachim Marseille, Yellow 14,
On Hold: Bf109K-4,I./KG (J)6, Bohemia, May 1945, Sinai, 1956; Mustang 2331, The Flying Wing (116) Squadron, Werfer-Granate 21's
Previous Stuff:
Aircraft: Bf109G-14, Erich Hartmann, Bf109G-6, Ludwig Franzisket, Dragon P-51D
Armor: IDF Upgraded M-48A3, c. 1968, 1/25 IDF Sho't, c. 1982
#52
Posted 06 March 2012 - 05:38 PM
Anyone else here jealous?
Dave
#53
Posted 06 March 2012 - 07:51 PM
The new airbrush is a fine specimen....
and seeing your progress is pretty COOL!! Impressive work ..Keep up the good work.
Potius Mori quam foedari.
#54
Posted 11 March 2012 - 03:12 PM
Dave, did you get started on the 109 build?
Pretty much finished with the paint, just a few touch ups here and there, decals and dullcote to go.
No decals so far - all paint.
Edited by Cpig, 11 March 2012 - 03:15 PM.
#55
Posted 11 March 2012 - 03:36 PM
Just loved the masking tutorial, as it is priceless to see how it's done. Masking and markings came out fantastic. Super touch with adding the white to the insignia blue and then the light oversparay. Looks perfect!
Peter
Peter
On the Bench
Hasegawa P-47D Thunderbolt "The Farmingdale Jug"
Tamiya 1/350 HMS King George V
Airborne:
Tamiya Spitfire Mk,IXc George "Buzz" Beurling, Canadian Leading Ace
Tamiya P-51D Mustang... Big Beautiful Doll
Trumpeter F8F-1 Bearcat
#56
Posted 11 March 2012 - 04:33 PM
Sincerely,
Mark
Previous Stuff:
#57
Posted 11 March 2012 - 08:35 PM
YOWZA! Very sharp.
Indeed!
#58
Posted 11 March 2012 - 09:16 PM
Kev
#59
Posted 19 March 2012 - 12:12 AM
When finished, you'll have to send some pics. to Bud Anderson's son, Jim so he can put them up on Bud's website!
John
#60
Posted 23 March 2012 - 08:00 PM
Thanks for the compliments, much appreciated. Greiner, I may just do that; great site btw, lots of useful information there.
Hadn't had a lot of time lately but finally got a little in on the decals (all three of em) and dullcote. Went ahead and made the nameplate decal myself. Hopefully I'll be close to finishing this weekend.
Edited by Cpig, 23 March 2012 - 08:03 PM.
