1/32 - Spitfire Mk I
  • Please log in to reply
139 replies to this topic
#1 Loic
Loic
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 5,930 posts
  • Gender:Male
Posted 13 December 2010 - 01:29 PM
Hello everybody!
Guys, I miss the group builds thingy and I have a Revegawa Spitfire I started long time ago that is begging me to finish it.
It is a Revell and Hasegawa combo issue, sold by revel with the Hase fuselage from Mk V and a pair of Mk I new wings.
The point is that I think it is argueingly well over the 25% limit due to some detailling work that has already been done :D .
I asked LSP Dave if he would accept me in ( Dave, please check your PM ) and I am waiting for his answer.
I guess it is also important to ask you guys if you would accept me in.
So, please let me know if it is OK with you that I enter this build assuming I wont participate to any kind of pol for eventual price, etc... I only want to be a part of the GB ;)
Cheers all,
Loic
Cheers!________________________________________________________________________________________________________
In the work :   Dornier Do 335   /   A-1H/J Skyraider   /   Mirage F1 (Scratchbuild)  /  Mirage IIIC
Completed builds :   Hawker Tempest (kitbash)   /   Nakajima B5N Kate (Scratchbuild)   /   Spitfire Mk I
Master pattern work:   DB-603 Engine    /   F4U-1 Corsair engine bay
#2 big matt
big matt
    Senior Member
  • LSP_Members
  • 2,308 posts
  • Gender:Male
Posted 13 December 2010 - 04:06 PM
Hey Loic!
I look forward to seeing what you can do with the old bird. I have the original Revell boxing and would love to see you work your magic.
Matt
We are all your base.
#3 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 13 December 2010 - 06:34 PM
Thanks Matt,
lets wait and see what the other and mods think.
Cheers,
Loic
#4 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,804 posts
  • Gender:Male
Posted 13 December 2010 - 07:58 PM
I'm OK with it Loic. We'll just pretend that your progress so far was made during the course of this GB. :coolio:
Kev
#5 Allok
Allok
    Senior Member
  • LSP_Members
  • 3,632 posts
  • Gender:Male
Posted 13 December 2010 - 11:32 PM
Sounds good to me, let's see it...
Don't you wish some people would use glue...
Instead of lipstick?
#6 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 14 December 2010 - 06:34 AM
Thanks a lot guys !
I will post a first batch of pic when I am back from work later today.
Cheers,
Loic
#7 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 14 December 2010 - 12:03 PM
Hi,
as promised, here is a first batch of pictures of the cockpit as a start.
It was done several years ago and I had no digital camera then so I unfortunatly have no in progress shots.
Anyway, I hope you will like it.
The sidewalls to start with.
The details are mainly done with electrical cables and fake stickers.
Posted Image
Posted Image
Then, the seat assembly unit.
The seat was equiped with a "leather" cussin and eduard belts (early type).
The armor plate was thinned.
The control stick was detailled with clothe string to replicate the typical aspect of the handle, it was thinned and detailled with lines/pipes, etc... Also, the sides of the stick have been discarded so one can see the chains/cables.
The rudder controls have been detailled with straps and set up with an offset to match the rudder orientation.
The floor has been detailled also with cables, etc... and the structure was reworked, the holes are done with dremell tool.
Finally, the IP was hand painted.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Here are 2 shots of the sides assembled with the seat unit.
Posted Image
Posted Image
Last but not least for the pit, I have made yesterday a small part to replicate the fuel tank that will be fitted in from of the rudder control. We wont see much of it when the fuselage is closed but in case someone lurk in there...
Posted Image
That's more or less it for the cockpit area ;) , still to come are port wing details with open gun bays and an engine :D
Hope you like it guys,
Cheers,
Loic
Edited by Loic, 14 December 2010 - 12:09 PM.
  • MARU5137 likes this
#8 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 16 December 2010 - 09:51 PM
Hi there!
I have been away for a while but managed to find some time tonight to post some more pics.
So, time for engine work! The base is actually the Hasegawa P51 engine. I have removed a few parts and added a lot of details made from electrical wire and card.
The engine chassis/frame/mount was made from aluminium tubing and card. I actually use some electrical wire that I slide into the tubing in order to have a mount that is still flexible thanks to the wires but stiff enough so it does not fall in pieces when to test fit it. Then, when you are reasonably happy with the all thing, you start to progressively (little by little) put some super glue into the "joints" until everything is rock solid. Adding the glue little by little allows adjustement to be made during the process. I have also used this technic to create a Hurricane cockpit frame and it works great!
so, once again, it is all assembled and painted, I have no WIP pics unfortunatly but you got the idea I suppose:
Posted Image
Posted Image
Posted Image
Edited by Loic, 16 December 2010 - 09:56 PM.
#9 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 16 December 2010 - 09:53 PM
Posted Image
Posted Image
Posted Image
#10 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 16 December 2010 - 09:57 PM
Posted Image
Posted Image
Posted Image
#11 Loic
Loic
    Senior Member
  • LSP_Members
  • 5,930 posts
  • Gender:Male
Posted 16 December 2010 - 09:58 PM
Posted Image
Posted Image
Hope you like it!
Cheers,
Loic
#12 Out2gtcha
Out2gtcha
    Senior Member
  • LSP Moderator
  • 22,057 posts
  • Gender:Male
Posted 17 December 2010 - 12:02 AM
Hope you like it!
Understatement!! VERY nice engine work. Love it!
Brian
#13 Troy Molitor
Troy Molitor
    Senior Member
  • LSP_Members
  • 1,624 posts
  • Gender:Male
Posted 17 December 2010 - 01:40 AM
Wow, nice looking Spit there, Bud.
Troy
#14 Troy Molitor
Troy Molitor
    Senior Member
  • LSP_Members
  • 1,624 posts
  • Gender:Male
Troy
#15 Derek B
Derek B
    Senior Member
  • LSP_Members
  • 12,289 posts
  • Gender:Male
Posted 17 December 2010 - 10:17 AM
Hi Loic,
Watching one of your builds is a bit like reading a well loved book - very enjoyable!
:goodjob:
Derek
Derek Bradshaw
" Are we not men?...Nay, we are but model makers?..."
