Revell P-51B Mustang
  • Please log in to reply
85 replies to this topic
#76 bdthoresen
bdthoresen
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 1,821 posts
  • Gender:Male
Posted 18 December 2009 - 11:00 AM
Adrian-
I like the work so far, especially seeing as how this is your first project with p.e. Do not be too hard on yourself about it's use! It looks a million times better than the crap Revell gives you!
By the way, the blades went into the post yesterday. They should be there soon. Pulled out the Revell prop for comparison- Man those blades are way too thin- These I am sending you will change the look of the completed model for sure!
Keep up the good work mano!
THOR
Is the enemy of my enemy my friend?; or just another a**hole?
#77 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 07 January 2010 - 05:40 AM
Whew - it's been a while since I touched this build.
The Holidays just seem to absorb any modeling time I had.
Hopefully, I'll be able to start doing a little here & there on this build & my Lightning build.
Thanks for the Blades Thor, I appreciate it!
They look great compared to the thin Revell Kit parts - if I don't pooch mounting them anyway. I'll have to figure out how to mount those suckers this weekend.
In the Works -
1/24 Airfix P-51D Mustang'Petie 3rd'
1/32 Trumpeter P-38L (Aircraft of the Aces Group Build)
Next Up
1/32 Trumpeter P-51B Mustang 'Shangri La'
#78 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 07 January 2010 - 05:46 AM
I also got a tail wheel bay in from Jerry Rutman.
Jerry did a great job on this part - it took the pressure off of me for sure.
If you've ever built this kit, you know the kit tail wheel gear is crap - it breaks if you look at it too hard.
Jerry solved that problem with a metal gear, so I got one from him - but I was scratching my head on how to mount it. I had thought of using a brass or styrene tube drilled out - then Jerry did the wheel well & problem solved.
In the Works -
Next Up
#79 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 07 January 2010 - 05:49 AM
I bounced around a bit tonight on this and worked on an idea for the main gear door hinges.
I started by double punching a few discs of styrene for the hinges.
In the Works -
Next Up
#80 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 07 January 2010 - 05:53 AM
I played with cutting a few but ran out of time.
I'll need to get the proper (or close enough) angle of the doors to cut them. Then I'll attach a piece of sheet styrene on the doors & glue the hinge piece - well that's the plan anyway.
Thanks for looking in - not much tonight but at least I'm back at it again.
Adrian
In the Works -
Next Up
#81 Spads57
Spads57
    Senior Member
  • LSP_Members
  • 1,040 posts
  • Gender:Male
Posted 07 January 2010 - 07:43 AM
Adrian,
Your P-51B is looking better with each new update.Keep up the good work my friend.
Regards,
Gregory Jouette
Mississippi
#82 eagledocf15
eagledocf15
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 215 posts
Posted 07 October 2010 - 07:51 PM
It has been a long time. Any updates?
#83 bdthoresen
bdthoresen
    Senior Member
  • LSP_Members
  • 1,821 posts
  • Gender:Male
Posted 08 October 2010 - 10:02 AM
Yeah, c'mon Adrian, what is the deal? I wanna know how this thing is coming along! :rolleyes:
You have done an amazing job so far- Keep cracking at it!
THOR :thumbsup:
#84 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 13 October 2010 - 03:22 AM
Wow, it's been a while since I've been on here and longer since I've done any work on my builds.
Thanks for the comments Greg, eagledoc & Thor and thanks for the bump on the Mustang. I guess I need to dust it off and get back on it & do a bit of work.
It's been even longer since I worked on my Trump P-38 or my Airfix 1/24 Mustang also.
Where does the time go?
I have to admit that I've moved a bit towards the dark side in the last few months tho.
I picked up a few ship kits off of ebay and got a little involved in a couple of them also.
I'm currently doing a bit of work on a Lindberg 'Jolly Roger' Pirate ship (don't let the hokey name fool you, it's actually a great little (1/130 scale) 30 gun Frigate (LaFlore) that I'm building into my version of the 'USS Boston'). I'm also working on a Lindberg Armed Schooner 'Sandpiper' - a great little 10 gun Revenue Cutter / Baltimore Clipper.
Both are excellent sailing ship models, in my opinion.
I think I'll pull the Mustang off the shelf this weekend and see where I stand on it. I need to get a few projects off the bench & on the shelf.
Adrian
In the Works -
Next Up
#85 JRutman
JRutman
    Senior Member
  • LSP_Members
  • 4,746 posts
  • Gender:Male
Posted 13 October 2010 - 02:46 PM
Adrian
You sound like me Adrian,I have about 6 or 7 projects going at the same time. Sort of modelers' ADD. Those sailing ships are great to build man. I am working on converting a Heller HMS Victory to the USS Pennsylvania-120 gun ship of the line.
J
#86 eagledocf15
eagledocf15
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 215 posts
Posted 14 October 2010 - 08:46 PM
I have to admit that I've moved a bit towards the dark side in the last few months though.
Adrian
Hooray for the getting the P-38 and the P-51 work again. The work is much anticipated.
As for the dark side - You must face and conquer it - and show off the work!
