Revell P-51B Mustang
  • Please log in to reply
85 replies to this topic
#16 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 930 posts
  • Gender:Male
Posted 09 December 2009 - 05:58 AM
Last pic of the night
I thought about sanding the plane down and rescribing, but because I'm not really offended by all those rivets on the Revell, I decided to just do some sanding between them just to smooth out a few rough spots on the surface. This worked out pretty well on my 'Ina' build, so I guess I'll give it another go on this ship, and I'll leave my foray into rescribing and riveting for another day.
Thanks for looking in, I appreciate it!
Adrian A.
In the Works -
1/24 Airfix P-51D Mustang'Petie 3rd'
1/32 Trumpeter P-38L (Aircraft of the Aces Group Build)
Next Up
1/32 Trumpeter P-51B Mustang 'Shangri La'
#17 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,382 posts
  • Gender:Male
Posted 09 December 2009 - 07:41 AM
You're doing some great work here Adrian! Good to see these old Revell kits getting some love.
Kev
#18 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 01:24 AM
Thanks Kev, I appreciate it!
I love the old Revell kits, especially the Mustang. It was one of the first big, 1/32 scale kits I ever built in the early 70's. I know they're not perfect but I'm OK with that. I fix or add what I can & don't try to worry about much of the rest.
I do this for the fun of it.
I did a bit of work on the fuse insides by adding some ribbing in the tail wheel area. I thought it a good idea to add a bit of detail there, but if I get a Jerry Rutman tail wheel bay, this will never be seen.
In the Works -
Next Up
#19 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 01:29 AM
Some zinc chromate green & a little touch up work around the ribs & I think it came out OK.
I'll hit it with some touch up green before I put a coat of Future on it & a slight wash.
In the Works -
Next Up
#20 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 01:40 AM
I sanded the framing in the engine bay to help accommodate the ribbing on the cowl piece. I guess that was a bit of a 'Duh' on my part. A little more thought on it & I could have moved the strip forward or back on the cowl piece & missed the framing nearly completely.
In any case, I managed to get the fit pretty close. I'll know more when I actually button up the fuse later & see how it fits then.
I also drilled some holes on the framing. I'll add more to the center line frame when I get it glued together - it's much simpler to get them matched up that way.
In the Works -
Next Up
#21 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 01:49 AM
I started a bit of sanding on the fuse outside also. It had a few scratches in it, possibly from the other sprues.
I'll continue this method for the entire build.
In the Works -
Next Up
#22 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 01:58 AM
I added a bit of interest in the wheel wells. A few bits of various size wires and rubber 'hoses' dresses the wells up
In the Works -
Next Up
#23 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:06 AM
I wanted to do a bit more, but I also didn't want to over-do it because the wells are so shallow
In the Works -
Next Up
#24 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:09 AM
Try as I might, I couldn't find any photos that showed these markings - so they gotta go!!
In the Works -
Next Up
#25 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:15 AM
I used my new clamps to glue the horizontal stabilizers after taking off the Revell info.
In the Works -
Next Up
#26 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:18 AM
Putting the wings together.
In the Works -
Next Up
#27 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:22 AM
The new clamps really worked well on this job. The rubberized tips grab & hold the plastic pretty well. The clothes-pins have a higher tension but have a tendency to slip off.
In the Works -
Next Up
#28 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:28 AM
I added a few more bits & some paint to the wheel wells after gluing the wings.
In the Works -
Next Up
#29 Adrian A.
Adrian A.
    Senior Member
  • LSP_Members
  • 930 posts
  • Gender:Male
Posted 10 December 2009 - 02:31 AM
I've got a few touch ups left to do then I'll do a coat of future & a wash here also.
In the Works -
Next Up
#30 bcauchi
bcauchi
    Senior Member
  • LSP_Members
  • 3,360 posts
Posted 10 December 2009 - 06:37 AM
Nice detail work Adrian, it makes a big difference to this old kit.
