Hasegawa Fw 190S Conversion
  • Please log in to reply
310 replies to this topic
#31 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 27 November 2009 - 07:31 PM
Thanks fellas. I haven't had the chance to use the hot water technique yet, but I'll be giving it a shot as soon as I get any modelling time (down to nearly zero at the moment). My only concern is with the strange rubbery nature of this resin, quite unlike anything I've seen before, but that could be just my general lack of experience with resin parts. I guess I have nothing to lose though!
Kev
#32 Cymru am Byth
Cymru am Byth
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 67 posts
  • Gender:Male
Posted 27 November 2009 - 08:52 PM
Hi Kev
Yes I thought it felt a bit odd to, very soft. There again that could be to your advantage!
Jeez, it does look bad doesn't it? Hopefully you'll be able to figure something out!
Best of luck with it. Any idea on the markings yet :)
Cheers
Si
#33 ruzlkampf
ruzlkampf
    Senior Member
  • Deceased Members
  • PipPipPipPipPipPip
  • 3,175 posts
  • Gender:Male
Posted 27 November 2009 - 09:17 PM
Ooooooh yes, so it begins; :blink: Looks like the modified 'hump' behind the pit is still straight, maybe all you need to do would be to add that to your existing kit? Might be easier than joining up the Hasegawa wings to this? Just thinking aloud to myself. How does new canopy fit to the original kit? Any chance of only modifying just the pit area?
Wheeew yeah, can't wait to see how ya pull this one off Kevin! :) Looks like plastic is gonna be aflyin.
#34 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 22 December 2009 - 09:25 AM
Well, after a mildly diverting detour through a Revellogram Babylon 5 Starfury, and half a Minicraft 707, I stopped for a bit to re-organise and re-furniture my modelling area. To take it for a test drive, I decided to return to this and try to kick start proceedings. Well, it turns out that there's no way I can use the UMI resin conversion with Hasegawa's old-tool kit. UMI's conversion is designed to be used with Hasegawa's new-tool kit, and as such the fuselage parts are modified copies of Hasegawa's parts - their new-tool parts. The old-tool parts are completely different - in dimensions, engineering and construction. Square peg, round hole.
So, what to do? I figure I have two choices now. The first is to track down a new-tool kit and use the conversion as intended. This would do justice to both the build and Si's generosity in donating the conversion. It would also be a little tricky, since I don't have that kit and funds are tight.
My second option is to abandon using the conversion and simply revert to my original plan of scratch-building the thing using my existing old-tool kit (which is the premise under which this thread was started). That would save me money, and utilise my existing kit, but the UMI conversion would go to waste (though I guess I could always do a second one down the track, using the correct kit combinations).
Whaddaya reckon fellas? Which way to turn...
Kev
#35 JamesHatch
JamesHatch
    Senior Member
  • LSP_Members
  • 2,342 posts
  • Gender:Male
Posted 22 December 2009 - 10:10 AM
I'd use the conversion. Si sent me his other set, and with some loving care, it should make a nice 'S'. Some lines may need a little rescribing, and a little plasticard could be used in places, but it provides MORE than an adequate conversion set. Get the new tool Hasegawa kit and use as intended.
#36 bdthoresen
bdthoresen
    Senior Member
  • LSP_Members
  • 1,797 posts
  • Gender:Male
Posted 22 December 2009 - 11:53 AM
I agree with James. Get a new tool kit, as you can find them fairly cheaply online. Get some really hot tap water and start straightening that puppy!
Get cracking!!!!! :ph34r:
THOR. who has not fondled a model in a matter of weeks....
Is the enemy of my enemy my friend?; or just another a**hole?
#37 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 22 December 2009 - 09:26 PM
OK, I guess that answers that question! So, this build is officially on hold until I can source me a new-tool Hasegawa kit. I guess I should try straightening the resin fuselage parts first, because if they won't yield, I'm back to Plan A in any case.
Kev
#38 LSP_Ron
LSP_Ron
    Senior Member
  • LSP Moderator
  • 16,468 posts
  • Gender:Male
Posted 22 December 2009 - 10:14 PM
I agree with Thor and James :)
Ron
I love deadlines. I like the whooshing sound they make as they fly by.
Douglas Adams
When I die, I'll be on time
#39 Hacker
Hacker
    Senior Member
  • LSP_Members
  • 3,899 posts
  • Gender:Male
Posted 23 December 2009 - 05:59 AM
is the Revell offering (hasegawa) old tool or new tool??
WORK IN PROGRESS
1/72 Spitfire prototype and Mk I
1/32 Tiger Moth stalled
1/28 Fokker D III being revamped
FUTURE PROJECTS
1/32 P-51B & D
1/32 Hurricanes
1/32 Spitfire
RESEARCHING ON
Blackburn Shark (32 or 24 scratchbuild project)
#40 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 23 December 2009 - 06:23 AM
I'm pretty sure it's the new-tool kit Hacker. RoG have reboxed a few of Hasegawa's new-tool kits over the last decade (109G, 190D-9).
Kev
#41 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 28 March 2010 - 04:18 AM
Having finally found a little bit of modelling time, I thought it past due that I return to this and try to get something happening. In our last episode, I was planning to attempt to de-warp the resin fuselage halves from the UMI conversion that Si generously sent me.
Well, I tried all right...and failed! I have been concerned all along about the weird rubbery consistency of the resin in the fuselage halves, and I've been reliably informed that this is caused by the resin not being mixed properly before casting. Anyway, as soon as I dunked the parts in the hot water, they went the same way that 2-minute noodles do when you give them the same treatment! Although they straightened up OK in the water, they became incredibly soft almost instantly, and attempted to fold up on themselves as I tried to retrieve them. The left one in particular became impossibly floppy and instantly distorted at my every attempt to fetch it out of the water. I dunked it several times in an attempt to get it sorted, but it just got worse and worse.
The right fuselage half came out OK in the end, but the left one is a write-off:
The second photo shows the large depression my thumb made in the resin as I tried to scoop it out of the pot. :)
So, I guess that rules out the UMI conversion for this project! Or at least the fuselage halves anyway. Once again I'm left with a series of options:
1. Revert to my original plan of using the old-tool kit and scratch-building the conversion;
2. Do the same using the new-tool kit I've since acquired;
3. Attempt to salvage the rear top decking from the resin parts for either option above, as an alternative to scratch-building it;
4. Give up.
I'm leaning towards a combination of #1 & #2. If given a choice between hacking up the old-tool or new-tool kits, I'd prefer to enact that kind of butchery on the old one - especially since the new-tool kit will build quite nicely OOB anyway. Cannibalising the resin parts may save me some scratch-building pain, and save the UMI conversion from being totally wasted. Either way, as Hacker mentioned in an earlier post, it makes for a useful 3D reference.
Oh, option #4 was put in for a bit of irony for anyone who knows me...
Kev
#42 theseeker
theseeker
    Senior Member
  • LSP_Members
  • 1,697 posts
  • Gender:Male
Posted 28 March 2010 - 02:03 PM
Kev,
We all consider option 4 from time to time.
When it comes to heating resin i use this little embossing heat tool I picked up from Hobby Lobby. It gives me better control, unfortunately it only comes in a non masculine color!
Posted Image
I stumbled upon this because I needed something for heat shrink tubing.
Posted Image
It works great for me.
Rocky
The best revenge is living well!
On the bench:
1/32 TAM F-4E almost done....
1/12 Lotus 97T Senna
#43 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 28 March 2010 - 07:23 PM
Thanks Rocky. Unfortunately the problem isn't with the method I used for heating the resin, but rather with the resin itself. Once heated, the resin becomes so soft that it can't even support its own weight. Even at room temperature the left fuselage half is disconcertingly rubbery; I can actually bend and twist the forward part quite easily. Still, I've got nothing to lose by trying the old hairdryer now!
Kev
#44 Hacker
Hacker
    Senior Member
  • LSP_Members
  • 3,899 posts
  • Gender:Male
Posted 28 March 2010 - 07:42 PM
Personally Kevin l would start from scratch. l am afraid you are :deadhorse: here but hey minor miracles have happened so like you said what have you got to lose? My question is this is the top ok? could you cut it off and splice it onto the kit fuselage? With a little sanding and putty it could work
WORK IN PROGRESS
FUTURE PROJECTS
1/32 P-51B & D
1/32 Hurricanes
1/32 Spitfire
RESEARCHING ON
#45 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 40,068 posts
  • Gender:Male
Posted 28 March 2010 - 07:55 PM
That's pretty much my default option at this point. The only question is do I use the old-tool kit or the new-tool kit as a basis. I'm leaning towards the old-tool kit, simply because if I had to choose one to build OOB as a standard 190, it would be the new-tool kit. The old one is a prime candidate for being chopped to pieces!
Kev
