1/32 Dragon P-51D
  • Please log in to reply
8 replies to this topic
#1 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 3,217 posts
  • Gender:Male
Posted 14 July 2009 - 12:02 PM
I don't usually show my work, except at local meetings,
but I thought I'd throw caution to the wind
and show the world a project I did for my wife.
My wife asked me to build her an airplane, so when I found these
Green Nosed Mustang decals with her name (Janet), it was only a
matter of time before I sat down and labored through the process
of building an airplane once again.
So, after over 20 some odd years of armor building, I managed to finish this:
Posted Image
Painted checker board, fitted windshield. A littles silvering to 'Janet'. Oh well.
Posted Image
Stenciled codes and serial number. Codes are my wifes' initials. Serial number is her birthdate (April 7, 1958).
I goofed and didn't cover the fuselage star when I did some invasion stripe touch up, or something, and removed some of the decal.
So I painted the spot aluminum. The canopy is futured. The kit national markings were from hunger. No amount of Sol
would settle them down.
Posted Image
Painted fuel caps and canopy latches. I painted the flaps laquer aluminum.
When I removed the tape some paint pulled off.
Posted Image
You can see where the .50's don't have covers on this wing. The other wing they do.
I didn't like the seam running thru so I sanded off the covers.
I rounded some tube and fit it to the other wing.
That wing was able to accept the covers because I did not finish the opening by sanding it 'to scale thickness',
as it were, like I did this wing.
Posted Image
The rockets don't fit to their base and the aux. fuel tank brace area needs work
The struts gave me a fit. For those of you who have built this kit, you'll know. I built two of the same strut.
The tires flop around on the rims so I had to shim them so the tires would fit. I absolutely hated the way the
struts fit into the wing.
Posted Image
Some detail painting. This was probably the most fun I had with the kit.
The bottom of the wing has a pebble texture. I sanded some of it off before I quit.
I think this is the cause for the light scratchy spots in the central grey area.
But maybe not.
Anyway, what's done is done. I hope you like it.
Thanks for looking.
Sincerely,
Mark
#2 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 16,281 posts
  • Gender:Male
Posted 14 July 2009 - 12:27 PM
Very nicely done Mark! I can tell from the rivets that it's the Dragon kit, but you've whipped it into shape beautifully. I'm sure your wife will be very happy with it. I would be!
Kev
#3 jeroenpeters
jeroenpeters
    Senior Member
  • LSP_Members
  • 2,030 posts
  • Gender:Male
Posted 14 July 2009 - 01:10 PM
If your wife is just as stunning as this bird, you're one lucky man!
Best regards,
Jeroen
Currently working on:
WnW Fokker E.III (phoooone home :)
Tamiya Spitfire Mk.IX
Revell He-111P-1
GMF Hs129 B2
WnW Junkers J.1 (finished!!!)
#4 alberto
alberto
    LSP Member
  • LSP_Members
  • PipPipPip
  • 47 posts
  • Gender:Male
Posted 14 July 2009 - 02:15 PM
Fantastic work on that Mustang, Mark!
I like very much the special care on the weathering, subtle and well done. Personally I love strong weathering (when is recommended).
The pics a bit dark...try to play with lighting to show better that beauty.
Cheers
I chose a bad day to stop sniffing glue...
#5 M. Scott Borden
M. Scott Borden
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 62 posts
  • Gender:Male
Posted 14 July 2009 - 03:40 PM
Very, very nicely done, Mark! The Dragon P-51D is a real challenge; you've made it look easy. Hope to see more of your work!
Scott
#6 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • 3,217 posts
  • Gender:Male
Posted 15 July 2009 - 10:57 AM
Thanks everyone, you're very generous.
And the BEST!
Alberto-I will work on my lighting!
Sincerely,
Mark
#7 Ironwing
Ironwing
    Senior Member
  • LSP_Members
  • 2,541 posts
Posted 15 July 2009 - 03:10 PM
Mark,
Nice job on a difficult kit. Your skill shows. Youve definately created a Mustang worth admiring. Nicely done.
Best,
Geoff
Mustangs are like money...you can never have enough <_<
#8 Firecaptain
Firecaptain
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 464 posts
Posted 15 July 2009 - 08:43 PM
TOP NOTCH work.......very clean...
Joe
#9 Texas
Texas
    Senior Member
  • Deceased Members
  • 3,144 posts
  • Gender:Male
Posted 15 July 2009 - 08:56 PM
Great Looking Model.....I really like your paint and weathering.
Texas ;) :( :ph34r:
