Guyman1 Posted January 4, 2017 Share Posted January 4, 2017 Great job I love conversion scratch builds always interesting to watch Guy mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Shawn M Posted January 4, 2017 Share Posted January 4, 2017 wow, this is gonna be cool Alain Gadbois and mpk 2 Link to comment Share on other sites More sharing options...
MikeMaben Posted January 5, 2017 Share Posted January 5, 2017 Alain Gadbois and mpk 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted January 6, 2017 Author Share Posted January 6, 2017 Hello all! First, thank you all for your interest in this conversion! Very much appreciated! So after cutting out the cockpit opening I realized that there isn't enough height above the existing front wheel bay to fit the cockpit. To create a bit more space, I removed the top of the bay including those freshly added details... Still tight so I am thinking of reducing the kit cockpit so it will fit. We'll see eventually, as this is something one finds out by trial and error... With all those guns removed, I though that a pilot might feel a bit defenseless in a hostile environment. So I added one gun on the lower left side of the fuselage. This is totally my own idea but I thinks its going to look cool! The aluminium tube sanded. Pilots being precious also, I decided to add an ejector seat. As is with the gun, this is not shown in drawings, but it does make sense. The first prototype was fitted with one (maybe not functional?). Also, with the cockpit moved forward, there is a lot more fuselage to get clear of when bailing out! The simplest solution was to use an existing seat, so I figured the Heinkel would be selected. I just happened to have one in the Revell 162 kit so I took my razor saw and just hacked it off the bulkhead! You know what? Perfect fit in the Hasegawa tub! One final thing. I will use the kit canopy except the windscreen that is much too short. I enlarged the side view to 1/32 (by pencil) and using this as a guide I trimmed the lower and back edge of the canopy to get the correct geometry. The back portion will get a similar treatment... Thank you again! Alain sandokan, BradG, r0t0rdr1ver and 10 others 13 Link to comment Share on other sites More sharing options...
Chris Wimmer Posted January 6, 2017 Share Posted January 6, 2017 Very creative modelling, my friend! Looking forward to seeing this come together! cheers Chris Alain Gadbois, R Palimaka and mpk 3 Link to comment Share on other sites More sharing options...
R Palimaka Posted January 6, 2017 Share Posted January 6, 2017 I agree, very creative and clever problem solving. This is a very interesting project. Richard mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
tomv87 Posted January 6, 2017 Share Posted January 6, 2017 This is great! Can't wait to see more! mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
TorbenD Posted January 7, 2017 Share Posted January 7, 2017 Very impressive surgery Alain - a quirky bird to be sure - watching with great interest. Torben Alain Gadbois and mpk 2 Link to comment Share on other sites More sharing options...
Guyman1 Posted January 7, 2017 Share Posted January 7, 2017 Very interesting build Alain great thought process in putting this together. Guy mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted January 8, 2017 Author Share Posted January 8, 2017 Hello and thank you for you comments! It is creative modeling for sure as there is no "real" Me 262 built as this one I am making. However, in the end, the model has to look as convincing as any other late war Luftwaffe aircraft model. So the finish will be very important in this project. I have thought quite a bit about the painting and markings. All the undersides will be unpainted with the roughly applied and sanded gray primer over bare aluminium finish. The top (as a recon machine) will be painted RLM 76 in its normal tint, and green variation on some parts. This will be a light coat showing the dark primer areas underneath. I will have to make some test of this that I will share with you for sure! But these last few days I turned my atention to the very bare main undercarriage bays. Of course it is not the cockpit that will be visible there, but 2 large fuel tanks. There is still a lot to add in this area and this is just the start... Inside of the fuselage: Structures added to the wing bottom. The edges of the openings have been thinned down. Regards, Alain Hubert Boillot, Guyman1, mpk and 5 others 8 Link to comment Share on other sites More sharing options...
r0t0rdr1ver Posted January 8, 2017 Share Posted January 8, 2017 I'm loving this project Alain, it will be stunning once completed. Can't wait to see more mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
Alain Gadbois Posted January 28, 2017 Author Share Posted January 28, 2017 (edited) Hello all! Been a while but I finally had time to advance on the 262... I have removed the kit cockpit floor and glued it directly on a new styrene front wheel well. The cockpit opening on the fuselage has been enlarged front and back. The 2 roughly rectangular panels on each side are what is left of the original kit gun cover. I leave them off now for better access to the interior. The guns openings have been sanded flush. I have gathered 3 Bf 109 instrument panels that will donate bits to make a new one. There has been a bit of detailing done on the kit tub, essentially scraping off some poor details and adding the oxygen system with wire and styrene bits. Here is the wheel well from up close. On the right is the area where the wheel rotates and lies flat after retraction. The rivets were done with a Rosie the Riveter tool. The sides of the front part of the wheel well to be added eventually... Next I finally finished the main structural details inside the fuselage, and painted the area with Tamiya silver spray paint. Honestly not done with the greatest care but next to nothing will be seen anyway. One of the 2 fuel cells in place, that hides almost all the interior. I've also started to engrave panel lines, choosing first the horizontal tailplanes as they can be done independently from the rest of the kit. Bye for now and thanks for watching! I plan more progress on the tailplanes next. Alain Edited January 28, 2017 by Alain Gadbois Hubert Boillot, BradG, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
ClumsyDude Posted January 28, 2017 Share Posted January 28, 2017 Looks great Alain! Nice crisp scratch building. Jim mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
mgbooyv8 Posted January 28, 2017 Share Posted January 28, 2017 Good progress, looking great Alain! Cheers, Peter Alain Gadbois and mpk 2 Link to comment Share on other sites More sharing options...
TorbenD Posted January 28, 2017 Share Posted January 28, 2017 Great progress Alain Torben mpk and Alain Gadbois 2 Link to comment Share on other sites More sharing options...
