1to1scale Posted March 26, 2018 Share Posted March 26, 2018 i think i need a figure painting tutorial. Link to comment Share on other sites More sharing options...
norbert Posted March 26, 2018 Author Share Posted March 26, 2018 Hi next step on the figures : a quick pure acetone wash on all the figures. This is done before the primer is fully dry, let's say half an hour to an hour after the spray. cheers Norbert Uncarina 1 Link to comment Share on other sites More sharing options...
LSP_K2 Posted March 26, 2018 Share Posted March 26, 2018 Hi Found a bit of time to work on a couple of my own figures. And maybe it's time to train on figures ... cheers Norbert I see no images. Link to comment Share on other sites More sharing options...
norbert Posted March 26, 2018 Author Share Posted March 26, 2018 I see no images. Yes, URL signature expired, changing picture hosting again...Will try to replace them chukw and LSP_K2 2 Link to comment Share on other sites More sharing options...
chukw Posted March 27, 2018 Share Posted March 27, 2018 What kind of 3D scanner are you using, Norbert? Excellent results! Link to comment Share on other sites More sharing options...
norbert Posted March 27, 2018 Author Share Posted March 27, 2018 next step : undercoat Tamiya XF 57 buff. The 1/24 mechanics will now go in other hands cheers Norbert Gazzas 1 Link to comment Share on other sites More sharing options...
norbert Posted April 21, 2018 Author Share Posted April 21, 2018 Hello I continue to explore painting over the Tamiya buff undercoat first, I use brown madder for the skin limits and some folds or darker area I let it dry a bit, but it is oil... early enough, I took the white and the red tubes and put them on a towel in order to keep eventuel excess oil out of the paint Paints are mixed to get a lighter red in order to give measles to the poor russian pilot then, you dip a brush into pure turpentine, and you proceed as you want to remove the dots, and the excess of brown madder from the limits And now, skins are ready for small touch-up...or not, depending to your taste cheers Norbert ShelbyGT500 and Dany Boy 2 Link to comment Share on other sites More sharing options...
norbert Posted April 26, 2018 Author Share Posted April 26, 2018 Hi Now some small touches : We take yellow ochre, white and brown madder principaly white and ochre are mixed, then a small dot of brown is added, in order to get a flesh color We push a bit the addition of white and we enlight the surfaces turned to the light. Then, quasi dry, you pull the paint to the shadings. An addition of brown, and you do the parts inthe shadows. Same, quasi dry, you pull the paint from the shodows to the light. You can do that several times until you achieve the effect you are looking for Link to comment Share on other sites More sharing options...
BiggTim Posted May 11, 2018 Share Posted May 11, 2018 You might consider sending some sample 1/32 figs to Jerry Rutman to see what he can do with them. He is very talented with fugures, and might be a good resource. Link to comment Share on other sites More sharing options...
