Tamiya P-51D, Sinai, 1956
Tamiya P-51D Mustang
  • Please log in to reply
591 replies to this topic
#586 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 2,805 posts
Posted 19 November 2017 - 06:47 PM
Amazing Finish!
  • dodgem37 likes this
#587 Barry
Barry
    Senior Member
  • LSP_Members
  • 5,009 posts
  • Gender:Male
Posted 20 November 2017 - 11:12 AM
Mark, Exceptional work!! :thumbsup:
Barry
#588 dodgem37
dodgem37
    Senior Member
  • LSP_Members
  • 7,826 posts
  • Gender:Male
Posted 03 December 2017 - 03:53 PM
Thank you, Shaka.
Thank you, Barry.
Have been making microscopic progress.
The kit comes with a fillet-less tail so I used clay to dam off the circular rivets, molded, then cast them.
I was able to get the framing seated properly, but that gap still remained.  So I filled the gap with .005 sheet, gluing it on the front side only, as I needed a rear panel line, sanded the dickens out of the wing/fuselage fairing gap, especially with the cotton bud sanding stick I made, and replaced the sanded off fasteners with those I cast.  I sanded them down to translucency on 2000 grit sand paper, stuck them onto upside down tape and removed any overage with a new blade.  I used a Radu Brinson RB Productions Nano Saw to finish the panel line between the wing and engine fairing.  The blades are panel line thin.
Other side.  There was a lip between the fuselage/wing fairing and the engine fairing, so I filled the area with melted sprue then sanded to match.   I haven't finished it off as of yet.  Pencil marks for new fastener location.  There is no panel line between top and bottom engine/wing/fuselage fairing.  Shimmed, filled, and sanded the firewall to fuselage gap, giving it a bad coat of paint which I will deal with later.  I may need more fasteners.  I'll take a look at that.
This has been a delicate exercise.  In retrospect I never should have finished the fuselage before tying in the engine compartment.  Every time I pick up the model to work on it there is a chance of something breaking.
Thank you for looking, liking, and commenting.
Sincerely,
Mark
  • LSP_Kevin, Martinnfb, Peterpools and 4 others like this
        Works in Progress:   Italeri 1/35 PT596Tamiya P-51D, Sinai, 1956,
            Completed WiP:  Erich Hartmann, Bf109G-14
                        Idle WiP:  Fw190A-5 Black 7 1/25th IDF Sho't, c.1982Bf109K-4, I./KG (J)6, BohemiaHungarian Bf109G-14, Bf109F-4/Z Trop,Shelf of DOOM!: Kawanishi N1K1 Kyofu Type 11 Rex , IDF AH-1 Tzefa FWerfer-Granate 21's,
   Ready for Inspection: Erich Hartmann, Bf109G-14, Ludwig Franzisket, Bf109G-6
#589 Shaka HI
Shaka HI
    Senior Member
  • LSP_Members
  • 2,805 posts
Posted 03 December 2017 - 06:38 PM
I wish I had your dedication, Mark. But after years dedicated into the build -- those gaps should be fixed.
  • Martinnfb likes this
#590 LSP_Kevin
LSP_Kevin
    Senior Member
  • Administrator
  • 39,726 posts
  • Gender:Male
Posted 03 December 2017 - 07:43 PM
Perfect mix of dedication and skill!
Kev
#591 ClumsyDude
ClumsyDude
    Senior Member
  • LSP_Members
  • 3,012 posts
  • Gender:Male
Posted 04 December 2017 - 01:30 PM
Looks terrific, Mark - can’t be far off the finish line now.
Jim
#592 Peterpools
Peterpools
    Senior Member
  • LSP_Members
  • 23,793 posts
  • Gender:Male
Posted 10 December 2017 - 05:24 PM
Brother Bear
Simply blown away - I remember the day you started you Mustang and never could I have dreamed the level of work and detail would have reached this height. From a guy firmly on the other side of the weathering fence, I am simply amazed at the realist weathering and finish - which compliments the extraordinary detailing.Magnificent ...
Keep 'em coming
Brother Bear
Edited by Peterpools, 10 December 2017 - 05:24 PM.
Trumpeter SBD-1
Also tagged with one or more of these keywords: Tamiya, P-51D, Mustang
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
