Tolga ULGUR Posted August 31, 2017 Share Posted August 31, 2017 (edited) Another new start. This is Trumpeter s 1/32 P-47N Thunderbolt which will be finished with the markings of "Chautauqua". Unfortunately Trumpeter s kit has some problems. I will try to eliminte these. -One of them is the inaccurate wheels. I solved this problem with the help of Rick Griewski. He sent the resin wheels from Jerry Rutman s set. Very appreciated. Thanks again Rick. -Another problem is inaccurate (really inaccurate) windscreen. I will swap it with Hasegawa s windscreen. Here we go: Edited June 4, 2018 by Tolga ULGUR sandokan, Kagemusha, Marmaduke and 5 others 8 Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2017 Share Posted August 31, 2017 Bring it on !.....Harv Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 1, 2017 Author Share Posted September 1, 2017 (edited) Firstly , I tried to fix the ugly Trumpeter s windscreen. This is really bad, simply disastrous I decided to use Hasegawa s canopy. You can see the difference between the ugly and the real one. But it needs some works to fit it on Trumpeter s fuselage. Edited September 5, 2017 by Tolga ULGUR Starfighter, AlexM, Troy Molitor and 2 others 5 Link to comment Share on other sites More sharing options...
Kagemusha Posted September 1, 2017 Share Posted September 1, 2017 Good luck with the canopy - I also have a Hasegawa for my N, just a thought... I wonder if the wheel hubs would fit the nicer Barracuda wheels? Tolga ULGUR and Rick Griewski 2 Link to comment Share on other sites More sharing options...
Vandy 1 VX 4 Posted September 1, 2017 Share Posted September 1, 2017 To replace your Hasagawa canopy I used the following set https://masterdetails.com/web-store/pilots-figures-details/war-era-years/world-war-2-1919-1945/p-47d-thunderbolt-cockpit-finishing-kit-detail Rick Griewski, Tolga ULGUR, Troy Molitor and 2 others 5 Link to comment Share on other sites More sharing options...
Troy Molitor Posted September 2, 2017 Share Posted September 2, 2017 This should be another favorite build starting off. Canopy swap is an easy fix. Love the look of the -47 N and a boat load of great colorful decal options. I'm looking forward to this one Tolga. Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 4, 2017 Author Share Posted September 4, 2017 Gap filled with Tamiya epoxy putty. AlexM, tomv87, Kendzior and 3 others 6 Link to comment Share on other sites More sharing options...
AlexM Posted September 4, 2017 Share Posted September 4, 2017 Interesting project. Is the rear part of the Trumpy canopy as bad as the forward part? Otherwise, maybe you could use the - presumably better fitting - Trumpy-part in open position Tolga ULGUR and nmayhew 2 Link to comment Share on other sites More sharing options...
nmayhew Posted September 4, 2017 Share Posted September 4, 2017 To replace your Hasagawa canopy I used the following set https://masterdetails.com/web-store/pilots-figures-details/war-era-years/world-war-2-1919-1945/p-47d-thunderbolt-cockpit-finishing-kit-detail How did that go? Link to comment Share on other sites More sharing options...
Kendzior Posted September 4, 2017 Share Posted September 4, 2017 Gap filled with Tamiya epoxy putty. Hope the epoxy putty will work without a risk of damage to the canopy, when you remove it after it is fully dry and that the putty will not crumble when you split the fuselage halves. I'd probably go with the inserts made of HIPS. Watching with great interest and keep my fingers crossed Best regards Hubert Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 5, 2017 Author Share Posted September 5, 2017 Interesting project. Is the rear part of the Trumpy canopy as bad as the forward part? Otherwise, maybe you could use the - presumably better fitting - Trumpy-part in open position Yes, all of them windscreen and the sliding canopy are wrong and inaccurate completely Special effort is required to model something so badly. It needs to celebrate Trumpeter . Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 5, 2017 Author Share Posted September 5, 2017 Hope the epoxy putty will work without a risk of damage to the canopy, when you remove it after it is fully dry and that the putty will not crumble when you split the fuselage halves. I'd probably go with the inserts made of HIPS. Watching with great interest and keep my fingers crossed Best regards Hubert Thank you Hubert Yes you are right, that s why I have used tamiya masking tape as a buffer between the epoxy and the clear part. Kagemusha 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted September 5, 2017 Author Share Posted September 5, 2017 And the result: Doctorgaz, Martinnfb, Kendzior and 6 others 9 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted September 5, 2017 Share Posted September 5, 2017 Excellent solution, Tolga! Kev Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Kendzior Posted September 5, 2017 Share Posted September 5, 2017 Wow, that looks just great! Thanks for sharing the photos and the idea - very inspiring . Best regards Hubert Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
