Guest Peterpools Posted December 15, 2017 Share Posted December 15, 2017 Shawn Terrific idea and a very nice start: terrific front office and pilot and will be following all the way Keep 'em coming Peter Link to comment Share on other sites More sharing options...
Shawn M Posted December 15, 2017 Author Share Posted December 15, 2017 Thanks Peter! Link to comment Share on other sites More sharing options...
tchwrma Posted December 15, 2017 Share Posted December 15, 2017 Good work, Shawn! I will be following! Paulo Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 15, 2017 Author Share Posted December 15, 2017 with my folks moving this weekend (ugh) I wont have much bench time Link to comment Share on other sites More sharing options...
Shawn M Posted December 17, 2017 Author Share Posted December 17, 2017 got the pilot, seat and stick set into final place. A scrap of resin under the seat set it at just the right height. the gunsight...well....sucked so I resculpted and detailed it onto the fuse prep work I sprayed a layer of Vallejo GunMetal Alain Gadbois, BradG, Dragon and 3 others 6 Link to comment Share on other sites More sharing options...
Shawn M Posted December 17, 2017 Author Share Posted December 17, 2017 I knew the bulkhead would block light and views into the lack of intake. So I painted in some faux depth. although not perfect it does the trick hard to tell but there are 3 different metal colors here While the pilot dries, I've chromed the landing light and have started work on the IP as it needs to go in prior to the stuffing the fuse like a thanksgiving turkey Big Texan, Dragon, blackbetty and 3 others 6 Link to comment Share on other sites More sharing options...
Gazzas Posted December 18, 2017 Share Posted December 18, 2017 Shawn, Just discovered this thread. Some nice work hap-nin. Great result on the pilot. I was gonna ask what has to be done to the Trumpy MiG to make it pure Russki. Now I have a reference. Gaz Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 18, 2017 Author Share Posted December 18, 2017 thank you Gaz There is a lot that needs to be done to make it "correct". While the Eduard PE set is great and comprehensive, I would scratch build the cockpit details next time. The rudders(s) and elevators are missing the mass balances and will need those added, there are 2 trim tabs on the ailerons and only one is needed, all the flight surfaces have square leading edges and need to be contoured, the hinges on the bottom of the ailerons are total BS, the tail shape is incorrect, the intake ducting non existent, the canon barrels are junk and will be replaced by master units, the surface of the model is pebbly and needs sanding, the canopy needs to be replaced (by Squadron VAC or the new HAD unit coming on market), there are some fictional panels, incomplete panel engraving, etc lol sandokan 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 19, 2017 Author Share Posted December 19, 2017 with the ip done and cockpit installed i glued the intake splitter in and started working my way down the fuse halves with liquid glue got 'er all sealed up Pretty solid joints, no gaps and minimal sanding to level the joint required. The black lines are the squeeze through of black paint and plastic LSP_Paul, Alain Gadbois, Big Texan and 4 others 7 Link to comment Share on other sites More sharing options...
LSP_Paul Posted December 19, 2017 Share Posted December 19, 2017 Looking great Shawn! Next comes the part of this kit that most people hate about it.. Fitting the wings..Crossing my fingers you enjoy sand, fill, file, prime, repeat..We are all here if you need to vent to somebody. It's Trumpeters fault..just sayin Paul Shawn M 1 Link to comment Share on other sites More sharing options...
Mark M Posted December 19, 2017 Share Posted December 19, 2017 Shawn M 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted December 19, 2017 Share Posted December 19, 2017 Impressive work, Shawn! Kev Shawn M 1 Link to comment Share on other sites More sharing options...
Dany Boy Posted December 19, 2017 Share Posted December 19, 2017 (edited) Shawn, this 1:32 Mig-15 modeling is looking great, and I have the impression that you reduce a little the front intake splitter or I am mistaken? Edited December 19, 2017 by Dany Boy Shawn M 1 Link to comment Share on other sites More sharing options...
Shawn M Posted December 19, 2017 Author Share Posted December 19, 2017 Thanks gang! Danny, no thinning of the splitter itself just the horizontal bars. They had terrible mould misalignment and were too chunky. Started some sanding of the joints, not as pretty as I'd first thought..oh well its only plastic. Link to comment Share on other sites More sharing options...
Shawn M Posted December 19, 2017 Author Share Posted December 19, 2017 Looking great Shawn! Next comes the part of this kit that most people hate about it.. Fitting the wings..Crossing my fingers you enjoy sand, fill, file, prime, repeat..We are all here if you need to vent to somebody. It's Trumpeters fault..just sayin Paul OMG Paul you are so right...gonna be a massive challenge to get a good fit there LSP_Paul 1 Link to comment Share on other sites More sharing options...
