BloorwestSiR Posted January 2, 2018 Author Share Posted January 2, 2018 Coooooool! This was a great kit. Other than some minor detail corrections it goes together really nice.I went the same way with the aftermarket too.If your so inclined, take a look at the the cowling openings, as from documentation I found, they were substantially too small OOB.I used a large wooden dowel of the correct diameter wrapped in 600 grit sandpaper (tapered on a lathe at the end right before the sand paper to make sure the openings got enlarged symmetrically all the way around and centered) to open them up to a more realistic size. Looking forward to more progress! I remember following along on your Lady Lil build Brian. Thanks for the reminder on the cowl openings. Carl Out2gtcha, CANicoll, Troy Molitor and 1 other 4 Link to comment Share on other sites More sharing options...
R Palimaka Posted January 2, 2018 Share Posted January 2, 2018 Don't know if you've heard, but the Canadian Warplane Heritage will be converting their Mitchell back to the proper glass-nose version. They've had a glass nose in storage for a while, but now have the funding to do it. The Hot Gen artwork is actually from a 98 Squadron aircraft flown by a Canadian pilot in NW Europe. The gun-nose was cool but not flown by the RAF. Richard Jeff and BloorwestSiR 2 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 14, 2018 Author Share Posted January 14, 2018 Don't know if you've heard, but the Canadian Warplane Heritage will be converting their Mitchell back to the proper glass-nose version. They've had a glass nose in storage for a while, but now have the funding to do it. The Hot Gen artwork is actually from a 98 Squadron aircraft flown by a Canadian pilot in NW Europe. The gun-nose was cool but not flown by the RAF. Richard That's great news Richard and it'll be good to see Hot Gen with the correct nose. I might still stick with the gun nose as I have pics of her that way. Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 14, 2018 Author Share Posted January 14, 2018 (edited) Wanting a quick break from the Phantom and Corsair, I decided to work a bit on the Mitchell. I decided to start with the cockpit seats. The first thing I noticed is that the the numbers on the instructions don't match the PE fret. They're off by 10. So if the instructions say you need part 10, then you need 20 on the fret. If it says 15, you need 25,etc. Not insurmountable but annoying nonetheless. Here's the first seat mount built up. I think I've got assembled correctly. I found it a bit fiddly so knowing I have to do a second one is filling me with so much joy. Not. Carl Edited January 14, 2018 by BloorwestSiR BradG, Dragon, Vandy 1 VX 4 and 4 others 7 Link to comment Share on other sites More sharing options...
Guest Posted January 14, 2018 Share Posted January 14, 2018 Im glad the "H" only has 1 seat ! Looks good....Harv Link to comment Share on other sites More sharing options...
Guest Peterpools Posted January 15, 2018 Share Posted January 15, 2018 Carl Holy Cow, a B-25 on the bench as well. Nice start with the engines and taking notes as later this year, I hoping to finally get going on my B-25. Thanks for the heads up on the HGW Seat PE set - always a bit of added fun when the instructions are wrong. Very nice work on the PE Seat - it looks mighty good. Any reason why you decided to use the HGW PE set and not the Eduard set as Brian did? Keep 'em comin Peter Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 15, 2018 Author Share Posted January 15, 2018 Im glad the "H" only has 1 seat ! Looks good....Harv You lucky dog Harv! I've started on the second seat base. Hope to have it done today. Jeff 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 15, 2018 Author Share Posted January 15, 2018 Carl Holy Cow, a B-25 on the bench as well. Nice start with the engines and taking notes as later this year, I hoping to finally get going on my B-25. Thanks for the heads up on the HGW Seat PE set - always a bit of added fun when the instructions are wrong. Very nice work on the PE Seat - it looks mighty good. Any reason why you decided to use the HGW PE set and not the Eduard set as Brian did? Keep 'em comin Peter Thanks Peter! I think it'll be the biggest model yet for me. The plan is to have the F-4E finished this month, the Corsair early month and then go full on with this build. At least, that's the plan... I think the HGW and Eduard seats are identical (Eduard usually do all the PE for HGW) and since I prefer HGW's fabric belts, that was the basis for my choice. Might be a bit cheaper that way too. Carl Out2gtcha 1 Link to comment Share on other sites More sharing options...
Dragon Posted January 16, 2018 Share Posted January 16, 2018 The engines look great; the wiring and the touch of griminess really enhances them. Nice work on the metal bending too! Mike Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 16, 2018 Author Share Posted January 16, 2018 The engines look great; the wiring and the touch of griminess really enhances them. Nice work on the metal bending too! Mike Thanks Mike! The PE is definitely proving to be a challenge. Dragon 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 16, 2018 Author Share Posted January 16, 2018 So I managed to get the second seat base finished. Here's all the parts that go into it: With those out of the way, I started on the seats themselves. First up was the copilot'seat. This was a bit easier than the seat bases. The plastic rod is for the vertical supports. Here it is assembled next to the underway pilot's seat. BradG, Shaka HI, Jeff and 1 other 4 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 16, 2018 Author Share Posted January 16, 2018 Deciding to take a break from the seats, I did some work on the nacelles. One thing I noticed after assembly was that the engraved lines for the gear doors was no deeper than the panel lines. I decided to scribe them a bit more to try and highlight them. Hopefully you can make out the deeper panel lines in the picture. Shaka HI, Jeff, KiwiZac and 2 others 5 Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2018 Share Posted January 16, 2018 Yeah, that does look better. You gonna make them deeper ?......Harv Link to comment Share on other sites More sharing options...
Out2gtcha Posted January 16, 2018 Share Posted January 16, 2018 Looks grand! Yes, I can now definitely distinguish between the gear doors and panel lines. Something I think I missed on mine BloorwestSiR 1 Link to comment Share on other sites More sharing options...
BloorwestSiR Posted January 16, 2018 Author Share Posted January 16, 2018 Yeah, that does look better. You gonna make them deeper ?......Harv Thanks Harv! I went over them again to make it a bit deeper. Here is what it looks like now. Link to comment Share on other sites More sharing options...
