robertmro Posted March 27, 2018 Share Posted March 27, 2018 Hi Guys, When I started this project I didn't realize that I could turn to this forum for help. Now that I'm going into the final phase a of this kit and I need some input. The ammo boxes will go the printing service as soon as I'm convinced that I got it right. Please look at these renders and suggest any changes. Thanks LSP_Kevin, Model_Monkey, Jeff and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted March 27, 2018 Share Posted March 27, 2018 Looks good!.....Harv Link to comment Share on other sites More sharing options...
chrish Posted March 28, 2018 Share Posted March 28, 2018 Look just like the ones in the 1/32 Tamiya kit so, gotta be right... Link to comment Share on other sites More sharing options...
robertmro Posted March 28, 2018 Author Share Posted March 28, 2018 The reference that I have and which is the same as Tamiya's rendition, doesn't have a rectangular indentation on the top. It's just flat. The original Airfix ones have an indentation and Eduard Brassin upgrade has one that projects up off the surface. The service manual has a rectangle on the top but it isn't clear weather it goes up or down. I'll probably just remove it because I have a picture that shows it sans rectangle. Link to comment Share on other sites More sharing options...
robertmro Posted March 28, 2018 Author Share Posted March 28, 2018 These are done. I just need to print them, unless someone can find something wrong. The number of bullets visible in the slots is correct. Uncarina, Menelaos, Jeff and 2 others 5 Link to comment Share on other sites More sharing options...
Gerhard Posted March 28, 2018 Share Posted March 28, 2018 Looks stunning, are you going to market these? Jeff 1 Link to comment Share on other sites More sharing options...
Bstarr3 Posted March 28, 2018 Share Posted March 28, 2018 Beautiful work! Link to comment Share on other sites More sharing options...
robertmro Posted March 28, 2018 Author Share Posted March 28, 2018 Looks stunning, are you going to market these? Thanks. Yes Tony C and Gerhard 2 Link to comment Share on other sites More sharing options...
Tony C Posted March 28, 2018 Share Posted March 28, 2018 Thanks. Yes Wouldn't mind a set, will you sell to the UK? Link to comment Share on other sites More sharing options...
robertmro Posted March 29, 2018 Author Share Posted March 29, 2018 Wouldn't mind a set, will you sell to the UK? I will be selling to the UK from my website but I have been receiving complaints from British customers about VAT and other local charges. I'm looking for a way make it more affordable there. Tony C 1 Link to comment Share on other sites More sharing options...
robertmro Posted April 4, 2018 Author Share Posted April 4, 2018 More samples: Uncarina, Model_Monkey, Menelaos and 1 other 4 Link to comment Share on other sites More sharing options...
LSP_K2 Posted April 4, 2018 Share Posted April 4, 2018 I don't have the 1:24th kit, and may never have one, but what you're doing for it here, looks really quite special. Iain 1 Link to comment Share on other sites More sharing options...
nmayhew Posted April 5, 2018 Share Posted April 5, 2018 This looks stunning in CAD but surely for gun barrels, which always look better as turned metal than any other medium in 1/32, they *need* to be in metal in 1/24? This seems to be going down the Eduard Brassin route...why not make just the gun ‘block' and everything else, but leave the barrels to the likes of Master Model? David66 1 Link to comment Share on other sites More sharing options...
robertmro Posted April 5, 2018 Author Share Posted April 5, 2018 This looks stunning in CAD but surely for gun barrels, which always look better as turned metal than any other medium in 1/32, they *need* to be in metal in 1/24? This seems to be going down the Eduard Brassin route...why not make just the gun ‘block' and everything else, but leave the barrels to the likes of Master Model? You have a good point. I thought long and hard about this. However, after studying my reference it became noticeable that the barrels have a slight taper toward the front end and there is a bolt-like area on the flash cone to grasp with a wrench. Furthermore there are tubes that barrels pass through before exiting the nose of the fuselage that need to be part of the casting. The exquisite Master barrels don't taper or have the bolt and would be difficult to fit to the tubes. However, anyone is free to cut off the cast barrels and add brass ones. Doing so would also double the cost of the modification and be less accurate. I agree with Eduard Brassin's decision but I can't find any reference that verifies the single slot in the ammo chutes. nmayhew and David66 2 Link to comment Share on other sites More sharing options...
Anthony in NZ Posted April 6, 2018 Share Posted April 6, 2018 WOW, that's really really nice!! Are you doing any of the junction boxes etc on the bulkhead? Let me know if you need any help, I have easy access to an FB-VI and am happy to help where you need it Cheers Anthony robertmro 1 Link to comment Share on other sites More sharing options...
