Tolga ULGUR Posted June 11, 2017 Author Share Posted June 11, 2017 (edited) Still some works for the cockpit Edited June 11, 2017 by Tolga ULGUR sandokan, TorbenD, rafju and 1 other 4 Link to comment Share on other sites More sharing options...
Joel_W Posted June 11, 2017 Share Posted June 11, 2017 Tolga, Looking forward to how you assemble all those parts into the cockpit, then further detail it including all the necessary wiring. Joel Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 12, 2017 Author Share Posted June 12, 2017 Tolga, Looking forward to how you assemble all those parts into the cockpit, then further detail it including all the necessary wiring. Joel Fitting test looks good. Hope that they will be installed without problem into the cockpit. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 12, 2017 Author Share Posted June 12, 2017 And the side walls, in the end Alburymodeler, sandokan and rafju 3 Link to comment Share on other sites More sharing options...
Joel_W Posted June 12, 2017 Share Posted June 12, 2017 Tolga, Those side walls really look quite good. Nicely done. Joel Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 12, 2017 Share Posted June 12, 2017 (edited) If you have the cockpit, the Aires p-51B wheelwell set is actually a P-51A set, so it'll work swimmingly. After that, the only real issue is a misshapen spinner, and a few nose shapes.... The spinner should be basically a 3 bladed version of the P-51D spinner. Once the spinner is corrected and installed, build up and sand the nose to match, and it'll be real close. use photos to guide you. I'm not a member of the LSP Caliper Crew nor do I deal with the "Red Line Express", so maybe that bunch could say more. I rely on the Mk.1 eyeball. (Soon to be the Mk.1a) Your pit is awesome, Sir. I'm really looking forward to seeing this done. I have a few in my stash, and they're great kits, actually, and with proper care and attention, build up into a beautiful rendition of an Allison Mustang. Edited June 12, 2017 by Clunkmeister Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 12, 2017 Share Posted June 12, 2017 The kit was marketed in four boxings, AFAIK. P-51A Air Commandos British Mustang 1 A-36 The A-36 seems to be the most scarce Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 13, 2017 Author Share Posted June 13, 2017 The kit was marketed in four boxings, AFAIK. P-51A Air Commandos British Mustang 1 A-36 The A-36 seems to be the most scarce Yess, I have nearly all of them. I will use them slowly. It seems that next step will be Air commandos. Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 13, 2017 Author Share Posted June 13, 2017 If you have the cockpit, the Aires p-51B wheelwell set is actually a P-51A set, so it'll work swimmingly. After that, the only real issue is a misshapen spinner, and a few nose shapes.... The spinner should be basically a 3 bladed version of the P-51D spinner. Once the spinner is corrected and installed, build up and sand the nose to match, and it'll be real close. use photos to guide you. I'm not a member of the LSP Caliper Crew nor do I deal with the "Red Line Express", so maybe that bunch could say more. I rely on the Mk.1 eyeball. (Soon to be the Mk.1a) Your pit is awesome, Sir. I'm really looking forward to seeing this done. I have a few in my stash, and they're great kits, actually, and with proper care and attention, build up into a beautiful rendition of an Allison Mustang. Thanks for the detailed information. In fact I am not willing to work with hard surgery corrections in this project. Due to closed wing flaps, main wheel weel doors have to be at closed position. So most of the details will be hidden under these doors. So I am planning to go as it is for this time being. Maybe I will try Aires wheel well in the next projects. Is there any after market correction for 3 blades spinner.? MikeC 1 Link to comment Share on other sites More sharing options...
Guest Clunkmeister Posted June 13, 2017 Share Posted June 13, 2017 (edited) Not that I know of, although you can get an AM spinner, fill three holes, and cut in two new ones. Failing that, buy the Tamiya sprue on eBay and use the spinner. Edited June 13, 2017 by Clunkmeister Link to comment Share on other sites More sharing options...
Dan Paxton Posted June 13, 2017 Share Posted June 13, 2017 Tolga, Sir If it helps, try this site for reference pictures of your P-51A http://www.avialogs.com/index.php/itemlist/category/1347-p-51a-mustang.html Dan Tolga ULGUR 1 Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 13, 2017 Author Share Posted June 13, 2017 Tolga, Sir If it helps, try this site for reference pictures of your P-51A http://www.avialogs.com/index.php/itemlist/category/1347-p-51a-mustang.html Dan Thank you Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 20, 2017 Author Share Posted June 20, 2017 And, in the end I am touching to the fuselage halves First of all I have to delete these huge ejector pins.. monthebiff, Dan Paxton, sandokan and 3 others 6 Link to comment Share on other sites More sharing options...
monthebiff Posted June 20, 2017 Share Posted June 20, 2017 Really like what you are doing with this kit Tolga, cockpit looks fantatsic. Regards. Andy Link to comment Share on other sites More sharing options...
Tolga ULGUR Posted June 21, 2017 Author Share Posted June 21, 2017 Really like what you are doing with this kit Tolga, cockpit looks fantatsic. Regards. Andy Thanks Andy.. Link to comment Share on other sites More sharing options...
