dutik Posted July 6, 2017 Share Posted July 6, 2017 So the nose is not 2mm too wide, but good fitting? Regards - dutik Link to comment Share on other sites More sharing options...
Joel_W Posted July 6, 2017 Share Posted July 6, 2017 Jorge, The nose clip fits like a glove. I'm sure it wasn't the perfect fit, but required quite a lot of massaging the nose clip to look that good. Joel Link to comment Share on other sites More sharing options...
oppenheimer Posted July 6, 2017 Author Share Posted July 6, 2017 after reducing the sides with sand paper i got perfect fit, and i opened a little the bottom of the fuselage to reduce the difference in wide of both pieces and still got enough space for the wing to fit. Paul in Napier, dutik and Harold 3 Link to comment Share on other sites More sharing options...
dutik Posted July 6, 2017 Share Posted July 6, 2017 Well, so this is the trick. Thank you for sharing! Regards - dutik Link to comment Share on other sites More sharing options...
Martinnfb Posted July 6, 2017 Share Posted July 6, 2017 Beautiful work on blending the resin bits into the Tamiya base Robert. Very inspirational, thanks for sharing. Cheers Martin Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 6, 2017 Share Posted July 6, 2017 Nice! The conversion resin looks excellent!! The bird itself looks like the Jimmy Durante of airplanes. Joel_W 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted July 6, 2017 Share Posted July 6, 2017 That looks terrific, Jorge! Kev Link to comment Share on other sites More sharing options...
kike_gt Posted July 7, 2017 Share Posted July 7, 2017 Nicely done!! hats off!!! Link to comment Share on other sites More sharing options...
Madelf75 Posted July 7, 2017 Share Posted July 7, 2017 Looks like it's going to be a nice looking kit Link to comment Share on other sites More sharing options...
oppenheimer Posted July 18, 2017 Author Share Posted July 18, 2017 Small update, hole airplane primed in Model master gloss black. red baron, Paul in Napier, Doctorgaz and 4 others 7 Link to comment Share on other sites More sharing options...
oppenheimer Posted July 18, 2017 Author Share Posted July 18, 2017 (edited) meanwhile while i let the airplane rest till is dry, i foud that i need modern look tires, and for the mustang you will find only WW2 era tires, so i bought a pair from Baracuda resin and filled all the lines i dont need on the tires and this is the result, not bad Edited July 18, 2017 by oppenheimer Harold, sandokan, Paul in Napier and 1 other 4 Link to comment Share on other sites More sharing options...
oppenheimer Posted July 18, 2017 Author Share Posted July 18, 2017 First group of panels done with the alcad Doctorgaz, red baron, TaffyMan and 8 others 11 Link to comment Share on other sites More sharing options...
Barry Posted July 18, 2017 Share Posted July 18, 2017 (edited) Looking GREAT!!!! Barry Edited July 18, 2017 by Barry Link to comment Share on other sites More sharing options...
Out2gtcha Posted July 18, 2017 Share Posted July 18, 2017 LOVE it!! More please Link to comment Share on other sites More sharing options...
Joel_W Posted July 18, 2017 Share Posted July 18, 2017 Jorge, I've got to hand it to you for the tire modification. I'd never think of anything like that, and the end result is perfect. Your NMF is really looking good. I'm also suprised at the procedure you're using. Nearly everyone including me does a basic coat of one of the Alcad 2 Aluminums, then masks and does the panels, but you've gone a completely different route, and it really works fantastically. I just might very well use if for my next (when ever that is) NMF aircraft build. Joel Out2gtcha and sandokan 2 Link to comment Share on other sites More sharing options...
