tucohoward Posted December 28, 2017 Share Posted December 28, 2017 You're gonna need a bigger booth. Good luck with this project! Looking forward to it. Jay Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 28, 2017 Author Share Posted December 28, 2017 Jay - Ha, I thought the same thing once I opened the box. Didn't even know if my desktop was big enough for the various subassemblies. It's defintely going to take some strategic thinking. Brian, thanks for the kind words. I've been following your F7F build with interest. Your level of scratchbuilding and detail is more than I can imagine doing myself. Karim - thanks for the tip on the HGW belts. Like I said, I think I'll probably leave this set to put in a spit sometime and use the kit belts for the Mossie. Peter - I just looked at your finished Mossie pics earlier and was inspired/hopeful for my own build. Hoping to get into it some more tonight. Do people who have done the kit recommend painting the PE harnesses before or after installing them? Link to comment Share on other sites More sharing options...
MikeMaben Posted December 29, 2017 Share Posted December 29, 2017 I also apparently need to decide already if I'm going to be using the figures or not. I'm leaning towards yes. I like crew figures too as they're the best way to give the model scale. If you use them you won't need to mess with the belts/buckles as they are because they're also molded on the figures. Thanks for having such an inspiring and welcoming forum. No , thank you for the cool tip on highlighting sprues. Helpful on huge kits like the Mossie. See , you're teaching us stuff already Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 29, 2017 Author Share Posted December 29, 2017 Updates with some fiddly work from last night. So far I'm loving working in 32nd scale, but I'm surprised how different it is from 1/48. The number of individual parts that are often assembled into one gives so much better detail, but also means the parts are smaller to work with than I expected. The Touch n Flow is perfect for these little subassemblies. Cockpit floor assembly from two angles Instrument panel bulkhead and rudder pedals. I waited on the rest of the IP assembly until I can grab some etching metal primer from the hardware store. I've had terrible luck with paint sticking to PE parts and I'm going to try a good metal primer this time around. Also didn't want to mess with decals at 12am Navigator's seat with armored glass. It's a cool effect with the clear part, and hopefully will be the hardest of the kit masks to cut out. And here's the whole cockpit subassembly (minus the stick) dry fitted. I'm going to follow from Brett Green's book and paint these little sub-sub assemblies where I can still get at all the nooks and crannies for detail painting, and then fit the cockpit together. Wow, kit within a kit is really true for this Mossie. I'm also realizing that quite a bit of planning is going to have to go into the interior decaling. I've got quite a bit of overlap between the kit decals, Eagle decals, and the HGW wet transfers. The important thing is that I've made a hard task harder for myself AlexM, Whitey, sandokan and 4 others 7 Link to comment Share on other sites More sharing options...
karimb Posted December 29, 2017 Share Posted December 29, 2017 Cool update! That cockpit looks super nice. Are you going to add wiring to the back of the instruments? K Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 29, 2017 Author Share Posted December 29, 2017 Hi, Karim, thanks. Yes, I've definitely thought about busying up the cockpit a little with some additional wiring, either lead wire or Milliput, but I'm not sure if the back of the IP is visible at all after assembly. I'll probably put some running around from the throttle quadrant, around the back of the Gee receiver, and running up the control stick. Jeff 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted December 29, 2017 Share Posted December 29, 2017 Very nice progress on the front office - One incredibly detailed kit. Looking godd Keep 'em comin Peter Link to comment Share on other sites More sharing options...
AdamR Posted December 30, 2017 Share Posted December 30, 2017 One tip i sometimes use is to thread the belt in the photoetch buckles while they are still on their fret then cut the buckle off. Helps with not losing those or having them ping off. Karim ^^ This! Also, turn the Mossie's box lid upside down and do all the harness work inside it. Pieces you drop will be easier to find and less likely to be eaten by the Carpet Monster. Good luck with your very ambitious build! Bomber_County, GusM and Jeff 3 Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 31, 2017 Author Share Posted December 31, 2017 Lots of updates - got paint down in the cockpit last night. Boy, do I love MRP! It sprays so beautifully - easy to lay down in thin translucent layers, no spitting or tip dry, no worrying about thinning ratios. It does stink though. I used the spray booth and a respirator. Parts laid out and primed in spray booth. Used Badger Stynelrez, my standard primer. In the foreground you can see the Barracuda resin ammo chutes, which I'm planning to apply late in the process. Base layer of MRP interiro grey-green I think I'm sold on 1/32 scale just for the instrument panels. This is amazing! Cockpit floor assembly. Laid down model air middlestone with a brush for the plywood foot panel. Will go over it with burnt sienna oils for a wood grain effect. Already lost a part - the decal for the radar screen. I painted it gloss black instead with a drop if Future. We'll say it's turned off. Pilot's seat brush painted with Model Air RLM 70. Microdetailing on the control stick. Wires done in 0.3 lead wire, clamps in lead foil, and wrapped the handle in copper speaker wire. Also primed and laid down interior green on the interior fuselage and bulkheads. Will finish detail painting on sidewalls and machine gun compartment, then will hit it all with Future and oil washes. Jeff, Trak-Tor, sandokan and 5 others 8 Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 31, 2017 Author Share Posted December 31, 2017 Peter thanks for following my thread. Just found your WIP from your Mossie, and it is really inspiring. Your paint work is remarkable, and I'm already finding it hard to live up to. Adam, thanks for the tip about working inside the box top, I'll have to remember that for working with small PE too Link to comment Share on other sites More sharing options...
Bomber_County Posted December 31, 2017 Share Posted December 31, 2017 Great start, i have had my Mossie in the stash for nearly two years, so you may just give me a kick in the pants. When I returned from my hiatus, I got the Tamiya Corsair, what a pleasure to build, so looking forward to the Mossie eventually....... Hitting the follow button..... Link to comment Share on other sites More sharing options...
Bstarr3 Posted December 31, 2017 Author Share Posted December 31, 2017 Thanks for following. It's definitely a big time kit. I've bitten off a lot. Hopefully it doesn't prove to be more than I can chew. I'm loving this move to 1/32 scale so far, and if whether I can finish this all in one go or not, my next is definitely going to be a single engine fighter. Bomber_County 1 Link to comment Share on other sites More sharing options...
dennismcc Posted December 31, 2017 Share Posted December 31, 2017 Great another Tamiya Mossie build, by the time I get around to mine you guys will have ironed out all the snags for me, I like the marking of the sprues as well, I go one further and colour code the parts on the instructions as to which sprue they come from, I've just been doing just that on my current kit. Cheers Dennis Bomber_County 1 Link to comment Share on other sites More sharing options...
Bstarr3 Posted January 1, 2018 Author Share Posted January 1, 2018 Small update: Finished with the detail painting and assembled the cockpit. Left the navigators seat out to leave room for decal and washes. Close up of the wood grain. I really like this effect. It's incredibly easy to get what I think is a very realistic effect. BloorwestSiR, dennismcc, AdamR and 3 others 6 Link to comment Share on other sites More sharing options...
Guest Posted January 1, 2018 Share Posted January 1, 2018 Lovely ! But, do you still have the mask on radio receiver ?.....Harv Link to comment Share on other sites More sharing options...
