spacewolf Posted October 1, 2017 Share Posted October 1, 2017 So glad to see this... my fav. Monogram bird.. brings back many happy memories... think I built 4 of them ! Love what you are doing !! Vaughn Link to comment Share on other sites More sharing options...
fightnjoe Posted October 12, 2017 Author Share Posted October 12, 2017 Many many thanks all for the kind words. I think I should just toss mine in the bin, now. Kev Not a reaction that my work normally gets. Joe Link to comment Share on other sites More sharing options...
fightnjoe Posted October 18, 2017 Author Share Posted October 18, 2017 With the continuing movement forward with the videos on this build it is time to throw out some better, used very loosely, quality images of the weathering. First up, and each of these will be a kind of summary of what happened. First the initial process was with a gloss coat I used Titanium White, cheaper oil set, to try to get some streaking and a bit of weather staining on the fuselage. I also used Burnt Umber, same set, to try to get some distinct staining on the panels of the engine area. I did not like the way this came out. Anyway the pics. The process is started anyway. Teaser, a bit of a change in execution is next up. All comments, critiques, and criticism are encouraged. Joe KUROK, Shawn M, spacewolf and 3 others 6 Link to comment Share on other sites More sharing options...
fightnjoe Posted October 21, 2017 Author Share Posted October 21, 2017 Ok for this update let me talk about my methods. First up for me was a drybrush of Testors Flat Aluminium. This concentrated on areas I felt and have seen received excess wear and tear on the paint due to crew use or even weathering. Along those lines I also used my cheap Oil Paint Titanium White with an abused round brush as well as two sizes of flat brush. I put small dots into the centerish of panels and then worked them into the paint. Mind you that this is being done over a flat clear layer. After several passes that encompassed varied panels I came to the decision that one of my more recent investments needed to be used here. Recently I purchased four sets of Abteilung 502 Oil Paints. Beginning with ABT070 Dark Rust I began to play a bit with panel lines. After just a brief attempt I just had the thought that it didnt look right. I used a cotton bud to remove most of it and brought out ABT004 Bitume and began to work around some of the lines. I tried to keep this to where dirt and grime would build up and where the weather would cause streaking. I did this over several sessions. Overall there is several hours of work. In the next update I will show what at the time I thought was the weathering finished. All comments, critiques, and criticism are encouraged. Joe Shaka HI 1 Link to comment Share on other sites More sharing options...
Shaka HI Posted October 22, 2017 Share Posted October 22, 2017 That looks really good, Joe. I think the model needs some PE gun-sights. It really deserves it. Link to comment Share on other sites More sharing options...
fightnjoe Posted November 9, 2017 Author Share Posted November 9, 2017 Many many thanks. For this build no, nothing out of the box. Future attempts, who knows. Ok this is the last, or what I thought was the last, of the weathering. For this part I did go back over the different panels with the oils again. This time my main goal was to add a bit of blending. I did manage to get some better definition on some of the panels and did add some further effects on the panels near the cowl. Now following this set of photos this build went quickly. The small bits went on with little issue other than the canopy. I will expand on that more on the final update but for now I will leave these with you. All comments, critiques, and criticism are encouraged. Joe LSP_Kevin and Shaka HI 2 Link to comment Share on other sites More sharing options...
fightnjoe Posted November 11, 2017 Author Share Posted November 11, 2017 My friends this build is finished. Following the last update the little things were completed and attached. There was one issue that is now a glaring reminder to me that it is not over until it is over. One of the last attachments was the clear parts. Following my normal procedure I fitted them and then used Tamiya Extra Thin to attach. This time the glue marred the surface and made the clear nasty. This does happen and in itself it did not bother me too much except for the idea that I had been working this "live" and did not have alternative parts. All in all this experiment was a success in my mind and I put it to the shelf with a smile. All comments, critiques, and criticism are encouraged. Joe LSP_Kevin 1 Link to comment Share on other sites More sharing options...
LSP_Kevin Posted November 11, 2017 Share Posted November 11, 2017 Congrats on getting it finished, Joe! Maybe now I should drag mine out again. Kev Link to comment Share on other sites More sharing options...
fightnjoe Posted November 17, 2017 Author Share Posted November 17, 2017 Kev it is a fun kit to play with. Many thanks. Joe Link to comment Share on other sites More sharing options...
