Simmo.b Posted May 12, 2017 Share Posted May 12, 2017 Very nice work!! I have this one to do as well but may do the photo recon A5 first monthebiff 1 Link to comment Share on other sites More sharing options...
monthebiff Posted May 12, 2017 Author Share Posted May 12, 2017 Andy WOW .. absolute precision work ... looking simply perfect Keep 'em coming Peter Thank you Peter, The AIMS parts are very good and easy to work with so far. Regards Andy Link to comment Share on other sites More sharing options...
monthebiff Posted May 12, 2017 Author Share Posted May 12, 2017 Very nice work You have done Let the pics come Mark Mark, I will try and keep the build log picture heavy as its the best way to tell the story. Regards. Andy mark31 1 Link to comment Share on other sites More sharing options...
monthebiff Posted May 12, 2017 Author Share Posted May 12, 2017 WOW! Some excellent work here Watching with great interest, Ju-188 is definitely one of the most beautiful WW2 airplanes and one of my favorite too. Best regards Hubert I agree with you Hubert, The Ju-188 is a beautiful looking aircraft and hopefully I can do the AIMS conversion justice. Regards. Andy Kendzior 1 Link to comment Share on other sites More sharing options...
monthebiff Posted May 12, 2017 Author Share Posted May 12, 2017 Very nice work!! I have this one to do as well but may do the photo recon A5 first Thanks for stopping by Simmo, So many nice versions of the Ju-88 to build its difficult to know where to start. If this one goes well I think a 388 will be on the to build list for me as well. Regards. Andy Link to comment Share on other sites More sharing options...
dutik Posted May 12, 2017 Share Posted May 12, 2017 Nice build, indeed. AIMS kits are great. Be aware that the major challenge still is ahead: Fitting the two large canopy clear parts together (and to avoid cracks, frosting, glue finger prints and all that horrors)... Good luck! I'll Keep my fingers crossed! Regards - dutik monthebiff 1 Link to comment Share on other sites More sharing options...
Kendzior Posted May 12, 2017 Share Posted May 12, 2017 [...] Be aware that the major challenge still is ahead: Fitting the two large canopy clear parts together (and to avoid cracks, frosting, glue finger prints and all that horrors)... Good luck! I'll Keep my fingers crossed! Regards - dutik For such tasks I'd recommend any odourless CA glue: no frosting, clear when cured. Little bit weaker than standard CA, but strong enough to keep the parts together. For me it always works perfectly. Best regards Hubert dutik 1 Link to comment Share on other sites More sharing options...
monthebiff Posted May 12, 2017 Author Share Posted May 12, 2017 Nice build, indeed. AIMS kits are great. Be aware that the major challenge still is ahead: Fitting the two large canopy clear parts together (and to avoid cracks, frosting, glue finger prints and all that horrors)... Good luck! I'll Keep my fingers crossed! Regards - dutik Thanks for the warning dutik.........keep thinking about exactly how I'm going to tackle the cockpit as a whole, I have a few idea's on how I will go about it but in the mean time I will get all the cutting up/ easy parts of the conversion done. Regards. Andy Link to comment Share on other sites More sharing options...
monthebiff Posted May 12, 2017 Author Share Posted May 12, 2017 (edited) Having an unexpected day at home I set about work on the tail plane and fitting the resin extension pieces. As you can see the unmodified kit parts are below the converted, due to the way Revell have you construct theses sub assemblies first you have to fit the extension to the control surface and then build the plastic parts together prior to fixing the resin wing tip. And this is what I have ended up with today. The fit of these extension parts are really nice, I've also had a look at the aileron extensions but these will need some serious work by the looks of things Regards. Andy. Edited January 2, 2020 by monthebiff dutik, Greg W, tucohoward and 1 other 4 Link to comment Share on other sites More sharing options...
monthebiff Posted May 13, 2017 Author Share Posted May 13, 2017 (edited) Have spent today painting and installing the Profimodeller tail wheel assembly. After much deliberation I sprayed the parts RLM 02, after seeing some online shots as well as the Ju-88 displayed as RAF Cosford some of the U/C parts looked to be an anodized gold colour....... where they painted RLM 02 initially all those years ago who knows so artistic licence said they where....... Then the huge spine piece added which needed a fair bit of trimming to get it to sit flush. Not bad but not perfect and some work required, then on to cutting back the lower fuselage insert. Pretty happy with progress today, lots of sanding, filling, sanding etc followed by my most favorite job of re-scribing is next on the list! Regards. Andy Edited January 2, 2020 by monthebiff MikeMaben, Kendzior, Pastor John and 6 others 9 Link to comment Share on other sites More sharing options...
Gazzas Posted May 14, 2017 Share Posted May 14, 2017 It's really nice to look 'up' into a tailwheel assembly and see parts that actually look like they will make the wheel extend or retract into the space. Very nice! Love the way all of the parts are being prepared. Gaz monthebiff and KiwiZac 2 Link to comment Share on other sites More sharing options...
monthebiff Posted May 14, 2017 Author Share Posted May 14, 2017 It's really nice to look 'up' into a tailwheel assembly and see parts that actually look like they will make the wheel extend or retract into the space. Very nice! Love the way all of the parts are being prepared. Gaz Thank you Gaz, In the end I'm leased I added the tail wheel update set as it does add some interest to the massive hole that is there. Really enjoying this build so far, I really like working with resin and chopping a base kit in to pieces so this conversion is right up my street!! Regards. Andy Link to comment Share on other sites More sharing options...
airscale Posted May 14, 2017 Share Posted May 14, 2017 I am really enjoying watching this come together - I started one but didn't get too far before getting distracted by something else so I am living that build through you It will make for one impressive model when done - do you have a scheme planned? I was going to do a dark blue French aeronavale one as they had a few - think the one I liked was also used as an HS293 testbed in that scheme ..I remember getting frustrated by struggling to find references too, so if you need any, I did build up pretty much most of what could be found out there - particularly in the cockpit so let me know if I can help.. Peter monthebiff 1 Link to comment Share on other sites More sharing options...
Bomber_County Posted May 14, 2017 Share Posted May 14, 2017 Nice build Andy, heard good things about AIMS, that cockpit is stunning straight out of the wrapper....... Pulling a chair up.......... monthebiff 1 Link to comment Share on other sites More sharing options...
imatt88 Posted June 7, 2017 Share Posted June 7, 2017 Love it! monthebiff 1 Link to comment Share on other sites More sharing options...
