BloorwestSiR Posted March 15, 2016 Share Posted March 15, 2016 Takka!Takka! Takka! Takka! After finishing my FR IX, I guess I couldn't stay away. So here's my next Spitfire build. As most have probably guessed, this will be MH434 from the film Battle of Britain. I'll be using the fundekäls sheet for the markings. The biggest hurdle I had was that I had previously assembled most of the wing. In doing so, I used the wrong cannon fairing bulges. To replicate the look of the .303 armed MK II Spitfire, the cannon barrels and their fairings were removed. This meant I had to remove them from my wing. I decided to try and cut them off with a small razor saw. This worked out better than I thought and I managed to get both fairings removed without damaging any of the detail on the surrounding panels. Next were the leading edge inserts. I used sprue from the kit to plug the openings. Then I sanded them to their approximate shape. The inserts were then attached to the wings and the final shaping will be done once they're dry. I also filled in the holes in the wing panels with sheet styrene. Carl SciFi58, Shaka HI, sandokan and 4 others 7 Link to comment Share on other sites More sharing options...
mozart Posted March 15, 2016 Share Posted March 15, 2016 Well done Carl, another build worth watching! Max Link to comment Share on other sites More sharing options...
dodgem37 Posted March 15, 2016 Share Posted March 15, 2016 Nice correction. Sincerely, Mark Link to comment Share on other sites More sharing options...
Shoggz Posted March 15, 2016 Share Posted March 15, 2016 Looking forward to this Carl! Link to comment Share on other sites More sharing options...
MikeC Posted March 15, 2016 Share Posted March 15, 2016 Nice one, will be watching. "Hello Rabbit leader, I thought you might come in from the sun." geedubelyer 1 Link to comment Share on other sites More sharing options...
Guest Peterpools Posted March 15, 2016 Share Posted March 15, 2016 Carlway to go! I'll be following all the way. Keep 'em coming Peter Link to comment Share on other sites More sharing options...
monthebiff Posted March 15, 2016 Share Posted March 15, 2016 Nice work around Carl, will be following with interest. Regards. Andy Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 16, 2016 Author Share Posted March 16, 2016 Thanks for dropping in everyone! I didn't get much done tonight as I went to see 10 Cloverfield Lane. It's good and worth the time away from the bench. I masked off around the panels so that I wouldn't lose too much detail once I started sanding. After sanding, I did another coat of filler. More to let that dry and sand it back tomorrow. I'm using dissolved sprue as the filler. Carl SciFi58, sandokan and geedubelyer 3 Link to comment Share on other sites More sharing options...
geedubelyer Posted March 16, 2016 Share Posted March 16, 2016 Glad you decided to build another Spitfire alongside the Esprit Carl. Neat work so far. I guess you'll need to rescribe the .303 gun hatches and add the openings in the wing leading edge? Or did this airframe retain the cannon hatches for the movie? Interested to follow along on this one. Cheers. Link to comment Share on other sites More sharing options...
dennismcc Posted March 16, 2016 Share Posted March 16, 2016 Nice work and a great choice of subject. Cheers Dennis Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2016 Author Share Posted March 17, 2016 Glad you decided to build another Spitfire alongside the Esprit Carl. Neat work so far. I guess you'll need to rescribe the .303 gun hatches and add the openings in the wing leading edge? Or did this airframe retain the cannon hatches for the movie? Interested to follow along on this one. Cheers. Thanks Guy! It wasn't a hard decision. I enjoyed building the FR IX so much that it was easy to just get this one out. According to the markings info, the cannon hatches were just just covered with that panels. It was done for appearance rather than operation. ' Rat a tat, tat tat... ' coming along at a good pace now just like the guns in the skies ! :piliot: AWESOME work Carl. Woo hoo.. Nice work and a great choice of subject. Cheers Dennis Thanks Maru and Dennis! I'll have a bit more to update later. Carl Link to comment Share on other sites More sharing options...
monthebiff Posted March 17, 2016 Share Posted March 17, 2016 All that wing panel sanding reminds me of my Alley Cat PR Spitfire conversion, keep up the great work Carl. Regards. Andy Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2016 Author Share Posted March 17, 2016 All that wing panel sanding reminds me of my Alley Cat PR Spitfire conversion, keep up the great work Carl. Regards. Andy I know, I built one as well. Actually, I have a second set in the stash that I thought about taking some of the inserts from. I decided they'd still need work to make them fit so I might as well stick to styrene. Carl Link to comment Share on other sites More sharing options...
BloorwestSiR Posted March 17, 2016 Author Share Posted March 17, 2016 I decided to simplify the build a bit. I'm going to eliminate the working control surfaces as well as the removable engine cowls. To that end, I've assembled the control surfaces and mounted directly to the wing without using the PE hinges. I then added the wing tips and landing flaps. The wings are pretty much done now. I then assembled just the necessary parts for the engine and attached the side cowl panels. dmthamade, SciFi58, sandokan and 2 others 5 Link to comment Share on other sites More sharing options...
Shaka HI Posted March 18, 2016 Share Posted March 18, 2016 Unless you're going wire up that engine -- I personally think it's better to build it with the panels closed. And the control surfaces look waaay better without the useless PE parts (just my opinion). geedubelyer, dmthamade and BloorwestSiR 3 Link to comment Share on other sites More sharing options...
