Tail Boom Productions 1:1 RAF Spade Grip. 10/28/17 Completed.
LSP_Ray
  • 1 month later...
  • 1 month later...
OK, where was I?
Sorry for the delay, Real Life got in the way: windows leaking in one place, second place flooded, and the wife is now undergoing chemotherapy.  :(  Still trying to finish my first book, too.
Anyway, trying to get some work done on it. I am swapping the MG armed spade for the cannon-armed one. It is a little more classic Spitfire, in my opinion.
Note I have also sawed the short post off. That is really a Hurricane style where the spade is on a tube. The Spit sits on an open trapezoidal-shaped arm. Will have to scratch something up.
Here is the worst part of this kit. It is supposed to be a sheet metal clamp that holds the gun camera switch. It is really thin and brittle. On both my kits (MG & cannon) it was broken during transit. Also, you are supposed to glue the piece that holds the button to the inside edge. Even by following the instructions, suggesting a pair of pins, it would be a very weak point. It would easily get broken during assembly, or by handling.
So I got out the Dremel and ground it off.
While I had the Dremel out, I also ground out the openings for the pneumatic piping.
Probably going to need to clean those up a bit, but you get the idea.
To replace the clamp, I made a paper template before grinding it off. I then transferred the template to some sheet aluminum. I cut out the two halves and drilled the necessary holes. Here they are all cleaned up.
I then worked them around the handle, and using some hardware that matched the kits, fastened them together.
And here they are ready for paint.
I also thought instead of using the provided cable that you are supposed to paint like brass tubing, why not use real brass tubing?
So I got some soft tubing and here is a length in place in one of the slots where it is visible on the real thing. I will put another piece in there (maybe two more) to finish that off.
Hopefully it won't be so long before my next update!
