What 109 to buy
  • Please log in to reply
43 replies to this topic
#1 Stinger16
Stinger16
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 472 posts
  • Gender:Male
Posted 14 November 2017 - 09:29 PM
Hello guys, I’m wanting to build a 1/32 Hartmann 109g. I can either go with the Hasegawa 109 g-6 or the Revell 109 g-6. What is the better kit to buy moving forward
Thanks for your input
Jeff
  • harvey likes this
#2 Zero77
Zero77
    Senior Member
  • LSP_Members
  • PipPipPipPipPipPip
  • 5,796 posts
  • Gender:Male
Posted 14 November 2017 - 09:39 PM
I have built several of each kits and both have their pros and cons. The Revell one is cheaper in Europe (i dont know if it's true in the US), and have more inner details in my opinion (the cockpit is nice from the box), and more options (both early and late canopies and tails, large and small wheels....). The dihedral is more accurate than on the Hasegawa kit. On the other hand there are several little acuracy flaws, like the cowling guns spacing, the cowl bulges size, or the spinner so if you want something accurate you may need some Alleycat correction sets.
The Hasegawa kit is older but it's more straightforward, with no surprise and no difficulties. You have more aftermarket options with a pretty cheap but nice Aires resin cockpit. You almost dont need any correction except that you have to putty a panel line on the engine cowling (actually a seam between the cowling and the fuselage). However you wont have any version options in the box, so you have to choose a kit matching the aicraft you want to build (early or late canopy, small or large size, small bean shape or large wheel housings on the wings, small or tall tail...)
Hope this helps !
Edited by Zero77, 14 November 2017 - 09:40 PM.
  • LSP_Paul, Martinnfb, harvey and 2 others like this
Following the big Photobucket rip-off attempt, all my pictures on the forum cannot display anymore. I try to reupload the RFI pictures, but i'm not sure i'd have enough time and energy to reupload the pictures of the WIP threads. If you're interested in a specific subject and want me to reupload some pictures, just let me know. :)
Finished : F-16C Barak, F-4J VMF333, Czech Mig-19PM, Bell X-1, Russian Su-25 in Chechnya, Ta152H-1, Czech Avia S.199, Heinkel He162, Swiss AF Bf109G-6, Regia Aeronautica Bf109G-6, P-47D "Slick Chick", RFC Sopwith Pup, A5M2 Claude, Schneider Cup 1926 Macchi M.39, German F-104G JaboG34, Curtiss P-6E, Curtiss P-36A USAAC, Piper SuperCub floatplane (PA-18-150), Russian built Nieuport 11, Albatros D.Va Seefrontstaffel 1, Bf109G-12 (two-seater trainer), Texas ANG F-86D,  Post-war Hawker Tempest Mk.V, Bf109E-3, F-35A 34th FS
#3 Mikester
Mikester
    Senior Member
  • LSP_Members
  • 1,530 posts
  • Gender:Male
Posted 14 November 2017 - 10:34 PM
Hope this helps !
The Revell kit is cheaper in the US as well.
Agree with everything you said, they both have their strong and weak points but if I'm building just one 109 for my collection I'm going with Hasegawa.  Since they both have minor flaws the Hasegawa's ease of assembly and straight-forward construction make it the more appealing choice for me.
  • Rick Griewski, harvey, LSP_Typhoonattack and 2 others like this
Mike Offutt
http://www.jg32.org
#4 oyoy5
oyoy5
    Senior Member
  • LSP_Members
  • 995 posts
Posted 14 November 2017 - 11:12 PM
Another vote for Hasegawa, simple build very accurate and looks awesome when finished. I still have a hard time figuring Revell miss on the cowling, bulges and spinner. They should redo the spinner like Hasegawa did on there newer Bf 109F-4 which is very well shaped. I feel the same on the FW 190 as well, Hasegawa wins again.
  • harvey likes this
#5 John Irwin
John Irwin
    LSP Junkie
  • LSP_Members
  • PipPipPipPip
  • 181 posts
Posted 15 November 2017 - 01:20 AM
I built the Revell G-6.  Added the Alleycat correction set which helped address most of the kit's issues (cowling, elevators with those thick discs, the kit seat with the molded on seatbelts, solid exhausts, solid cooling scoops, misshaped radiator, etc). Also added the Aires cockpit which was a huge improvement over the crappy kit one.   Had major fit problems with the Aires resin, literally put 20 hours of work into trying to get it to fit without throwing off the geometry of the kit nose / windshield, etc.   Finally got it all together but it wasn't 100% perfect.
In retrospect, I should have gone with the Hase kit.   One should not have to purchase a boatload of correction sets for "new tool" product.  That being said, if you aren't concerned with absolute accuracy, proceed with the Revell product.   Minus all the resin, it would build up quite easily and when completed, looks close enough to keep most people happy.
#6 Jolly Roger
Jolly Roger
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 218 posts
  • Gender:Male
Posted 15 November 2017 - 02:09 AM
Having built both, if I were to build another I would go with the Hasegawa.
Roger <(^^,)>
#7 Hardcore
Hardcore
    Senior Member
  • LSP_Members
  • 1,566 posts
  • Gender:Male
Posted 15 November 2017 - 04:05 AM
The landing gear is very weak on the Revell kit. A metal replacement would add to the cost.
I recommend the Hasegawa kit.
#8 LSP_Typhoonattack
LSP_Typhoonattack
    Senior Member
  • LSP Moderator
  • 25,715 posts
  • Gender:Male
Posted 15 November 2017 - 04:13 AM
I'd echo the thoughts of the others; Hasegawa all the way.
Kevin
I was going to procrastinate tonight, but decided to wait.
In Progress:
#9 Airfixer
Airfixer
    Hooked For Life
  • LSP_Members
  • PipPipPipPipPip
  • 432 posts
  • Gender:Male
Posted 15 November 2017 - 04:38 AM
Same here.
Hasegawa hands down.
#10 thierry laurent
thierry laurent
    Senior Member
  • LSP_Members
  • 5,857 posts
  • Gender:Male
Posted 15 November 2017 - 07:22 AM
There is no G6 to recommend as such. The Revell, Trumpeter and Hasegawa have good and bad points.
The Hasegawa is the easiest to build, then the Trumpeter and finally the Revell but none is really difficult to build as such.
The Trumpeter kit is the only one with riveted surfaces and also the only kit for which there is no aftermarket item to solve the main issue (the shape under the nose). In Europe, I would recommend the Revell kit with the Alleycat correction set (cheapest option). For the Hasegawa kit option, I would recommend at least a new spinner, new exhausts and a resin cockpit. I think Aires/Quickboost released all those items. For a more detailed assessment of all the kits, have a look at the relevant tweak lists on LSP.
Hth
Thierry
  • Tony T and Zero77 like this
#11 DonH
DonH
    Senior Member
  • LSP_Members
  • 681 posts
  • Gender:Male
Posted 15 November 2017 - 07:25 AM
Wait and buy a Tamiya kit  :whistle:
  • Kagemusha, nmayhew, JohnB and 2 others like this
Done and Dusty
Tamiya Spitfire IXc
http://forum.largesc...wtopic=42491=
#12 ade rowlands
ade rowlands
    Senior Member
  • LSP_Members
  • 1,003 posts
  • Gender:Male
Posted 15 November 2017 - 08:05 AM
Well I want to do a G-5 and have gone the Revell route because I got the base kit G-6 for a steal. However by the time I’ve added aftermarket to correct the kit issues it’s not so much of a steal, sure most of it like the Brassin cockpit is not an essential upgrade I picked one up at the Eduard stand at SMW because it looks good and I’ve yet to have any fit issues like I do with Aires stuff, plus I was there to pick up other stuff too so thought why not? I’ve got a hold of the Amur nose correction set which I really like the look of, Barracuda Spinner, Eduard wheels, and Eduard bronze gear legs, to me, those are what’s required, optional stuff was the Barracuda upper wing sections and as I’m building a G-5 armed with cannon gondolas I picked up a set of those from Barracuda also. All in all it’s run me to about £70 for everything. Decals I can cobble together the markings from what’s in my spares box plus the kit decals for stencils and crosses. To be honest, I’d have added much of the same stuff had I gone Hasegawa but the initial kit outlay would have been at least £30 for a Hasegawa one from HLJ and add shipping to that plus the lottery of customs charge or no customs charge if it sneaks through or gets caught the £15 I paid for the Revell kit won out. Whether any one builds better than the other I’m not too concerned about I have what I have and the way I build it’ll look like a child built it regardless of what it cost or who made it.........
  • Padraic Conway and Mikester like this
#13 Jennings Heilig
Jennings Heilig
    Senior Member
  • LSP_Members
  • 7,156 posts
  • Gender:Male
Posted 15 November 2017 - 05:01 PM
Exactly
"It's all part of the show..."
#14 Kagemusha
Kagemusha
    Senior Member
  • LSP Moderator
  • 9,917 posts
  • Gender:Male
Posted 15 November 2017 - 05:05 PM
Only a matter of time.
#15 ade rowlands
ade rowlands
    Senior Member
  • LSP_Members
  • 1,003 posts
  • Gender:Male
Posted 15 November 2017 - 07:17 PM
Totally forgot about the Tamiya 1/48 job coming out. If they do upscale it I’ll be up for one.
